Shaft drive vs Chain drive - benefits or drawbacks?
Discussion in 'Australian Motorcycles' started by DaZZa, Jan 28, 2004.
  1. DaZZa
    sanbar Guest
    Worked for that former cop who beat the speeding ticket rap in court.
    Claimed he was accelerating to avoid an accident somewhere near/in
    Mansfield IIRC, and the judge agreed.
    - sanbar
    sanbar, Jan 29, 2004
  2. In aus.motorcycles on Thu, 29 Jan 2004 12:22:30 +1100
    I get 17-18km/l on the daily commute on the Guzzi, and 20+ on long
    highway runs.
    I don't often fang it, when I did I found that spending heaps of time at
    or near redline didn't make the consumption drop below the normal
    commuting amount.
    What it did do was drop the normal commuting consumption! I went from
    low 17s to high 18s.
    If you want a big bike with good fuel consumption, a square-slide
    Dellorto soft cam T/SP series Guzzi is a very good candidate. You get
    bugger all performance really, but those squareslides are misers for
    fuel.
    Zebee
    Zebee Johnstone, Jan 29, 2004
  3. DaZZa
    Goaty Guest
    Kleenex to pit no 3 please ...
    Cheers
    Goaty
    Goaty, Jan 29, 2004
  4. TPG's farking news service ditched your post, Smee, so I have to reply to
    Zebee's.
    But,.....
    For starters, my GPX250 accelerates quite acceptably at highway speeds, but
    what do I need to "get away" from?
    Secondly, what I'm getting at is that "powering out of trouble" means that
    to avoid one potential danger, you are increasing your speed, (and, as you
    are powering away from the danger, putting yourself in a situation where you
    can't brake if another danger arrives).
    If you leave appropriate gaps, keep up your concentration etc, you will
    never need to power out of trouble.
    That having been said, everyone does make mistakes, and there are times when
    having that power is useful for getting you out of trouble that you have put
    yourself in. But from my experience, in traffic, I'd rather better brakes
    than more power anyday. The GPX (RII model, with the twin discs with 2-pot
    callipers up front) I find to be a better mount around town than the ZX10
    (similar brakes (although a little larger, and with semi-floating discs),
    but a lot heavier), despite the ZX10 having heaps more power.
    To be fair, I used to "believe" in the powering out of trouble thing, but to
    be honest, a lot of it was just an excuse to ride fast. Since I've had my
    license back (after an 18 month absence which was entirely my fault) I don't
    ride as fast, but I'm a lot safer. I haven't been in a single situation
    where I've even thought about "powering" out of trouble in the last 2 years.
    I use the brakes with a fair bit of force every week or so though.
    Besides, all that power isn't going to help when the traffic is chockers.
    Being small, light, and nimble might.
    James Mayfield, Jan 29, 2004
  5. I thought it was a 17" front, vs 16".
  6. Getting away from what?
    Besides, if you want to increase the distance between yourself and
    someone else, judicious use of the brake can be just as effective as a
    twist of the throttle.
    There are SOME times when having power is handy, but it's use to 'get
    out of trouble' is ,IMHO, highly over-rated.
    That said, I love KNOWING that on the highway I can just twist the grip
    on the K and be around that road train in a flash. If I was on the GS, I
    probably wouldn't attempt it; and THAT is another way of getting out of
    trouble - by not getting into it in the first place.
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
    Peter Cremasco, Jan 29, 2004
  7. DaZZa
    Black Bart Guest
    When that car in the next lane that's about to come across and flatten
    you and hauling on the chocks will just get the car behind you up your arse.
    Black Bart, Jan 29, 2004
  8. DaZZa
    DaZZa Guest
    Pity someone else bought the bastards before I could. :)
    DaZZa
    People can be divided into three classes.
    The few who make things happen
    The many who watch things happen
    And the overwhelming majority who have no idea what has happened
    Picked up from a web site, author unknown
    Address in header is spamblocked. ROT13 the following for email replies
    DaZZa, Jan 29, 2004
  9. I get 16km/l on my 1000cc sidecar. Make you feel better?
    Al
    Alan Pennykid, Jan 29, 2004
  10. I remember noticing it on a loaner z1000(?) Kwaka years ago, but never
    noticed on any Bimmer I took for a ride, so probably depends on how
    well the rear suspension is set up. The Kwaka had a quite noticeable
    rear end lift and slightly sideways under power.
    Also rode an XJ900 for a week or so in the late 80s and didn't notice
    the effect there either.
    Cheers
    Kevin Gleeson
    Technical Director
    Blue Rocket Productions
    Hobart, Tasmania, Australia
    www.blue-rocket.com.au
    Kevin Gleeson, Jan 29, 2004
  11. Swingarm length has a lot to do with it, shorter swingarms lift more than
    longer swingarms. My XJ750 it was very noticeable. The only reason I
    noticed it at all on my K100RS is because I took the Paralever rear off and
    replaced it with a standard K100 Monolever (strength issues for sidecar
    use), it was very noticable then. Shafts dont handle badly anyway, the only
    downside they have is extra unsprung weight (diff/driveshaft weighs more
    than chain and sprockets).
    As far as problems in cornering with shafts most of the horror stories come
    from older Boxers or Guzzis where it is the along the frame crank that is
    the problem, not the shaft. On one of these bikes with a heavy flywheel you
    get a large torque effect throwing the bike to the left or right when you
    accelerate or backoff the throttle suddenly, it can in some circumstances
    throw the bike down into the corner. But the deal is that you dont ride
    like that, you shouldn't be shutting down hard in the middle of a corner
    anyway. Ridden appropriately (and many people can, it's no black art) they
    handle well. It doesn't happen on K-series BMWs (also an along the frame
    crank) as the flywheel/clutch spins in the opposite direction to the engine,
    negating the torque effect.
    Al
  12. DaZZa
    Theo Bekkers Guest
    "James Mayfield" wrote
    KH100?
    I commute 55 kms each way on an 1100 Guzzi. I don't do this to save
    money on fuel. It actually increases my fuel cost as the fuel for the
    company ute is very cheap indeed. I do it because I want to.
    Theo
    Theo Bekkers, Jan 30, 2004
  13. DaZZa
    sharkey Guest
    Yeah, the XLV is quite short and has a very noticeable shaft
    reaction, the rear noticeably climbs under acceleration.
    I don't think it's a problem, though -- it's just one of
    those things you automatically compensate for.
    Yeah, the CX650 used to jitter sideways when idling. When it
    was cold and misfiring it used to look like it was about to
    throw itself off the sidestand! Again, it never seemed to
    make a difference above walking pace ...
    -----sharks
    sharkey, Jan 30, 2004
  14. That can go onto the "Why didn't somebody think of it sooner?" list.
    I've though about this for three minutes, and can already envisage what
    seems like a solution; I humbly submit it here to be drawn, quartered and
    condescended.
    Taking a Guzzi-style longitudinal-vee engine, you could separate the
    flywheel from the crank and replace it with a drive gear, such as modern
    inline-fours have on one of their webs. You then lower the crank in the
    cases, and raise the flywheel-clutch basket-gearbox input shaft assembly.
    Next, make the flywheel a gear to engage with the drive gear fitted to the
    end of the crank, like the clutch basket on an inline four. The crank and
    the flywheel will now spin in opposite directions, negating the torque
    reaction, but retaining the rotational inertia necessary to stop the thing
    stalling every third attempted takeoff from a set of lights.
    To keep the engine compact and lined up with the drive to the back wheel,
    you'd have the gearbox output shaft bolt somewhat underneath the input shaft
    instead of directly beside it, and there'd probably be no need to dry-sump
    the engine because there'd be room for a sump under the gearbox (lowering
    the crank without removing the sump from underneath it would bring the motor
    much closer to the ground).
    Trying this on a Boxer would be more difficult. You'd have to_raise_the
    crank- the cylinders would be unacceptably close to the ground otherwise,
    making it impossible to achieve the sort of thing Al got up to on the
    weekend, lower the flywheel-clutch-input shaft and then stick the output
    shaft where required.
    If you really tried, though, you could possibly even make an extremely short
    engine in which the gearbox shafts sit directly underneath the crank.
    Probably not achievable with a flat twin ( the cylinders would stick out too
    far for the height they'd have to be at then) or a v-twin (the engine would
    end up being too tall), but a short-stroke flat-four or a v-four...
    Waddayasthink?
    Intact Kneeslider, Jan 30, 2004
  15. DaZZa
    Theo Bekkers Guest
    "Alan Pennykid" wrote
    IMHO that's a load of crap Alan. If this was an effect that you can
    feel you should be able to notice it when you accelerate or decelerate
    sharply when travelling in a straight line. It doesn't happen and,
    believe me, my bike has a massive flywheel.
    Theo
  16. DaZZa
    Steve Strik Guest
    Clem,
    Why did you drive to 3 GP's in the mid 90's? ;)
    Steve
    Steve Strik, Jan 30, 2004
  17. DaZZa
    Steve Strik Guest
    Theo,
    That calc gets thrown out if it's a choice of spend $10 or $20k on
    either a car or a bike.
    Steve
  18. DaZZa
    X-No-archive: yes
    sharkey wrote in message ...
    Probably just caught it's own reflection in the window and was shuddering in
    horror.....
    Clem
    [....as you would.]
    Knobdoodle, Jan 30, 2004
  19. DaZZa
    X-No-archive: yes
    Theo Bekkers wrote in message ...
    Eh? Surely you jest!
    I've only ever ridden one 'Guzzi but I could hardly overtake on the bloody
    thing 'cause as I'd accelerate it'd try and turn left!
    I never noticed the effect as pronounced on the one BMW I've ridden though..
    (Maybe I'm a larger percentage of total weight these days!).
    I'm sure though that, like shaft-reaction, it's something you don't even
    notice after 100km-or-so.
    Clem
  20. In aus.motorcycles on Fri, 30 Jan 2004 13:49:14 +1000
    Bizarre.
    My GT has The Flywheel That Ate Mandello, and the T's is not much
    smaller. I haven't noticed a problem.
    I did have a stonkingly light flywheel on the T for a while, an epicycle
    racing item that was a lot of holes held together by some alloy more or
    less.
    The difference is marked in engine behaviour between the two flywheels
    but not in handling.
    Zebee
    Zebee Johnstone, Jan 30, 2004
