Servicing the Sprint
Discussion in 'UK Motorcycles' started by Jeremy, Aug 29, 2006.
  1. Jeremy
    Jeremy Guest
    The Sprint needs a major service @ 12,000 miles. Currently on around
    9,000 but it's 12 months since it was last serviced (when I bought it
    from Carl Rosner). So I figured I'd do the annual bits - oil and filter
    change plus inspections/adjustments as required.
    The owner's handbook has a table indicating what's required plus
    instructions for how to proceed.
    2 questions:
    1) Would I benefit from having the HBOL even for these routine
    maintenance tasks?
    2) Would any of you who are familiar with the model be aware of any
    significant differences after the 2000 model year? The HBOL (as far as I
    can see) covers the models only up to 2000.
    jeremy
    Spitfire
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170023095391
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
  2. Jeremy
    TOG Guest
    Yes, absolutely. For instance, there's one awkward bit when servicing
    triples which involves removing the camchain tensioner to allow enough
    slack to shift the cams to gain access to the valves. because of the
    120 degree crank throw, it's always under some form of spring or
    compression tension, and can (will) 'jump' when you release the cachain
    tension, knocking the timing out.
    At least it did on my mate's T-bird. The Haynes BOL gave a wrk-around
    involving jamming the thing with a piece of wood. Actually, we managed
    to re-time the engine easily enough, but still.
    Then there are the various torque settings for the various bolts. I
    dunno how much work you plan doing, but I wouldn't dream of tackling it
    without a manual.
    No idea, sorry.
    TOG, Aug 29, 2006
  3. Jeremy
    Jeremy Guest
    I'm not thinking of going that far and I think that's beyond the scope
    of the owner's handbook - will leave all that to the dealer. Just basic
    oil & filters type stuff for now - I think it best to get the HBOL
    anyway.
    Well it'll have to do then.
    jeremy
    Spitfire
  4. Jeremy
    Tim Guest
    The HBOL covers about 6 models (it's in my garage and I can't be arsed
    to look) and is a bit vague from time to time. However the Triumph
    workshop manual also suffers from irritating gaps, so I find it best to
    have both to hand. I am speaking of a T595, but assuming that this is
    generally so in your case.
    Tim, Aug 29, 2006
  5. Jeremy
    Adie Guest
    the 12K, two year service includes lots of stuff that I'd let a dealer
    do [1]. as long as this is done next time then I'd thought you'd be
    ok. Mine had done 10K and I opted for full service. its hardly turned
    a wheel since so prolly wont get the next one (3 years or 18K).
    [1] and charge a wedge for
    Adie
    Triumph 955iSS (for sale) / ZX9R / GSF1200 bandit (for sale) / CG125
    keeper of the FAQ for my sins
    Adie, Aug 29, 2006
  6. Jeremy
    Jeremy Guest
    Yeah, I know the 12k is a "fair chunk of change" service - best part of
    £400 IIRC. But by this time next year perhaps I will have succumbed to
    the delights of an alternative....
    Spitfire
    jeremy
    Jeremy, Aug 30, 2006
  7. Jeremy
    Adie Guest
    mine was closer to £500.
    Adie
    keeper of the ukrm faq for my sins
    Triumph 955iSS (for sale) / ZX9R E1 / GSF1200 bandit (for sale) / CG125
    Adie, Aug 30, 2006
  8. Jeremy
    What could possibly need doing to cost that?
    Hog, Aug 30, 2006
  9. Jeremy
    Tim Guest
    Labour costs for a start. If I remember correctly it's a full day in the
    workshop for the major service.
    Tim, Aug 30, 2006
  10. Jeremy
    If there are ancillary tasks perhaps, brake pads/disks, tyre changes,
    head bearings etc. A basic major service though, oils/brake fluid,
    plugs, valve clearences, balance/emissions - 4 hours or the workshop
    manager is getting gnarly on yer arse. I would have been expected to put
    two a day out.
    Hog, Aug 30, 2006
  11. Jeremy
    Tim Guest
    The schedule for a Daytona 955i can be found here;
    http://home.hetnet.nl/~speed4/bikes/955i/Daytona955i_from_vin132513.pdf
    Tim, Aug 30, 2006
  12. Jeremy
    Err yes which supports what I just said. It does include Lube Headstock
    Bearings, that could be hard or easy on these, don't know. Still it
    should only take a whole day on a 'Wing unless problems are identified
    along the way.
    I guess perhaps 'Techs do not get slave driven the same way now. Doing
    it comfortably could take a day.
    Hog, Aug 30, 2006
  13. Jeremy
    Tim Guest
    *If* you slavishly follow the instructions; e.g. battery out, this panel
    next, etc., I can see it taking quite some time. I only do so much
    servicing before giving it to the shop partly because of not having some
    special tool and partly that if I screw-up I know it's going to cost. If
    nothing else the shop is supposed to have a room full of spares and
    stuff which I certainly don't have.
    Tim, Aug 30, 2006
  14. Jeremy
    Access into the rocker cover *could* be a bitch too
    Hog, Aug 30, 2006
  15. Jeremy
    Tim Guest
    It's fairly crowded under the tank. I took it very slowly putting on the
    Scottoiler connection to the vacuum. Even so I was caught out by the
    extra connector on the loom that isn't used, it's for California
    emission control.
    Tim, Aug 30, 2006
  16. Jeremy
    Whew that must be a long cable
    Hog, Aug 30, 2006
  17. Jeremy
    SD Guest
    Wings are remarkably easy on service time, ityf.
    I'm sure an 8k service was only 3-4 hours.
    It's been a while since it had a dealer service.
    67 thousand miles, in fact.
    | ___ Salad Dodger
    |_\_____/_| ..83466../..22358.../..31893.
    '^' RBR Clues: 52 Pts:1005 Miles:3416
    SD, Aug 30, 2006
  18. Jeremy
    It's Adie. She's high maintenance.
    platypus, Aug 30, 2006
  19. Jeremy
    Adie Guest
    obviously not as Ive been waiting since early August for my husband to
    bring me some flowers.
    Adie
    Adie, Aug 30, 2006
  20. Jeremy
    ginge Guest
    Where's he supposed to find a front garden full of daffodils at this
    time of year?
    ginge, Aug 30, 2006
