No, not the Ducati, the Briggs & Stratton lump in my mower. It's a very simple 4 stroke jobby, but rcently just has no power, won't run properly (slow and laboured). There's no manual throttle on it, it's operated automatically via a sail switch. I had the whole thing apart last night and couldnt find any obvious clues. Cylinder head and valves were a bit black, but even after a good clean up it still won't run right. Petrol is fresh, so it's not that, and carb (such as it is) is clean too. Runs the same with the air filter on or off, so it's not a clogged filter. Apparently good compression (thumb over spark plug hole), and no nasty shards of metal in the oil. Any ideas?
