Sharing a bike on a trackday?
Discussion in 'UK Motorcycles' started by Ben, May 26, 2009.
  1. Ben
    darsy, May 27, 2009
    #41
  2. Ben
    Well ships would have needed some sort of unique ID, otherwise you
    wouldn't be able to tell one from another, in a fleet situation.
    Trains I'm not so sure about. But in neither case are the names
    generally jusdt a name. They tend to be named after something, whether
    it be an object, a country or a person. Small boats, I grant you,
    often bear human names, but even then it's by no means required.
    Anyway, however it started doesn't mean that we should allow it to
    start again with modern machines.
    Only on TV though. And only for anthropomorphised vales of 'car'.
    Ace, May 27, 2009
    #42
  3. Ben
    Ben Guest
    Ben, May 27, 2009
    #43
  4. Ben
    Ben Guest
    Not quite sure why you'd want to do this[1], but I like the idea...
    http://www.gixxer.com/forums/showthread.php?t=27208
    [1] Cheaper, easier, and better handling to buy a K1 Thou.
    Ben, May 27, 2009
    #44
  5. Ben
    ginge Guest
    With idiots that can't remember numbers containing more than 2 digits.
    ginge, May 27, 2009
    #45
  6. Almost as bad a vendors saying "I'll come down and see yourselves next
    week".
    I had to almost physically[1] restrain myself.
    Phil.
    [1] And now I'm sounding almost RP like..
    Phil Launchbury, May 27, 2009
    #46
  7. Ben
    Alex Ferrier Guest
    You are. Your supposition, however, remains unaffected.
    Alex Ferrier, May 27, 2009
    #47
  8. Ben
    Ace, May 27, 2009
    #48
  9. Ben
    AndrewR Guest
    I recall a Performance Bike's reader's special from years ago, where
    somebody had put an early Fireblade motor into a CBR400 frame.
    Unfortunately they hadn't done much else, so the bike was still running on
    standard CBR4 shock, forks and brakes. So basically the end result was just
    about unrideable and only about 5kg lighter than a stock 'blade anyway.
    The article, which was a full size one, rather than one of their old
    inside-the-back-cover one-pagers, focused mainly on all of the work that had
    gone to getting the motor in to the frame - hand made engine mounts, bespoke
    air-box, etc. and then one paragraph at the end to what it was like to ride
    and I guess that's the point. It's not about making a bike that is, in some
    way, better than the stock stuff from the factory, but about making
    something that's unique, personal and a demonstration of your skill.
    AndrewR, D.Bot (Celeritas)
    Aprilia RSV-1000R, Honda VFR750F-L
    The speccy Geordie twat.
    AndrewR, May 27, 2009
    #49
  10. Ben
    There was something similar used to show up over Maidstone bridge in the
    mid 90s. FZR400 chassis, CBR900RR motor, NC30 swingarm and a rather
    funky set of under-seat pipes, iirc.
    Christ knows what it was like to ride but it looked tempting.
    ogden, May 27, 2009
    #50
  11. Ben
    "What can ourselves do for yourselves today?"
    darsy, May 27, 2009
    #51
  12. Ben
    And Simian had a later one.
    darsy, May 27, 2009
    #52
  13. Ben
    darsy, May 27, 2009
    #53
  14. Ben
    ogden, May 27, 2009
    #54
  15. Ben
    darsy, May 27, 2009
    #55
  16. Ben
    AndrewR Guest
    Because you end up with something that is individual and a demonstration of
    what you personally can do, compared to a stock bike, however good, that
    simply demonstrates that you can draw a cross in the signature box on a set
    of finance papers.
    It's not my thing, because I can barely adjust a chain without having my eye
    out with a spanner, but I can see why people do it.
    #56
  17. Ben
    darsy, May 27, 2009
    #57
  18. Ben
    Ben Guest
    Ben, May 27, 2009
    #58
  19. Ben
    I can speak only for the K4 thou, but the only stability issue of any
    kind that I've noticed is down to the engine making oodles of grunt and
    either sending the front skywards or the back sideways. The chassis is
    stability personified. Anything with the thou engine fitted is going to
    exhibit the same characteristic.
    ogden, May 27, 2009
    #59
  20. Ben
    darsy, May 27, 2009
    #60
