Shuddery vibrations on a motorbike.
Discussion in 'UK Motorcycles' started by Beav, Jan 19, 2007.
  1. Beav
    I know it's a bit way out in the wilderness but have you checked the
    wheel balance? I've had balance problems that only showed up on
    braking and if you've been painting the wheels they'd have needed
    balancing before re-fitting.
    Andy Bonwick, Jan 20, 2007
  2. Beav
    Beav says...
    Another thing to check, and I have seen this done, is whether you have
    managed to get a disc pad in the wrong way round - that is assuming you
    took the pads out. Matey was wondering why the bike had a brake judder
    and made a funny noise.
    Lozzo, Jan 20, 2007
  3. Truly odd if both discs are the same part number. How's the wear pattern
    on each disc - any difference? There's no vibration before braking?
    Grimly Curmudgeon, Jan 20, 2007
  4. Beav
    As did the EBC discs I fitted to the 9R.
  5. Beav
    Coo, I'm glad I read the thread before replying. I'm of the same
    opinion and I'm pleased there's two of us to look stupid.
    Pip, Jan 20, 2007
  6. Beav
    Bugger.
    Go for a new set of pads then, in extremis.
    Pip, Jan 20, 2007
  7. Beav
    Beav Guest
    I had the wheels balanced before fitting Andy. I had a weight come off a few
    months ago and it was only a farty little one, but the difference it made
    was very noticeable and I didn't want to go to the trouble of fitting the
    wheels only to discover I'd have to remove one (or both) to get a smooth
    vibration free ride.
    Looks like that idea was somewhat flawed.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 20, 2007
  8. Beav
    Beav Guest
    Heh, I usually manage to do that without too much effort.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 20, 2007
  9. Beav
    Beav Guest
    There's very little wear at all, considering the miles the bike has done
    (~12000), but I'm not a heavy user coz it gives me a wife (as opposed to a
    monkey) on my back (and neck and head). Still on its original pads, but what
    wear there is on the discs will be caused by particular pads, so I'll swap
    the discs and hope.
    Course, I'll also make doubly sure I've got both discs seated perfectly
    flat, coz there's **** all like hearing "are the discs sat properly", a few
    times to create a niggle of doubt.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 20, 2007
  10. Beav
    Beav Guest
    I bet mine have too, but I've spent the day today clearing crap I'll never
    use (careful with those thoughts) out the garage and building a nice shiny
    new bike lift and I've not had the opportunity to inspect them.
    An upside to the day though, when I was presented with a 500kg winch from
    SWMBO, so I'll be installing that (and an "I" beam) in the garage tomorrow
    and if I don't solve the bike problem by Monday night, I can use the winch
    to fucking hang myself.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 20, 2007
  11. Beav
    Beav Guest
    message
    I'm all but convinced of it now, particularly after reading what Andy B and
    Champ had to say.
    Y'know, I'm usually a stickler for labelling EVERYTHING because I truly
    fucking hate what's happening now. I can live with cock ups or dodgy parts
    fitted "just to do for now", and I've learned that I'm not clever enough to
    remember where every part on everything I touch has to go, come the time it
    has to go back, so labels and lots of 'em.
    I did things *very* sightly differently this time, in that I half re-built
    everythng as I took it apart. Spacers went back on axles, Cush drive rubbers
    were taped to the sprocket carrier coz they has nipples on them and I KNEW
    I'd get them the wrong way round, chalk arrows on the front wheel showing
    roataion direction. Silly things, but they take the guesswork out. It never
    crossed my mind that the discs would be sided, but even if they're not, they
    still should've gone back on the same side they came off and I'm not sure
    they did.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 20, 2007
  12. Beav
    Beav Guest
    I didn't need to remove the pads Loz, but it's a good thought. Cheers
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 20, 2007
  13. Beav
    Beav Guest
    First thing will be to swap the discs back and give it a try. If it's still
    vibrating, I'll fit new pads for certain.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 20, 2007
  14. Beav
    BGN Guest
    Oh darling it's *all* the rage these days. Everyone's doing it.
    BGN, Jan 20, 2007
  15. Beav
    Happy loctiting, old feller.
    Pip, Jan 21, 2007
  16. Beav
    Ah, there's yer problem you see. It's hardly surprising you've got a
    vibration with a fucking great big Andy fitted to your wheels.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Jan 21, 2007
  17. Beav
    I wasn't even pissed so I can't use that as a reasonable excuse. The
    wheel balance thing is a shit to sort out sometimes, I've had a tyre
    changed and the wheel balanced and then needed to have it balanced
    about 500 miles later because it wasn't right.
    Andy Bonwick, Jan 21, 2007
  18. Beav
    Beav Guest
    I didn't think he was *that* big and he does make me ride faster.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 21, 2007
  19. Beav
    Beav Guest
    Oh BOLLOCKS, now I've ginged myself.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 21, 2007
  20. Beav
    Beav Guest
    Not so happy UN Loctiting though. I made sure there was *just* the right
    amount went on the bolts when I refitted the discs so I suspect a little
    heat will be called for. No oxy-acet, but a plastic welding heat gun thingy
    capable of 800deg C.
    I don't use Loctite on the calipers though, I use an anti-seize compound
    instead. They've never come loose and they're easy to remove next time.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 21, 2007
