Skidding
Discussion in 'UK Motorcycles' started by BGN, Oct 14, 2005.
  1. BGN
    BGN Guest
    Hello all.
    That horrid cold wet and windy time of the year is back again, leaves
    falling from trees, mud in the road and all that nice stuff.
    This will be my first biking winter, and even though I did all of my
    training when it was snowing earlier on this year that was all on a
    rather upright 125.
    This morning I was chuffing along on my way to work on the A20 (my
    preferred crashing spot for cars and bikes alike) and on a very modest
    curve in the road the bike did a wee skid. I noticed there was mud in
    the road, but there wasn't much but the leaves gave it a bit of back
    up.
    It felt like the rear moved to the left and the bike wobbled in a
    generally unstable fashion, I reduced the throttle a bit (but still
    gave it a small amount of power) then kicked it up a gear and carried
    on to work in an uneventful fashion.
    Apart from leaving the bike at home and taking a car to work, what is
    the best thing to do when unintentional skidding or sliding takes
    place. Reduce throttle, leave it the same? In addition to going more
    slowing would putting the bike in a higher gear reduce the risk of
    skidding?
    Thanks.
    BGN, Oct 14, 2005
  2. BGN
    YTC449 Guest
    Hello all.
    1 Countersteer
    2 Pile on the power
    3 Stick boot down on the side lowest to ground
    4 Powerslide around the corner like a Stadium rider on 2 wheels and a leg
    5 stop at next services for pants change
    I don't intend or ever want to try it but it does look good on Speedway
    Robbo
    Trophy 1200 1998
    BotaFOF #19. E.O.S.M 2001/2002/2003/2004/2005
    B.O.S.M 2003, 2004, 2005
    FURSWB#1 KotL..YTC449
    PM#7
    YTC449, Oct 14, 2005
  3. BGN
    BGN emerged from their own little world to say
    Plan A:
    Observation is key.
    Go slower so you see the hazard AND have time to react appropriately.
    Plan B
    Go much faster. The likelihood of suffering pain when you crash is
    minimised.
    wessie, Oct 14, 2005
  4. BGN
    PDannyD Guest
    On Friday 14 October 2005 17:28, BGN() wrote in
    Relax.
    PDannyD, Oct 14, 2005
  5. BGN
    JackH Guest
    Learn to be less hamfisted, in a nutshell.
    I tend to automatically drop into a smoother style of riding, when the roads
    are wet / covered in mud / I spot rather more gravel mid bend, than I'd
    prefer.
    And as for leaving it in a higher gear, that's a definite no - when you're
    in a lower gear, you'll get more engine braking - this helps in two ways:
    * Any braking you then do with the back brake, has more engine force to
    overcome, before it can lock the back wheel up.
    * It's a more gentle way of scrubbing off speed in some ways, than prodding
    furiously at the brakes.
    Others may disagree - I *personally*, have managed to avoid lobbing it big
    style in the wet since my formative, riding mopeds and 125s, years, so read
    into that, what you will. ;-)
    Try and keep it sunny side up for more than a few days, eh. :)
    JackH, Oct 14, 2005
  6. In uk.rec.motorcycles, BGN amazed us all with this pearl of wisdom:
    IME doing nothing has saved me from binning it. You could try sticking
    your leg out or put your foot on the ground (which saved me once) but I
    only really notice it after it's happened.
    Whinging Courier, Oct 14, 2005
  7. BGN
    Wik Guest
    Leave the throttle alone works best for me; don't open it, don't close
    it, just leave it where it is. Unless you get really unlucky and
    encounter several yards of muck and shite (or diesel...) then these
    sorts of moments are usually over before the brain has an opportunity to
    do anything about it, anyway.
    Of course, if we're talking really lurid, arse-end waaay out of line
    with the front-type skids then gas it, 'cause it's 50/50 you're going to
    come off anyway.
    And having the front skidding as well is usually a trip to A&E unless
    you're Nicky Hayden or Valentino Rossi. I've only had this happen twice,
    both times on the BMW on 020's when I was pushing a little harder than
    perhaps I ought. It was a little, um, disconcerting but it stayed put
    and just meant my exit line was about a foot further out than I'd
    intended. Fortunately, both times was over here and on right-handers.
    Wik, Oct 14, 2005
  8. BGN
    I fail to see how using engine braking prevents the rear wheel locking
    up.
    Pip, Oct 14, 2005
  9. BGN
    Dan L Guest
    Don't do it.
    When you wanna come....
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Oct 14, 2005
  10. BGN
    BGN Guest
    IIRC from my car driving lessons I was advised to start off in a high
    gear if the road was likely to help with skidding. For example
    starting off in 2nd gear instead of 1st. I normally do 30mph in 2nd
    gear on the bike, but it certainly doesn't mind doing it in 3rd gear.
    On a slippery surface could skidding/loss of rear traction be caused
    by going in 2nd gear as there's more torque than in 3rd? Or would the
    benefits of engine braking over sticking on the normal brakes in this
    situation outweigh any advantages?
    Perhaps I'm over thinking this again.
    BGN, Oct 14, 2005
  11. BGN
    You're prolly not, but you are using a poor comparator.
    Using a higher gear for the same road speed in order to reduce rpm and
    therefore the quantity of torque applied to the driving wheel(s) works
    for a car, but on a bike may cause a stall and then over you go.
    Personally I have always practiced progressive throttle control and in
    the winter my entire throttle use becomes very delicate and only
    extends to about half of the available travel. So much so, that I
    realise Summer has arrived when I rediscover the other half of the
    throttle. I would never advocate use of a higher gear, preferring to
    retain control under my right hand (or foot) rather than the
    ever-clumsy left foot.
    Be gentle with the controls, relax and remain ever-watchful for
    treacherous surfaces and the natural traps - under trees lurk wet
    leaves, damp patches or even algal slime/moss - and in Winter frost
    patches that the sun never gets to.
    Pip, Oct 14, 2005
  12. BGN
    BGN says...
    My Gixer Thou will happily pull away smoothly from 30mph in 5th. A
    smaller bike should be able to do this quite happily too. There's no
    need to be in as low a gear as 2nd at 30mph.
    Lozzo
    Track pixie
    GSX-R1000 K1
    ZX-7R
    GPZ500S
    Lozzo, Oct 14, 2005
  13. BGN
    BGN Guest
    It'll quite happily do it, but I always seem to keep the revs up.
    Dunno why, I did it on my Cat-A test and the examiner didn't care. I'm
    not sure if it's a good or a bad thing.
    BGN, Oct 14, 2005
  14. BGN
    Being in too tall a gear will mean you've got the throttle a bit too wide
    open. This won't be a problem until you lose traction, and the back wheel
    spins up...
    platypus, Oct 14, 2005
  15. BGN
    antonye Guest
    Most people come off because they instinctively shut the
    throttle. This loads the front as the weight dives forward
    and can cause the front to lose traction as it can't handle
    putting 100% of the traction through the front tyre.
    Keep on a positive throttle and ride it out. The rear will
    grip as it clears whatever caused the slide and you'll
    still be going in the right direction. Not panicing is
    the best way to go.
    Wet road surfaces are not inherantly slippery, and it takes
    quite a bit of throttle chopping to get it to break traction
    in a messy way. Be smooth and you'll be fine.
    antonye, Oct 14, 2005
  16. BGN
    Stuart Gray Guest
    whipping the clutch in and throttle on tick over has helped me out off road
    a few times, and on road where the surface was pretty porridge. Feel where
    the bike wants to go and feed in power where it needs it. I never had to put
    a foot on the floor, I reckon that upsets the balance and it looks naff,
    just like the guys who accelerate from the lights with feet dangling for
    half a mile.
    Stuart Gray, Oct 14, 2005
  17. wessie wrote
    Ho yuss. Be observant, put a trauma nurse on the dole.
    That and relax.
    steve auvache, Oct 14, 2005
  18. BGN
    JackH Guest
    If you're running with a shut throttle, from higher revs, the braking effect
    is better than that, if you were in a higher gear - the engine is thus,
    providing more resistance to the momentum you have, and you slow down
    quicker.
    Now... if you then brake hard up to a certain level of applied force, the
    engine braking will assist in slowing you down quicker - go past this point,
    and within reason, the flywheel effect of the engine will then be greater
    than it would be if revving lower, in a higher gear - net result is, unless
    you really take the piss, the rear wheel locks up less easily due to
    excessively applied braking, because of the greater resistance the engine
    giving.
    It's not a rule as such, and this is where having half a clue on how to read
    the road and conditions unfolding out in front of you reasonably well, comes
    in...
    JackH, Oct 15, 2005
  19. BGN
    JackH emerged from their own little world to say
    I've read this twice. I'm sure you know what you mean but it is meaningless
    gibberish.
    We've covered this already.
    wessie, Oct 15, 2005
  20. BGN
    JackH Guest
    There's an 'is' missing, just before the 'giving' right at the end. ;-)
    JackH, Oct 15, 2005
Similar Threads
Loading...
