Slow-action throttle?
Discussion in 'UK Motorcycles' started by Eddie, Feb 5, 2009.
  1. Eddie
    Eddie Guest
    The Monster's throttle has quite a short action, which is fine if you're
    confident and used to riding powerful-ish bikes.
    However, if you're someone who's a bit out of practice, and was only
    used to riding a lardy old 600 anyway, you might find it to be a bit
    sensitive.
    I know there are plenty of aftermarket "fast-action" throttles
    available, but does anybody sell "slow-action" throttles?
    Eddie, Feb 5, 2009
  2. Eddie
    Just spray some furniture polish on the seat. She'll learn to cope.
    platypus, Feb 5, 2009
  3. Eddie
    SD Guest
    Paging Spete.
    SD, Feb 5, 2009
  4. Eddie
    Eddie Guest
    Yeah, but will I learn to live with the black eye that I'd get shortly
    afterwards?
    Eddie, Feb 5, 2009
  5. All depends on the setup - is it a conventional cable operating a lever
    or something similar? It would be perfectly possible to use an older
    throttle assy and fiddle with the leverage at the client end.
    Grimly Curmudgeon, Feb 5, 2009
  6. Eddie
    Eddie Guest
    Interesting, ta. I'll look into it.
    Eddie, Feb 5, 2009
  7. Standard fitment on any BMW, ITYF.
    The Older Gentleman, Feb 5, 2009
  8. Eddie
    Eddie Guest
    It's FI; the "business" end has a cam of its own, IIRC.
    Eddie, Feb 5, 2009
  9. Eddie
    Jérémy Guest
    That's nice to know. I thought you all must have double-jointed wrists.
    Jérémy, Feb 5, 2009
  10. In that case...
    You can fiddle with cam ratios; if there's a suitable cam available that
    will fit the FI spindle (or however it's held on). If it's a pot, it
    might have a protruding standard shaft.
    A quick-action bar end will be married to a q/a FI end, so I doubt you'd
    be able to do much with the existing bar end throttle, as it's basically
    not got enough travel.
    What you have to do is go up in size, both at the bar end and at the FI
    end, to slow the throttle action.
  11. Eddie
    Eddie Guest
    Smaller at the bar end, or bigger at the throttle body end, surely?
    Eddie, Feb 5, 2009
  12. Eddie
    antonye Guest
    There are different tubes available which should replace the
    existing one - basically a larger diameter on the cable end
    which means that for the same degree of rotation it will
    pull more cable. So you want a smaller diameter one.
    Or check out the different types of throttle assembly. I'm
    guessing that as the S4R is the 996 engine it will use the
    same throttle as that (the 748/916/996/998 set) ? Maybe
    one from an SSie would be a better throttle as I'm sure
    these are different.
    I know that the old carby throttle assembly has a lot
    slower action than the FI assembly as I bodged my original
    carby one on the race SS when we fitted the FI engine.
    I swapped to a proper FI assembly which I bought new from
    Red Racing for less than second hand on ebay AND you got
    new OEM grips with it!
    See: http://tinyurl.com/9rpwe
    #352003 (second down on right) is the OEM 916 assembly
    which runs at 65deg to WO
    #357203 (third down on right) is the OEM carb assembly
    which runs at 94deg to WO
    antonye, Feb 5, 2009
  13. Eddie
    antonye Guest
    I don't think they are removeable/replaceable though.
  14. Eddie
    antonye Guest
    Forgot to add; I think I still have the old carby
    one in a box somewhere if you want it FOC to try
    and fit it.
  15. Well, it depends how much travel there is available on the existing bar
    end pulley. Disconnect it and see - if only a part of it is being used,
    then fine, you can keep it. But I was thinking you'd probably have to go
    bigger at the bar end and then choose a pulley for the FI end that would
    be bigger than original anyway - but quite what that size would be I
    don't know.
    I suspect the original bar end pulley will run out of movement before a
    bigger pulley on the FI end is fully open. Bicbw.
  16. That buggers that, then.
    Smaller diameter pulley on the bar end, then.
  17. Eddie
    Eddie Guest
    I didn't think they would be, and I didn't really want to have to fiddle
    around with that end of things.
    Eddie, Feb 5, 2009
  18. Eddie
    Eddie Guest
    Exactly what I was thinking.
    Ah, useful. All the required details, and the prices aren't bad at all!
    Eddie, Feb 5, 2009
  19. Eddie
    Eddie Guest
    Yes, please! That's a twin cable throttle, isn't it? I can just ignore
    the "closing" side.
    <emailed>
    Eddie, Feb 5, 2009
  20. Eddie
    Eddie Guest
    .... or not:
    <>... Deferred: Connection timed out with dev.null.
    Your three-letter nickname at your surname .co.uk?
    Eddie, Feb 6, 2009
