Single bearing crankshaft?
Discussion in 'Australian Motorcycles' started by Theo Bekkers, Sep 19, 2003.
  1. Theo Bekkers
    Theo Bekkers Guest
    I've been looking at two-stroke powered whipper-snippers lately and
    was told not to buy the cheaper 'domestic' versions as they have a
    single bearing crankshaft. i.e. a bearing on one end of the crankshaft
    only. I never heard of such a thing. I spent the extra $50 and bought
    the two-bearing model.
    Anybody tell me how a motor with only one bearing on the crank stays
    together or am I misunderstanding what three different people are
    telling me?
    Theo
  2. Theo Bekkers
    Stevo Guest
    Can't believe the crankshaft wouldn't be supported at both ends.. *gasp*
    But maybe just a simple bush/sleeve bearing? whereas the other end (the
    'drive' end) might have a roller/tapered roller...
    Stevo, Sep 19, 2003
  3. If I hadn't thrown out the "what ever the brand was" stroker
    whipper-snipper, I'd send it to you.
    I'm sure you've got enough rubbish about your place, I know I had!
    Hammo
    Hamish Alker-Jones, Sep 19, 2003
  4. Theo Bekkers
    Theo Bekkers Guest
    "Stevo" wrote
    *gasp*
    Me either.
    Like a '50's BSA or Triumph twin?
    Theo
  5. Theo Bekkers
    Stevo Guest
    *pass*
    but I am also astounded.. how the hell do they seal the cranckcase to make
    it work??
    Stevo, Sep 19, 2003
  6. Theo Bekkers
    Stevo Guest
    Yep, they ran plain bushes.. most serious owners replaced them with
    rollers.. plenty of kits available.. did wonders for the oil pressure I
    seem to recall, particularly over a reasonable distance..
    Stevo, Sep 19, 2003
  7. Theo Bekkers
    Theo Bekkers Guest
    "Stevo" wrote
    They blocked off the oil feed on the left side bearing? I thought
    (long time since I looked at one) that that feed also went to the
    camshaft bushes.
    Theo
  8. Theo Bekkers
    Theo Bekkers Guest
    "Theo Bekkers" wrote
    Better make that right side.
  9. Theo Bekkers
    CrazyCam Guest
    Theo Bekkers wrote:
    No thanks....I _gotta_ get a better offer than that! ;-)
    regards,
    CrazyCam
    CrazyCam, Sep 19, 2003
  10. Theo Bekkers
    Stevo Guest
    Yes, I think that was the case, fitting the roller bearing outer race
    blocked off the opening I think, providing more flow to the top end.. but
    on the A10's at least, it was possible to provide a passage from the relief
    side of the oil relief valve to the new roller (a drilling, in the right
    place) so that once the oil got to the max pressure (50 PSI?) the bearing
    was first to get a squirt.. otherwise it just relied on oil splash..
    Stevo, Sep 19, 2003
  11. Theo Bekkers
    RM Guest
    I have a perfectly good 2 stroke whipper snipper that i f#*ked the carby on,
    as the needle had seized and i tried to pull it out but it broke...
    so if anyones got a whipper snipper carby that is just lying around
    cluttering up the shed, i would take it off your hands <<< wonders how many
    whipper snipper carbys there would have to be to create an appreciable
    'clutter'
    HEY THEO watch out for carby needle seizure in your new machine...I usually
    run the lawn mower carb empty to avoid having this happen, if i ever get the
    whipper snipper going, or get another, i'll fit a fuel tap so i can do the
    same
    Someone let Theo Bekkers at loose on an internet
    connection and the result was:
    RM, Sep 19, 2003
  12. Theo Bekkers
    Theo Bekkers Guest
    I have an old two-stroke whipper snipper that I haven't been able to
    start for years. Forget the brand. The new one is a Stihl. The old one
    is still.
    Warranty, dealer.
    Theo
  13. Theo Bekkers
    Nathan Smith Guest
    The other side has a seal but no bearing (?)
    Two seals and one bearing!
    Sounds like a good joke. "there was these two seals and bearing walk into a
    bar. Boom Tish."
    Nathan
    Nathan Smith, Sep 19, 2003
  14. Theo Bekkers
    sharkey Guest
    building materials: "bearing seat", "getting my bearings",
    "your round!", "you look like you've been blown by a penguin"
    -----sharks
    sharkey, Sep 19, 2003
  15. Theo Bekkers
    Stevo Guest
    There may be bolts holding it together.. but a 2 stroke crankcase needs a
    gas tight seal to work properly doesn't it?.. at least a whipper snippre
    doesn't have a gearbox to scavenge oil from..
    Stevo, Sep 19, 2003
  16. Like I was telling Theo, I chucked all that stuff. Had a small collection
    of carbies for small stroker engines. Not much use telling you that, but
    its always the way, as soon as you chuck it, it comes in handy....
    Hammo
  17. On 19/9/03 11:36 PM, in article
    What about where the cam chain goes. Its runs off the same bearing!
  18. Theo Bekkers
    Theo Bekkers Guest
    "Rex Turner wrote
    Find some tall grass and push-start it.
    Theo
    Theo Bekkers, Sep 21, 2003
  19. Theo Bekkers
    Rex Turner Guest
    About the only way I believe - you see most motors of this type have an
    output shaft one side (for the cutting disk etc and on the other side is
    mounted the Fan and the Starter (either Cord or Impulse).
    In quite a few years of engineering/repair of most types of motors I can say
    the only single sided cranks were in model aircraft motors. So if this
    particular motor is also a single sided crank, I'd be interested to see it.
    RexT.
    Rex Turner, Sep 21, 2003
  20. Theo Bekkers
    Theo Bekkers Guest
    "Rex Turner wrote
    see it.
    Rex, I started this thread because of a whipper snipper. The Stihl
    dealer told me the difference between two models was that one had a
    bearing on one end of the crankshaft and the other one at each end.
    They both had pull-starts. I didn't ask how the single-bearing model
    worked. I bought the other.
    Theo
    Theo Bekkers, Sep 22, 2003
