Single Carb !!
Discussion in 'Motorcycle Technical Discussion' started by Bantam, Jan 18, 2004.
  1. Bantam
    Bantam Guest
    Is there any good reason why, for a non-sportsbike, you couldn't have a
    branched inlet manifold and just one large carburettor?
    Anyone done this?
    I was wondering about the XS.
  2. Years ago, SU Carburettors offered just such a conversion for the old
    Bonneville and Commando twins.
    Worked very well - improved starting, virtually no less of performance
    and better economy.
    On a four-cylinder bike, making up the three-into-one manifold would be
    tricky, and finding the space for a single (large) carb might also be
    difficult, but there's no reason why not.
    I suppose you'd lose some top end performance, probably gain mid-range,
    and yes, improve economy. I've never seen it done, though.
    The Older Gentleman, Jan 18, 2004
  3. How do cars do it? Or "did" would be better, seeing as all cars are FI
    these days. I mean, cars managed happily for decades with (often) only
    one carb.....
    That's right, except that the carbs were twin-choke.
    The Suzuki GSX550/750 did the same thing, with a pair of twin-choke
    carbs, IIRC.
  4. Bantam
    Les Guest
    Triumph used single and dual carbs for different models, no reason why
    others can't do the same. I know a guy that modified the manifold for his
    Honda Goldwing and is running an Edelbrock 4 bbl carb. Bike starts and runs
    good and sounds great with the straight pipes he made. It hesitates a bit
    when he kicks in the 4 bbls though.
    Les
    Les, Jan 18, 2004
  5. Bantam
    Mark Olson Guest
    Don't forget the GR650 Tempter, which also used a siamese carb.
    Mark Olson, Jan 18, 2004
  6. Did it now? Cor, I rode one of those in, er, um, 1982 in Sweden and
    never noticed. Horrible bike, mind.
  7. Bantam
    Mark Olson Guest
    Mea Culpa. I just looked at http://www.partsfish.com and it appears to
    have used two conventional carbs.
    I could have sworn Suzuki used one of those siamese carb thingys on a
    twin, perhaps I misremember it from looking at the GSX550.
  8. Bantam
    bowman Guest
    Both of my bikes and the pickup have one carb apiece. Of course, one of the
    bikes only has one cylinder, while the other has two.
    Having spent part of my youth listening to several little SU's each humming
    their own tune, one carb is fine by me.
    bowman, Jan 18, 2004
  9. Bantam
    Bantam Guest
    I'm expecting some carbs to arrive shortly for the XS but should
    anything go amiss then I have been considering making up a three into
    one manifold and using an SU carb and flat chrome filter.
    I was just curious whether there was any damn good reason not to do
    this.
    Many Thanks
    Should I have to give it a go then I'll get back with the result.
  10. Bantam
    bowman Guest
    Ah, one of those technical types! All I ever had was a piece of vacuum hose
    to listen to the whistle of each carb. Just like tuning a guitar. A twelve
    string with a badly warped neck.
    bowman, Jan 19, 2004
  11. Bantam
    Bantam Guest
    And you want to throw away 50 years of carburetor development and go backwards
    Well em, NO, not really.
    I suppose I just thought the SU was simple enough to start with for such
    a project and as some of the Minis used twin SUs it would be possible to
    get the delivery requirements fairly close.
    I'd much prefer the proper carbs (and I may still end up fitting them)
    but they are hard to find at the moment.
    Anyway, very interesting reading.
    Bantam, Jan 19, 2004
  12. I suppose I just thought the SU was simple enough to start with for such
    SU carb is indeed very simple and reliable. The Minis which used pairs of
    them used the small ones, 1-1/4 inch usually, and the perceived wisdom on
    tunng the 'A'series engine is that twin carbs is a needless complication and
    to use a single bigger one instead. On a 1275cc Mini this would be a single
    1-3/4 inch item and the hot 1000cc Mini engine which I built used a single
    1-1/2 inch carb.
    SteveM
    Stephen Malbon, Jan 20, 2004
  13. Problem with SU carbs is getting a lean cruising mixture and a rich power
    There are also various different springs available to use above the piston,
    I believe that there are also different grades of the damper rod that screw
    into the top of the "bell" and which goes into the oil-filled cylindrical
    extension of the top of the piston. There are, of course, literally hundreds
    of different needles available.
    I have to admit to liking SU carbs having been brought up on various British
    cars that used 'em. That said I'd much rather have fuel-injection.
    SteveM
    Stephen Malbon, Jan 21, 2004
