Sintered pads?
Discussion in 'UK Motorcycles' started by cat, Nov 27, 2008.
  1. cat
    cat Guest
    Now, these pads don't have anything on them about flow rate or anything
    like that, so I'm lost.
    Are sintered pads just better, or do they have to match the disc?
    cat.
    cat, Nov 27, 2008
  2. cat
    Flow rate? What? Are you drunk?
    No.
    Champ, Nov 27, 2008
  3. cat
    Just go to your local bike shop and say "Can I have some brake pads for
    an ER5 please."
    You may want to insert the word "sintered" between the words "some" and
    "brake" if you
    a) want to spend a bit more money, and
    b) want to stop a bit better which may be of some use as you're in
    London and there'll be a lot of fuckwits on the road.
    CT, Nov 27, 2008
  4. cat
    JackH Guest
    c) replace the discs on a more regular basis due to the higher wear rate on
    these compared to conventional pads.
    Metal on metal, innit.
    JackH
    98 Honda VFR800FiW
    03 VW Passat TDI Sport (resting)
    89 Vauxhall Nova 1.3 Pearl (for sale)
    00 Peugeot 306 HDI Meridian
    JackH, Nov 27, 2008
  5. cat
    No, just being deliberately 'stupid'.
    Pip, Nov 27, 2008
  6. cat
    cat Guest
    I'm just ashamed that my bike failed on obvious stuff.
    The horn's fucking loud now though :eek:D
    *wanders off to get bits posted next day*
    cat, Nov 27, 2008
  7. cat
    eviljonny Guest
    Aww the little toot was part of the charm!
    eviljonny, Nov 27, 2008
  8. cat
    zymurgy Guest
    I was interested by the wear on the freelander discs.
    The pads are virtually new (about 10mm of pad left) but they'd buried
    themselves into the disc to the tune of several mm on both sides.
    Either the pads are made of carborundum, or the discs were soft. I'll
    keep a closer eye on it now ...
    P.
    zymurgy, Nov 27, 2008
  9. cat
    What do they make EBC Pro-Lite discs out of then? My old 9R has done
    30k miles on one set of Pro-Lites and always has sintered pads fitted.
    Andy Bonwick, Nov 27, 2008
  10. cat
    JackH wrote:
    It's a Kawasaki, they've all had sintered pads fitted as standard since
    the early 80s.
    Lozzo, Nov 27, 2008
  11. cat
    JackH Guest
    http://www.sportbikesolutions.com/sintered_vs_organic.htm
    JackH
    98 Honda VFR800FiW
    JackH, Nov 27, 2008
  12. cat
    Everyday I learn something new and interesting. Today I've learned
    that those nice rusty discs on the 9R should have warped, worn wafer
    thin and been scored to **** by my obsession with using sintered pads.
    Actually I'm being a **** here because the bike always has EBC HH pads
    fitted and works well with them but that's because they're designed to
    be used on Pro-Lite discs.
  13. cat
    Corrodium, if my experience was anything to go by.
    Pip Luscher, Nov 27, 2008
  14. cat
    zymurgy Guest
    My 12R has stinky organics in the back and sintered on the front, for
    obvious reasons :)
    P.
  15. cat
    It's the copper content in the pads that causes the high wear rate on
    the disk apparently...
    Muck, Nov 27, 2008
  16. cat
    All depends on make of disc and material. Certain discs are made to
    suit certain pads, as Andy B has discovered. Kawasaki's standard discs
    are fine with sintered pads, as that's what they leave the factory
    with. A good replacement sintered pad is the Vesrah JL range because
    Vesrah make 90% of Japanese factory fitted pads.
    Lozzo, Nov 28, 2008
  17. cat
    zymurgy Guest
    Thank you Mr Murray.
    P.
    zymurgy, Nov 28, 2008
  18. cat
    True... it's a mine field and it depends on disk material. I was
    generalizing about folk that find their disk wear has gone up.
    Muck, Nov 28, 2008
  19. cat
    JackH Guest
    Strange... only you'd think if that was the case then 'Copper Slip' ought to
    be made with something other than copper, really.
    JackH
    98 Honda VFR800FiW
    JackH, Nov 28, 2008
  20. cat
    Would you? You know, just occasionally I credit you with a modicum of
    know-how, although I'm not sure why. Glad that you pop up with posts
    like this often enough to dissuade me from that line of thinking.
    And I've just realised that my kf reverted to an old version when this
    machine was rebuilt last week.
    Ace, Nov 28, 2008
