Secret of quiet up shifting?
Discussion in 'UK Motorcycles' started by Harry Bloomfield, Apr 9, 2005.
  1. Hi,
    Working up through the box at high or even medium revs, I always
    produce a loud thump whilst changing up through 1st, 2nd and 3rd. The
    only way I can achieve a smooth change is by doing it very slowly,
    carefully and at low revs.
    It is not the bike, it is me!
    I can manage a perfectly smooth clutchless change up everytime, but I
    don't like doing it. So what is the technique, what am I doing wrong?
  2. Harry Bloomfield
    I've got a similar problem - everytime I hammer a nail into my skull,
    it hurts, no matter how slowly & carefully I do it.
    I can hammer nails into wood without it hurting everytime, but I don't
    Krusty, Apr 9, 2005
  3. Gavsta was thinking very hard :
    I don't think so.
    I heard mention of 'pre-loading the pedal' - putting a small amount of
    pressure on the gear pedal before pulling the clutch in. I have tried
    it, but it seems little different to clutchless changes. As soon as you
    dip the throttle it changes whether you pull the clutch in or not.
  4. Harry Bloomfield
    Catman Guest
    Which is the point of a clutchless shift. Is it still clunking?
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 155 TS
    www.cuore-sportivo.co.uk
    Catman, Apr 9, 2005
  5. Harry Bloomfield
    Catman Guest
    Should have read this bit. Stick with the clutchless changes, you really
    don't need a clutch (IME) to upshift unless you're going slowly and may
    need to feather.
    Catman, Apr 9, 2005
  6. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Catman
    If you don't really give a toss about the state of the gearbox
    internals, you mean.
    Grimly Curmudgeon, Apr 9, 2005
  7. Harry Bloomfield
    Catman Guest
    Is this one of those long standing things? Clutchless up-shifts shag your
    box, or something?
    Catman, Apr 9, 2005
  8. Only on wheelying shafties.
    genuine_froggie, Apr 9, 2005
  9. Harry Bloomfield
    Catman Guest
    Odd. Mine seems OK, as did the Monster.......
    Catman, Apr 9, 2005
  10. Harry Bloomfield
    Catman Guest
    Ahhh, that explains it, then :)
    Catman, Apr 9, 2005
  11. It was somewhere around Barstow, on the edge of the desert, when the
    Long term, they'll round off the engagement dogs and the box will start
    jumping out of gear either on the upchange or the overrun.
    Doesn't matter if you have the bike for a year or two from new and don't
    put a lot of miles on then punt it on for the next owner to catch the
    problem.
  12. Harry Bloomfield
    Catman Guest
    Hmmmm. Define 'long term for me'?
    Catman, Apr 9, 2005
  13. It was somewhere around Barstow, on the edge of the desert, when the
    Depends on the hardness of the dogs, and one or two really muffed
    changes might cause the damage.
  14. It was somewhere around Barstow, on the edge of the desert, when the
    Ah, but for how much longer? As I said above (or below, you can never
    tell), it depends on the hardness of the material. The dogs are undercut
    slightly so they're tolerant of a little bit of rounding off but one day
    the wear will become too much and it'll start developing problems.
    True, the upchange is easier on the box than the downchange, but the
    problem remains the same.
  15. Harry Bloomfield
    Catman Guest
    Average mileage figujre? I mean, the Triple has >6k so far, the Monster had
    similar.
    Catman, Apr 10, 2005
  16. It was somewhere around Barstow, on the edge of the desert, when the
    It's a how long is piece of string question. I've come across 'boxes
    which have been fucked in 20k miles and others have went on for much
    longer in relatively sympathetic clutchless changers hands. Otoh, some
    folk are unlucky enough to have gearbox problems even though they always
    use the clutch.
    It's just a general thing; mechanical sympathy is learned and if you
    envisage the little bits of metal whizzing around and suddenly being
    forced into and out of mesh with one another without so much as a by
    your leave you'd rapidly realise the impact on your future wallet.
    Another thing; if the makers thought they could get away without giving
    you a clutch, you wouldn't get one.
    Grimly Curmudgeon, Apr 10, 2005
  17. Harry Bloomfield
    Catman Guest
    Well, I tend to base my mechanical sympathy on what I can feel and
    hear........
    Except one that worked on the down shift, perhaps ;)
  18. It was somewhere around Barstow, on the edge of the desert, when the
    Of course not, but they're not being forced into mesh in a loaded state.
  19. It was somewhere around Barstow, on the edge of the desert, when the
    Well it depends on getting it just right every time; a slight backing
    off of the throttle to unload the geartrain just as you snick it up and
    it should be ok. The real damage occurs when you muff a change and the
    gears are forced into mesh while power is still being applied; the dog
    corners are forced to slide over each other and there's a minute amount
    of wear happens. Wear, as you know, is cumulative.
    Sometimes the gears don't mesh properly and you get a nasty grunching
    racket - that's trouble in store if you do that too often.
    The Japanese are pretty good at gearboxes, I must admit; but even the
    toughest box will eventually crack in the hands of the hamfisted (and
    footed). Those geardogs are very tough but not indestructible.
    Whatever; if folk are happy to carry on doing clutchless changes, it's
    up to them. I'd be awfully leary of buying a s/h bike that'd been
    subjected to thousands of clutchless changes by the PO, having been
    caught that way before.
  20. Harry Bloomfield
    Mash Guest
    How's my Fazer going? that had at least 10k of clutchless upshifts.
    Mash, Apr 10, 2005
