Show Me, Tell Me lights/indicators
Discussion in 'UK Motorcycles' started by serf, Feb 13, 2004.
  1. serf
    serf Guest
    On the motorcycle practical test, one of the specified questions for 'Show
    Me, Tell Me' is:
    "Show me how you would check that the lights & brake lights and reflectors
    are clean and working."
    The model way of showing this is given as:
    "Operate switch (turn on ignition if necessary), identify reflectors. Check
    visually for cleanliness and operation."
    However, on the CG125 (Makes Sign of Holy Pushrods), the lights and
    indicators operate only when the alternator is running.
    As starting the engine with the bike still on the stand is an instant test
    failure (loss of control), how should I show that they are working
    correctly? As far as I can see, I would have to give a "tell" answer instead
    of a "show" answer. Would this result in being marked down?
    Suggestions to take the test on another bike will be mocked and derided
    copiously. There Is No Other Bike.
    serf, Feb 13, 2004
  2. ****, is it? That's bonkers.
    Can you start the engine whilst astride, then put it on the stand - or is
    that "reckless endangerment"?
    pseudoplatypus, Feb 13, 2004
  3. serf
    serf Guest
    I don't know. I had thought of doing that, but it seems risky. In the
    absense of any clear correct way of answering the question, there
    seems to be a choice between:
    1) physically doing something that the examiner may regard as a loss of
    control and give an instant fail for, or
    2) giving a verbal answer only whilst pointing to bits of the bike, which
    may result in being given a minor fault.
    I would be inclined to choose the latter. Are there any good reasons not to?
    serf, Feb 13, 2004
  4. serf
    flashgorman Guest
    Give him a verbal answer and then offer to get on the bike and start it to
    verify, explaining that you know about the not starting on the stand rule.
    flashgorman, Feb 13, 2004
  5. serf
    Rexx Guest
    Can't you just explain it to him as you have here?
    Rexx, Feb 13, 2004
  6. <snip>
    How about procuring an engineers inspection mirror on an extending handle
    (bit like a car aerial).
    You could then sit on the bike with the engine running, whip out the mirror,
    extend and be able to check all points on the bike.
    Maybe a daft idea, but it is early.
    oldbloke at work, Feb 13, 2004
  7. serf
    Catman Guest
    Thinking back to my test, one of the questions asked was the 'what
    would you do before carrying a pillion'. That was definitely an
    acceptable 'tell me' and I can't see that your lights issue would be
    any different.
    One would also assume that the tester would know enough about bikes to
    know of the 'limitation' of the CG (MSOHP)
    www.cuore-sportivo.co.uk
    Catman, Feb 13, 2004
  8. serf
    Catman Guest
    Didn't say it was hard did I? :)
    IMHO the test is too easy, and I'm surprised I'm still alive.....
  9. Don't be so sure...
    Doesnotcompute, Feb 13, 2004
  10. serf
    Ben Guest
    Sit on the bike with the stand up and start it with your foot on the
    back brake?
    Ben, Feb 13, 2004
  11. serf
    Catman Guest
    Now there's an interesting thought........
  12. serf
    TMack Guest
    Point out to examiner that lights only work with engine running (designed
    that way) and this is how you would check - check lights for cleanliness
    first then get on the bike, start it up, hold it on front brake/footbrake
    and then check front lights and indicators - place your free hand in front
    of headlight if neccessary to check that light (dont forget both main beam
    and dip) is working (reflected light from hand will confirm this). If you
    can see rear indicators then check these visually (if not then see next
    bit) - if anyone else is available (such as the examiner!) you would ask
    them go to rear of bike and tell you if tail light and brake light (and
    indicators if you can't see them) are working OK - tell him that if no
    person is available you would check by backing bike up to nearest object
    (car, wall, shop window etc) and checking reflected light as confirmation of
    functioning.
    Alternatively - mount remote control video camera on rear rack, linked to
    HUD projected onto visor!!!!
    Tony
    TMack, Feb 13, 2004
  13. Why not? Loads of people must do their tests on a CG. The only reason
    I didn't was coz they are too big for me (yes, I know!).
    Motorbike instuctors and examiners are, IMVLE, decent people who want
    to see good biker saget onto the roads and be safe. They're not all
    paper-pushing jobsworths trying to keep us off the roads.
    I think it's like generally in life: don't assume too much
    intelligence, but don't assume lack of intelligence either.
    Power Grainger, Feb 13, 2004
  14. serf
    ....or use a handy reflective surface/shop window to see the red glow
    yellow flashing whilst sat astride. Putting a hand over the headlamp
    shows it working.
    sweller, Feb 13, 2004
  15. serf
    mups Guest
    It certainly needs to be more relevant to modern riding conditions. I would
    suggest the following enhancements to the current test.
    Marks will be deducted for:
    Insufficient use of lanes 1a/2a on dual carriageways.
    Incorrect use of the turning left, turning right and turning nasty signals
    Sticking ones knee out when only 2 degrees from vertical.
    The pulling wheelies/stoppies in an incorrect location [1]
    Extra marks will be awarded for:
    Correct use of the mean and moody biker stare
    Correct observation of fit bored housewives
    Use of wheelies/stoppies to attract said MLIF's
    Any motorcyclist performing a manoeuvre which causes a female's knicker
    elastic to snap at 50 paces will automatically be awarded a full licence.
    [1] I.E. where nobody can see you
    mups, Feb 13, 2004
  16. serf
    *bzzt*
    Marks deducted for use of a Clarksonism on ukrm.
    CT, Feb 13, 2004
  17. serf
    mups Guest
    Guilty as charged m'Lord. However I would like to say in my defence that I
    only took my eyes off the clichometer for a moment and it must have just
    drifted in.
    mups, Feb 13, 2004
  18. serf
    While I know what is meant by MILF, I've never worked out what it
    actually stands for.
    Champ, Feb 13, 2004
  19. serf
    "Mom's I'd Like to ****".
    HTH.
    cf. www.milfhunter.com (s5w2p4)
    darsy, Feb 13, 2004
  20. serf
    mups Guest
    Tsk and you being a man of the world and all that.
    Mothers I'd Like to ****
    www.milfhunters.com (not work safe!)
    mups, Feb 13, 2004
