Shogun/Pajero?
Discussion in 'UK Motorcycles' started by Nige, Dec 2, 2010.
  1. Nige
    Nige Guest
    I need a mega cheap 4x4 just for winter, aint going down the expensive route
    this time, anyone had one? I know parts are mega expensive if you need them,
    but generally, are they decent enough to do 20 or 30 miles at a go without
    dropping to bits.
    I hear of overheating probs, i would rather have a lwb & they are bloody
    cheap..
    Nige
    R1
    MX5
    Nige, Dec 2, 2010
  2. Nige
    If you want cheap but adequate for light off roading then a Maverick or
    Terrano 11 can be picked up for peanuts, and the parts are cheap as
    chips.
    Lozzo
    they churn out)
    Lozzo, Dec 2, 2010
  3. Nige
    and get some Firestone tyres. They rock...
    wessie, Dec 2, 2010
  4. Nige
    petrolcan Guest
    You are a bad man.
    petrolcan, Dec 3, 2010
  5. Nige escribió:
    From Spanish dictionary:
    "pajero, ra.
    1. adj. Dicho de una persona: Que masturba o se masturba."
    Paul Carmichael, Dec 3, 2010
  6. Nige
    Simon Wilson Guest
    Didn't we do this a while ago? Along with the Vauxhall Nova and the
    Toyota MR2?
    Simon Wilson, Dec 3, 2010
  7. Nige
    PacMan Guest
    except the mirror housings. Can't find them in a breakers, and it'll
    set you back best part of £200 for a new nearside door mirror.
    Either that or avoid driving in the early morning in naturally-mamaged
    woodland ...
    PacMan, Dec 3, 2010
  8. Nige
    Paul - xxx Guest
    Heh, get a Disco ...;)
    Friend has an automatic 2000 my Shogun (pukka UK, IYSWIM, not a grey
    import) and swears by it. She is, however unimpressed by power
    delivery and load-carrying ability. She reckons it's under-powered,
    especially if you have the family and luggage to take far. It has,
    however, been extremely reliable, though a new exhaust cost something
    approaching £300, but this was dealer fitted I believe .. ;)
    It has 120k+ on the clock and she reckons it'll easily do the same
    again. They've also had a complete new set of discs in it's time but
    that's normal wear and tear. They use it offroad inasmuch as it's on
    farm tracks to get hay to horses, slowly towing a water bowser (weighs
    3 tons when full) between fields and general household/stable duties.
    She says while it's been reliable for her she wouldn't have another ...
    she doesn't like it, but it's just a feeling, nothing she can quantify.
    Mind, her judgement can be judged when she says her next car will be a
    Mitsibishi/Nissan 'king-cab' pickup ... ;)
    Paul - xxx, Dec 3, 2010
  9. Simon Wilson escribió:
    I think you might be right. Playground "humour" etc.
  10. I'll let you know... the Hilux has been pretty good but spent a cold 30
    minutes changing glow plugs this morning at 6:30AM and it's currently in
    the garage for wheel bearings and brake pads.
    Really went up slippery roads well in 4wd today though.
    stephen.packer, Dec 3, 2010
  11. Nige
    Nige Guest
    The only ones about are so fucked it's untrue!!
    Nige,
    'Candygram for Mongo'
    R1
    Nige, Dec 3, 2010
  12. I'm looking for engine heater options for my SOJC and Tranny. I find
    that even a 60W heater under the bonnet overnight makes a helluva
    difference - there's loadsa space under the battery tray and the bonnet
    is soundproofed, which doubles as very effective heat insulation.
    Having seen the benefits of this meagre 60W for the past several
    mornings [1], I'm definitely going the full way and getting a block or
    circulating heater.
    [1] At -6C I reckon the battery lost at least half of its cranking
    power. With the heater in place, the engine spins like it's autumn.
    Grimly Curmudgeon, Dec 3, 2010
  13. Nige
    Paul - xxx Guest
    Yeah, the cheap ones are anyway! Been looking for a mate, notalot of
    decent stuff about, everyone's hanging on to them, if there's any left!
  14. Nige
    Nige Guest
    Found a lwb Pajero today, good condition, needs a good deep clean, only
    problem was the transfer lever would not budge from 2wd ffs.
    Not great, but possibly worth a punt as it could be a very easy fix, or a
    very fucked box...
    Nige, Dec 3, 2010
  15. So... the noise I put down to the front near side wheel bearing
    seemingly was due to... the near front side wheel bearing.
    The vibration however... was probably due to the fact that the
    propshaft-rear transfer box had 2 of the 4 bolts missing and the other
    two slack and about to fall out.
    Whoops.
    Still fixed now and no one was hurt.
  16. Nige
    Nige Guest
    hehe - went to see a belting looking Pajero lwb today, bodywork stunning,
    interior dirty but cleanable. Took it fo0r a spin, it was bloody bang on,
    until i went to shift it to 4wd....lever totally stuck, not moving jammed.
    I have had hundreds of Land rovers, but these cunts are a bit different, not
    just a sticky lever.
    He wanted £1700, didnt have a clue what he was selling. I walked at this
    point as i need 4wd..
    He rang earlier asking if i wanted it as it was.
    A bit of searching about gives me various options as to what it is.
    He wants £1200
    I bid him £800
    The engine alone would do £300, so if it's a shitter i'll break it.
    Nige, Dec 3, 2010
  17. Nige
    DozynSleepy Guest
    I had a 92 lwb Pajero Exceed with the 2.5 diesel. Would have another
    one again but maybe try the 2.8 . The 2.5 is fine for pottering
    around taking it easy at 50 or 60 mph. Too noisy and strained at
    motorway cruising speeds.
    I had a rocker arm snap which stuffed the engine but since I had
    somehow managed to do 30k miles without an oil change I figured it
    owed me nothing. If going for a 2.5 definitely change the belts.
    DozynSleepy, Dec 4, 2010
  18. Nige
    DozynSleepy Guest
    It's an easy fix. I'll see if I can find the bookmark for it. Check
    the forum on the Pajero owners club.
    http://www.pocuk.com/forums/
    DozynSleepy, Dec 5, 2010
  19. Nige
    Nige Guest
    I did already, bt thats stuck in 4wd, this is stuck in 2wd...
    Nige,
    R1
    Nige, Dec 5, 2010
  20. Nige
    dozynsleepy Guest
    dozynsleepy, Dec 6, 2010
Similar Threads
Loading...
