Sign change
Discussion in 'UK Motorcycles' started by The Older Gentleman, Sep 23, 2006.
  1. Yup. Hairdryer time, methinks.
    Checking completed auctions on Fleabay, I see a one-owner Trophy (item
    270028734517 - same year as mine, only 3500 mileage, and in much better
    nick than mine), made £2800, so mine probably wasn't even as much as my
    low estimate.
    So on that basis, I'm happy with the deal.
    I pick it up on Friday and I'm around next weekend, if you're anywhere
    in the vicinity.
    The Older Gentleman, Sep 24, 2006
  2. The Older Gentleman
    The Older Gentleman wrote:
    I was planning to drop the RX off for a service and some other work on
    Saturday if the guys can fit me in so I'll be driving past your gaff on
    the way home.
    BTW, have you heard anything from Champ or Owen regarding the "exhaust
    tag team"?
    Timo Geusch, Sep 24, 2006
  3. The exhaust was dropped off by Champ on Saturday, and fitted by yours
    truly today. The Z definitely sounds (and goes) much better. I also
    fitted the new rear mudguard.
    Next task - the head races, a new front tyre, and a pair of decent
    shocks.
  4. The Older Gentleman
    OK, fair enough. I guess they were probably afraid to have me come to
    close to their bikes :).
    Not as much work as the Morini, eh?
  5. Hmf. Rather more, actually.
    Especially as when I'd fitted the rear guard, the brake light stopped
    working. Turned out there was a previous-owner electrical bodge for it
    that chose that moment to go on trike.
    Tell you what, though: this is now one bloody nice Z650, both
    cosmetically and mechanically.
    <nonchalant whistle>
    How's the Motosport?
  6. The Older Gentleman
    It's grown another wheel, too?
    It seems to be the day for 'leccy bodges - I just discovered that the
    gel battery on the chop had *exploded*. No, really.
    Anyway, what's the bodge?
    Which is more than you could say for the Morini. I guess you'd have to
    invest the same amount of work and *then* fork out for a paint job.
    It's a runner. That is, if you kick the living daylights out of the
    fucker for about 30 minutes, it'll run for about 30seconds. Which is a
    marked improvement over the other one with a decent engine because you
    have to kick that even longer.
    Anyway, I played with it a tad more and the fuel tap bowl was full of
    crusty shite. Traced that a bit further and it looks like the float
    needle sticks in the closed position randomly. I guess the vibration
    frees it off again and the bowl fills, so it keeps running...
    I *bet* that that's one of the problems with the other Motosport as
    well as both can be kicked over at full choke until you're red in the
    face and still show a dry plug.
    The bastards.
  7. Oh, I suspect that the fuse holder for the brake light fuse broke, so he
    ran the wires outside the fuse box, and added a wire running directly
    from the front brake light switch. That and the connection from the rear
    switch meet in a junction box.
    It all works.
    The problem was he used those crappy bullet connectors and they weren't
    secure and well, you can guess.
    Probably. I'm still torn between keeping the Z and selling it. It's a
    lovely bike to ride, which is in its favour, and I reckon that with the
    replacement exhaust, it's worth about £1600, which is slightly less than
    it's cost me.
    Buy an XT and smile.
  8. The Older Gentleman
    Oh yes :-/.
    And you didn't write about it a lot in Classic Bike either, I noticed.
    To make up the shortfall, like.
    You mean, because I've got it going after hopping up and down on the
    kickstart for two days solid?
    Just to confirm that I'm not completely useless with a kickstart I
    fired up the Triumph today, partially for a pre-MOT test (which it
    failed) and to confirm if it was running rich or not.
    It is. Mainly because one of the POs fitted Japanese switchgear with an
    integrated choke lever. And the lever doesn't have enough travel to
    lift the choke on Amal up all the way.
    Oh well, remember that Motosport which came with a "choke lever off
    some old Britbike" (your words)? Turned out to be a perfect fit, that
    one.
  9. <VBG>
  10. The Older Gentleman
    Donald Guest
    Welcome to the dark side.
    Donald, Sep 25, 2006
  11. The Older Gentleman
    deadmail Guest
    Hahaha... BMW, "dark side".
    deadmail, Sep 25, 2006
  12. Heh. Well, I've owned Beemers before. What I intend to do is maybe chip
    it, and see what can be done about the handling. ISTR that Hog's went
    round corners amazingly well for such a lardy old bus. Suggestions?
    The Older Gentleman, Sep 25, 2006
  13. The Older Gentleman
    Adie Guest
    On Mon, 25 Sep 2006 19:05:58 +0100,
    sell it and buy something that does.
    Adie
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280031578936
    Triumph ZX9R / GSF1200 bandit (for sale) / CG125
    keeper of the FAQ for my sins
    Adie, Sep 25, 2006
  14. Hmf. Got one of those already.
  15. The Older Gentleman
    2 up on the IOM the left hand rocker cover and the OE pannier were
    grinding away nicely
    Hog, Sep 25, 2006
  16. The Older Gentleman
    Ohlins or Fournales rear shock, possibly Progressive fork springs. TBH
    I wouldn't necessarily chip it as most chips seem to work on the
    premise that dumping huge amounts of fuel into the engine does more
    than increase bore wear.
    There's some info about tuning them on the ibmwr site, IIRC.
    Timo Geusch, Sep 25, 2006
  17. The Older Gentleman
    Ah I'm just catching up with the full thread. I was referring to the
    R100RS at the IOM.
    Sooo TOG has himself an LT. Woo Hoo. Great bikes, just one thing spoils
    them (for me), they need another gear or top gear 15% higher. When
    Ultimate Source were still around they did supply a cog conversion. TOG
    OTOH might be happier cruising a little slower.
    Mine did have an Ohlins with the hydraulic preload adjustment.
    Progressive fork springs. New head bearings. Make sure the 'arm bearings
    are right. Careful tyre choice. Bob's your cross dressing Auntie. IMHO
    most of the mid corner weaving is down to small inputs through the
    tiller like bars. Reducing the play in the rubber mounts at the top yoke
    helps. There was some info on ibmwr about this too.
    Once again I found that EBC HH pads worked. With new goodridge hoses it
    turned good brakes into eyeball poppers.
    All you need now are some proper lights :eek:)
    http://www.photobox.co.uk/album/52643
    Hog, Sep 25, 2006
  18. I've just dug out an old BIKE roadtest, comparing the Pan, R1100RT,
    K1100LT and (surprise!) the 1200 Trophy.
    The R1100RT was rated the best, closely followed by the Pan. The K was
    the most economical, and superbly comfy, but its handling was a bit,
    erm, soggy.
    The Trophy had a stormingly torquey engine and was built as well as the
    BMW, but did just 31mpg....
    I'm not expecting sports bike handling, but like I said, I've got a
    Ducati for that.
  19. Does anyone else do one?
    Yeah, right.
  20. The Older Gentleman
    Nope. Bonners reckoned they could be made but the amount of hassle
    involved closed my decision to sell it.
    <tickles line>
    Hog, Sep 25, 2006
