Sig Change
Discussion in 'UK Motorcycles' started by 'Hog, Sep 6, 2005.
  1. 'Hog
    'Hog says...
    They are 65mm and won't fit straight on, but the better 4 pot Tokico
    TL1000S ones will. They make those in 65 and 90 mm spacing, be sure to
    get the right ones. Don't bother with Tokico 6 pots, they are shite.
    Lozzo, Sep 6, 2005
  2. 'Hog
    'Hog Guest
    Well I agree but I have them so....
    Do you think the 9R and the Gixxer 6 pots will be effectively the
    same?
    'Hog
    'Hog, Sep 6, 2005
  3. 'Hog
    Bear says...
    The ZX-9R front end is perfect, the Bandit is weighty enough to make it
    work. An R1 front would be too soft and too short to do it properly. The
    caliper mounts make for a greater choice of brakes too.
    Lozzo, Sep 6, 2005
  4. 'Hog
    Bear says...
    Which part of "standard motorcycle" don't you understand?
    Lozzo, Sep 6, 2005
  5. 'Hog
    'Hog says...
    Pretty much, yes.
    Lozzo, Sep 6, 2005
  6. 'Hog
    'Hog Guest
    <sets eBay search to AP>
    'Hog
    'Hog, Sep 6, 2005
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    <raises eyebrow>
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Sep 6, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    Disagree. I love the "WTF's holding that *on*?" look from the RHS.
    And I have *exquisite* taste in motorcycles as a quick glance at my .sig
    will confirm.
  9. 'Hog wrote
    Absolutely.
    steve auvache
    750 VT Shadow (something for the weekend)
    Bindit 600 (was lost and now is found)
    GS500E (small but perfectly formed)
    mongvan (dehydrated)
    steve auvache, Sep 6, 2005
  10. 'Hog
    Bear says...
    It's a nice and compliant, well damped and fully adjustable upside-down
    front end with capacity for stonking brakes to be fitted straight on.
    They look really good and they work well on heavier bikes. Perfect for a
    Streetfighter.
    They're not the same as the forks on your old 9R, this is from the
    previous model. It's always been reputed to have been better but dropped
    from the 9R for reasons of cost.
    Lozzo, Sep 6, 2005
  11. 'Hog wrote
    Kinnel, just as well you weren't giving it full beans then.
    steve auvache
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    <raises other eyebrow>
    <flicks vees at Kiran>
  13. 'Hog
    Christofire Guest
    'Hog wrote:
    [B12 + stuff]
    Indeedy. It's suitably "look at me", but not over top "OI!" on the
    noise front. Well done with it - it's a nice bike and no mistake.
    Christofire, Sep 6, 2005
  14. 'Hog
    Eddie Guest
    The B's had USDs? Why did they go back to non-USDs for later models, then?
    FWIW, I think the non-USD forks on my 9R give me more feedback than the
    USDs that were on the Falco, which were meant to be very good indeed.
    Eddie, Sep 6, 2005
  15. 'Hog
    Eddie says...
    Cost more than anything else.
    All depends on the bike and the forks. Stuff like Paoli or Marzocchi
    suspension is notoriously hard as standard, yet Showa is usually quite
    soft.
    Lozzo, Sep 6, 2005
  16. 'Hog
    AndrewR Guest
    "YOU'VE HIT A CAR ... you daft fucker!".
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1, Fiat Coupe 20v Turbo
    The speccy Geordie twat.
    AndrewR, Sep 6, 2005
  17. 'Hog
    Eddie Guest
    They were all talkative during the "you're braking too hard, you're
    losing grip" stage, but went strangely quiet after that. Incommunicative
    Italian shite, obviously.
    Eddie, Sep 6, 2005
  18. 'Hog
    Eddie Guest
    I've gathered that.
    Well, yes. The main problem on Falcos is the extremely cheap and nasty
    rear shock, which is never going to help you get the best out of
    whatever's fitted at the pointy end.
    <fx: blank look>
    So, what's a ZX-9R E2 fitted with, then?
    Eddie, Sep 6, 2005
  19. 'Hog
    Eddie says...
    I thought Aprilia used Sachs shocks.
    Kayaba, aka KYB IIRC. They seem to make most Kawasaki suspension.
    Lozzo, Sep 6, 2005
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    #My Lord, Kayaba,
    #Oh Lord, Kayabaaaa....
