Sig change.
Discussion in 'UK Motorcycles' started by steve auvache, Feb 25, 2006.
  1. Blue it is, so it is dog slow but some minor fettling and it should be a
    half way decent little bike.
  2. the man with no idea wrote
    What is wrong with it, I may have cheap spares?
    Oh c'mon, as machines go they don't get much more basic and still have
    two cylinders.
  3. the man with no idea wrote
    Fine by me. Try steve at
  4. the man with no idea wrote
    It shouldn't make it that bad surely?
    Further back in time than my newsbase holds posts.
    This one I have just bought has had a restrictor fitted and from what
    the seller told me bits of it may/may not have been removed by him when
    he did a carb overhaul. He certainly didn't set them up right and if
    what I have got is not out of tune but just sort of restricted a bit
    then 70 is probably slow even for a headwind. How much do you weigh?
    Let off the front preload then.
  5. steve auvache wrote
    More news...
    I just had a look at the certificate of restriction which was in the
    little pile of provenance and section 2 paragraph 4c suggests it should
    be good for 91mph.
    steve auvache, Feb 26, 2006
  6. the man with no idea wrote
    Intuition suggests that things should be made mushier but sods law says
    the opposite may be true, it needs winding both ways to find out.
    Implying then that it is road speed associated and not engine revs?
  7. In uk.rec.motorcycles, the man with no idea belched forth and ejected
    the following:
    The thing I've found with Haynes manuals, or any kind of "instruction"
    manual for that matter, is not to use the bloody thing at all unless you
    really need it. If you start to tackle a job without it, you'll be in a
    better position to see what's what when you do pick it up.
    There's yer problem, see.
    Put the book down and just look at the bracket.
    Can you see what needs to be done?
    Try changing the bracket without the manual, you'll feel better for it,
    too.
    Good man.
    Get a load of cable ties in, too.
    You won't regret it.
    Whinging Courier, Feb 26, 2006
  8. In uk.rec.motorcycles, the man with no idea belched forth and ejected
    the following:
    I fixed a RHS footpeg using nothing more than a piece of copper tube
    with a hole banged in it. It even passed an MOT.
  9. steve auvache
    I think you need a pair of scissors to help you to snip posts first
    .... here's a pair and a couple of spares for later:
    8< 8< 8<
    Pip, Feb 26, 2006
  10. steve auvache
    JackH Guest
    My ex Barry Richards one was.
    Improved a fair bit simply by having the valve clearances done, and the
    carbs cleaned and balanced.
    Was still a disappointment though - sold it and got a CBR600. Mucho
    betterer...
    JackH, Feb 27, 2006
  11. JackH wrote
    Mine sound fine and have a history of dealer service but will get
    checked.
    On the list. I have got to source half a dozen bits for it and get in
    there and get it done[1]. I am hoping for warm and sunny next week.
    Yes, another 10 horses would be nice but the trade off is in size,
    weight and bullet proofing and that would spoil it.
    Up to 90 it will probably see off anything on four wheels so any gap I
    might desperately need is mine for the taking and as long as it does
    that sort of thing I don't mind the lack of the rest, too much.
    [1] Anybody have any knowledge of paddock stands for these little
    beasties?
    steve auvache, Feb 27, 2006
  12. steve auvache
    JackH Guest
    Erm, it was about another 40 horses, IIRC... reliably obtained ones, too.
    I've got a rusty old homemade jobbie that Timo gave me with the TZR250 I had
    off him, ages ago.
    A quick lick of paint, and it'll be fine for something like that, given it's
    the same sort of physical size.
    Yours for nothing if you want it.
    JackH, Feb 28, 2006
  13. JackH wrote
    Mine then.
    Let the underground railway roll.
    steve auvache, Feb 28, 2006
  14. steve auvache
    flash Guest
    If someone can get it to Halifax, I could take it across to Blackpool.
    flash, Feb 28, 2006
  15. steve auvache
    I can do the Enfield -> The City leg.
    darsy, Feb 28, 2006
  16. darsy wrote
    I can collect from either.
  17. steve auvache
    flash Guest
    Maybe an old tramp steamer[1] out of the city and along the coast to
    tyneside then?
    [1] Seems appropriate for some reaon
    flash, Feb 28, 2006
  18. steve auvache
    I've been invited onto the "Oriana", but that's not until November.
    darsy, Feb 28, 2006
  19. Maybe an old tramp steamer[1] out of the city and along the coast to
    tyneside then?[/QUOTE]
    We need the Captain of the "Greasy Bastard".
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
    Grimly Curmudgeon, Feb 28, 2006
  20. steve auvache
    JackH Guest
    Except it hasn't really, has it.
    Hmm... I've got to pick something up from the Hertford area in the next week
    or so - will let you know when I'm likely to be going that way, and can drop
    it in on my way past if you still want it.
    I've even got an unused tin of silver hammerite type paint you can have with
    it.
    JackH, Mar 19, 2006
