Sick KLR650
Discussion in 'UK Motorcycles' started by rda, Jul 11, 2005.
  1. rda
    rda Guest
    Ok so I got rid of the blade and bought a KLR on the rebound. 1997 5000
    miles not so bad nick (except previous owner attacked it with spray paint)
    Until today I had only ridden it a couple of times with a max of around 10
    miles.
    I took it into work this morning which is approx 40 miles and on the way in
    it spluttered a few times, just like running out of fuel, only with a full
    tank.
    On the way home things wee much worse; it was farting from the exhaust under
    load and lurching about all over the place. Things seemed to improve on a
    neutral throttle, but the symptoms were still there.
    Once it cut out with the clutch in, but it restarted ok and continued to
    struggle onward.
    Anybody any idea what could be the problem? Even with these symptoms it
    would still accelerate albeit erratically.
    Oh well, so much for *bargain bikes*
    rda, Jul 11, 2005
  2. rda
    TOG Guest
    Sidestand or clutch ignition cut-out? Notorious for giving grief,
    especially on Kawasakis.
    TOG, Jul 11, 2005
  3. rda
    SP Guest
    What's the state of the battery? The battery requires a minimum charge
    to make the bike run properly so it's worth looking at that first.
    Of course, if it is the battery you then have to determine has it just
    failed through age, or was there another reason that caused it's demise?
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Jul 11, 2005
  4. rda
    Blocked breather in the petrol filler cap?
    CT, Jul 11, 2005
  5. rda
    rda Guest
    I thought of that, tried opening the cap and riding off, no improvement.
    I thought it may be overheating, seems a little better when left to cool a
    little.
    Just doesn't *seem* like a dodgy connection, although Ill bypass the
    switches and see how I get on.
    I thought something to do with the fuelling or maybe dodgy spark plug (nice
    and easy to sort).
    Strange thing is it didn't do it last night at all, only after this longer
    ride today :(
    Well I have plenty to be looking at, thanks guys.
    rda, Jul 11, 2005
  6. rda
    BigJ Guest
    Are you sure about this ???
    As long as the alternator is working then that should be enough to run
    the engine without a problem
    The battery is only used for starting the engine and running lights
    etc when the engine is not running
    BigJ, Jul 11, 2005
  7. rda
    SP Guest
    Yes, thanks.
    I had a GPX600R fail on me purely to the fact that the battery was
    unable to hold a decent enough charge.
    I also 'rescued' a broken down Kawasaki owner not so long after with
    the same problem I had experienced, took him to the bike shop to buy a
    new battery and off he went.
    Unless you have a couple of cells that have failed, and the battery is
    unable to hold the required charge to make the bike run?
    Lesley
    CBR600FW
    BONY#54P BOB#18
    SP, Jul 11, 2005
  8. rda
    SP Guest
    If the regulator has a heatsink :eek:)
    <looks sternly at a CBR600 rectifier>
    Alternatively, touch the battery and go <ow, ow> as it is a bit hot ;o)
    Lesley
    CBR600FW
    BONY#54P BOB#18
    SP, Jul 11, 2005
  9. If you have totally failed cells, then the battery doesn't actually make
    any electrical connection across the terminals and then nothing will
    make it go.
    Only time I've known duff batteries bring bikes to a complete halt is if
    there isn't enough juice to power a fuel injection system. Sometimes a
    jump-start is necessary to get bikes running, but once running they
    usually keep doing so.
    The Older Gentleman, Jul 11, 2005
  10. In uk.rec.motorcycles, rda amazed us all with this pearl of wisdom:
    1) Shit in the tank
    2) Shit in the carbs.
    I had exactly the same symptoms as those on a bike I bought recently. A
    good carb clean and a fuel filter has sorted it.
    Whinging Courier, Jul 11, 2005
  11. rda
    Dan L Guest
    The side stand cut out on the Zephyr is very different to the CB500. On
    that, if you were in gear and dropped the stand it cut out. On the Zephyr,
    it sort of stalls if you try to pull away with the stand down. When I got
    the Zephyr I thiught the cut out had been disconnected as it didn't
    immediately kill the engine.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Jul 11, 2005
  12. rda
    Salad Dodger Guest
    That's odd - the TS250 was running quite happily while the battery was
    on the bench charging.
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..75939.../...19198.../..30340.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR Clues: 24 Pts: 400 Miles: 1589
    Salad Dodger, Jul 11, 2005
  13. rda
    Dan L Guest
    That's what I thought, except that when the TS50 lunched it's reg / rec,
    once the (newly charged) battery had shot it's load, the bike just stopped,
    refusing to restart until the battery was recharged.
    Dan L (Oldbloke)
    Dan L, Jul 11, 2005
  14. rda
    Dan L Guest
    Bloody odd
    Dan L (Oldbloke)
    Dan L, Jul 11, 2005
  15. rda
    Steve Parry Guest
    rda fumbled, fiddled and fingered:
    My F650 did that a few months back, as soon as I removed the noddy metal
    shrouded spark plug caps all was normal again.
    Steve Parry
    K100RS SE & F650
    and a 520i SE Touring for comfort [temporarily scarred]
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Jul 11, 2005
  16. rda
    eatmorepies Guest
    This bit could be caused by a very dirty air filter - has it been overfilled
    with oil? If so it will have breathed the extra into the airbox.
    John
    eatmorepies, Jul 11, 2005
  17. Differences in design. The TS might have a separate stator coil for
    ignition only or it might simply have a PM alternator and reg/rec which
    will tolerate batteryless running.
    Grimly Curmudgeon, Jul 11, 2005
  18. rda
    This would make me wary.
    sweller, Jul 11, 2005
  19. rda
    mups Guest
    AOL, anything with a non-standard paint job shouts binned to me and a
    home brew pint job shouts binned and bodged.
    mups, Jul 11, 2005
  20. rda
    Steve Parry Guest
    mups fumbled, fiddled and fingered:
    Aye some of those "home brew pints" are like rats piss ;)
    Steve Parry
    K100RS SE & F650
    Steve Parry, Jul 12, 2005
