Small Engine Tune-Up - What have I done?
Discussion in 'Motorcycle Technical Discussion' started by Fred McKenzie, Jul 14, 2006.
  1. Sorry if this is off-topic.
    A 2500 Watt 120V generator (Powermate Proforce PM0102500) seems to
    be working fine, but engine sounds a little rough. Why not touch up the
    carburetor adjustment and see if that improves it?
    First I turned the screw on the carburetor to the right. Some resistance
    to turning, but absolutely no difference in engine speed or sound.
    Then I turned the screw to the left. Screw is quite loose and still no
    difference in the engine, but now I have gas leaking from the bottom of
    the carburetor! I turned the screw to the right until snug, and the gas
    leak has stopped.
    There is no other adjustment visible on this carburetor. Is that screw
    intended to drain the carburetor, or have I seriously messed up something?
    The owners manual is no help. I searched the web for data, and only found
    that the 5.5 HP engine was made by "Sumec". I gather that they make
    motorcycle engines, but found no carburetor data.
    Fred
  2. *Sigh*
    The Older Gentleman, Jul 14, 2006
  3. Mark-
    Very interesting article. It reminds me of the Till Eulenspiegel story.
    'The name "Eulenspiegel" literally means "owl mirror," and may refer to
    the proverb: "Man sees his own faults as little as a monkey or an owl
    recognizes his ugliness in looking into a mirror."'
    Fred
    Fred McKenzie, Jul 15, 2006
