Slow punctures
Discussion in 'UK Motorcycles' started by HooDooWitch, Sep 23, 2005.
  1. HooDooWitch
    HooDooWitch Guest
    I've got a slow puncture on the front tyre which drops from 34psi to
    around 26psi over 2 weeks. I've looked for knicks and nails but other
    than the usual wear & tear (on a 3k mile tyre) I can't see any likely
    pucture marks.
    Before I go and empty a can of tyre-weld into it, is there anything
    else that others have tried (and hopefully succeeded with) to stop
    slow punctures?
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, HooDooWitch
    Check the valve. Put a blob of spit on it and see if it blows a bubble.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Sep 23, 2005
  3. HooDooWitch wrote
    Check the valve with a little bit of fairy liquid.
    Take the wheel out, pump it up *lotz* and submerge the fucker in a
    container of water and look for the bubbles.
    Take it to a man to get it fixed proper.
    steve auvache, Sep 23, 2005
  4. HooDooWitch
    Eddie Guest
    Ultraseal was praised by our friendly local mechanic.
    Tyre-weld is meant as a "get you home" measure, whereas Ultraseal is
    designed to be left in permanently.
    Eddie, Sep 23, 2005
  5. HooDooWitch
    zymurgy Guest
    Not a bad idea, the 12R has 17 PSI in the front everytime I come to
    ride it.
    Quite disconcerting ..
    Paul.
    zymurgy, Sep 23, 2005
  6. HooDooWitch
    TOG Guest
    With that really slow kind of leak, checking for a bubble on the valve
    probably won't work. Replace the valve core.
    TOG, Sep 23, 2005
  7. HooDooWitch
    flash Guest
    Try letting the back tyre down by a similar amount to compensate.
    flash, Sep 23, 2005
  8. <strikes Zymurgy off the 'handy, bike-fettling blokes to know' list>
    Beelzebub@Work, Sep 23, 2005
  9. HooDooWitch
    HooDooWitch Guest
    Noted, ta.
  10. Tubeless? Probably imperfect sealing at the rim.
    Grimly Curmudgeon, Sep 23, 2005
  11. HooDooWitch
    HooDooWitch Guest
    Noted.
    It could be the valve as I usually have to bend the fucker to get
    around the front disks with the usual inflators you find at garages.
    Might be worth investing in a decent foot pump, or trying to be less
    ham-fisted.
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, HooDooWitch
    You can get a nice little 90 degree bend that screws on to the existing
    valve stem when you want to use a garage air line.
  13. HooDooWitch wrote
    Unless you are a fat ****, DO NOT buy one of them double barrelled ones.
    Always treat your motorcycle as you would treat your woman.
  14. HooDooWitch
    Eddie Guest
    Instead of going around the front disks, try going through the disk
    carrier instead - sometimes makes life easier.
    Get a compressor; you'll wonder how you ever lived without one.
    Eddie, Sep 23, 2005
  15. HooDooWitch
    HooDooWitch Guest
    Good point, once every two weeks even you'll be able to get on ...
  16. HooDooWitch
    HooDooWitch Guest
    <fx: checks pocket money>
  17. HooDooWitch
    HooDooWitch Guest
    In my skydiving days it was commented that I fell faster than a brick.
    I might manage a triple.
    Well, Sarah's expecting our second child *today* so perhaps I'll find
    a mini-moto in the garage when I get home. ;)
  18. HooDooWitch
    Catman Guest
    Is that the pink one? I've got some of that in the back of the Triple cos I
    thought I had some steel in it. Turns out that they were not very deep at
    all.
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 156 TS S2
    www.cuore-sportivo.co.uk
    Catman, Sep 23, 2005
  19. HooDooWitch
    TMack Guest
    Well my bike is fucked so I seem to have got that right.
    Tony
    TMack, Sep 23, 2005
  20. HooDooWitch
    Lady Nina Guest
    Blimey, that was quick. Best of luck with it.
    Lady Nina, Sep 23, 2005
