Single or twin disks?
Discussion in 'Classic Motorcycles' started by Guest, Apr 11, 2009.
  1. Guest
    Guest Guest
    My R80 RT monolever has a single front disk. It never has stopped on a
    sixpence exactly, and I've always wondered about a twin disks, pretty
    much a bolt-on conversion for these.
    I've just seen the bits on fleabay, so thought I might ask what the team
    thinks: which is better - more force onto a single disk with less
    unsprung weight and less gyroscopic force, or a bigger (and better
    balanced) braking area?
    If I did it, I assume the back drum shouldn't need changing, coz that
    would be rather awkward (presumably a new bevel box at least if it's
    very different).
    Are there any other factors I should consider?
    Guest, Apr 11, 2009
  2. A single disc will always try and twist the forks when it's applied,
    whereas twin discs don't. That's a factor in twin discs' favour.
    The unsprung weight is an issue, but plenty of Beemers run twin front
    discs with no problems and if you want the ultimate in handling, you
    won't be buying an old R80 anyway.
    No need to change the rear drum at all, no. I'm assuming that all the
    conversion bits come with the larger master cylinder that you'll also
    need, by the way.
    The Older Gentleman, Apr 11, 2009
  3. Guest
    Guest Guest
    Good points, many thanks.
    They were selling the callipers and pipework together, but the master
    cylinder was separate. It might be an expensive operation yet.
    I'll give it more thought, as I'm used to the bike's 'little quirks' and
    cash is always good (in _my_ pocket, that is :) ).
    Cheers,
    S.
    Guest, Apr 11, 2009
