Sig change
Discussion in 'UK Motorcycles' started by Adie, Jun 28, 2009.
  1. Adie
    So the sticker that Andy mentioned says 'Castrol Racing 2 Stroke',
    which to me implies the Power 1 Racing 2T, the guy says TTS, & Lozzo
    says it smells like castor based. Confusing!
    I've emailed my New Best Friend[1] (Automotive Oils Technical Advisor
    at Castrol) to see what he reckons.
    [1] MV back brake locked up solid on the way to Avebury due to moisture
    in the fluid expanding when hot[2]. Matey stops to see if I need a
    hand, & gives me a Williams F1/Castrol branded Leatherman to use as I
    didn't have any tools with me. He insisted I keep it, which was a good
    job as it locked again on the way home.
    [2] Lesson learnt - brake fluid doesn't keep even when put in a wine
    bottle & all the air sucked out with one of those vacuum pump things[3].
    [3] Which normally I wouldn't bother doing, but this was SRF which is
    bastard expensive (50 quid a litre).
    Krusty, Jun 29, 2009
  2. Adie
    Who's just replied, saying get some of the oil out, stick it in a glass
    jar, & pour a bit of normal (mineral based) engine oil in. If the 2T's
    castor based, they won't mix & will separate out.
    Also TTS is red & castor based are brown, although it may not be too
    easy to tell the difference if it's old & murky.
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Krusty
    What a nice man!
    But, you ride an MV on public roads and don't carry tools? You mad
    impetuous fool, you.
    go and talk to the Catholics.
    Wicked Uncle Nigel, Jun 29, 2009
  4. Adie
    Champ, Jun 29, 2009
  5. Adie
    There were many, many, many at Cassington. I think you may have been
    overcome with emotion.
  6. Adie
    Two strokes, or Kawasaki two-stroke triples?
    I might have coped with the former. Probably not with the latter.
    Champ, Jun 29, 2009
  7. Adie
    Both I'm afraid. 250, 380, 750 triples, LCs, 250D, even a fizzie! Plus
    loads of other old Jap stuff, several Vincents, plenty more old Brit
    stuff, Harley flat-tracker etc etc.
  8. Adie
    That's Tyga bodywork, from Thailand, not Japan.
    http://tyga-performance.com/site/index.php?cPath=73_498
    I was tempted to do something similar to mine but most CBA. It does look
    nice but the original tank is retained and the old-fashioned shape kinda
    clashes with the curves of the aftermarket bits.
    ogden, Jun 30, 2009
  9. Something blocked in the MC then, or perhaps it doesn't even have an
    expansion orifice.
    Grimly Curmudgeon, Jun 30, 2009
  10. Adie
    No, once a year, last Monday in June.
    Krusty, Jun 30, 2009
  11. Adie
    The prices on the web site look great but they're direct prices from
    Thailand and don't include shipping or import duty. The prices from the
    UK importer are about double and then you need to factor in the work
    required to fit it, let alone having it painted up properly.
    I'll be keeping mine standard for the forseeable.
    ogden, Jun 30, 2009
  12. Adie
    Adie Guest
    which we've now done. The old stuff was clear and very thick.
    The TTS is indeed reddy/brown and is now settled on top of the clear
    stuff but not gone gloopy.
    Adie
    UKRM FAQ: http://www.ukrm.info/faq/
    YZF-R1 : FZ1N : RD350LC
    (anyone would think I was partial to Yamahas)
    keeper of the FAQ for my sins
    MRO#11 BOTAFOF#7 BOTAFOT#130 DIAABTCOD#17 MIB#24 YTC#16
    BOB#15 ex-UKRMMA#22 BOMB#11
    Adie, Jul 4, 2009
  13. Adie
    Clear & thick 2 stroke oil? Hmmm. At the risk of getting a slap, you
    did take it from the 2T tank & not the gearbox, didn't you...
    Did you mix it up or just pour it onto the old stuff?
    Krusty, Jul 4, 2009
  14. Adie
    Adie Guest
    Andy can give you that slap. yes it came out of the take that said
    "two stroke oil". when I say clear it was baby oil non coloured.
    mixed it up and left it. its now been drained and is full of TTS.
    Adie
    Adie, Jul 4, 2009
  15. Adie
    No, I took it out of the petrol tank.
    Mixed it up thoroughly and then it separated so the old stuff was at
    the bottom within 5 minutes.
    I've drained it all and then kicked it over until new oil came out of
    the pump so the pump's primed ok but I'll let Adie do a couple of
    hundred miles before I have a go on it.
    I reckon it'll be ok but it'll be fingers crossed and hovering over
    the clutch for a while.
    Andy Bonwick, Jul 4, 2009
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, Adie
    Hmm...
    Adie and "baby oil" in the same thread.
    Excuse me, I just want a few moments...
    Wicked Uncle Nigel, Jul 4, 2009
