Personally, I'd go for a good quality posidriver. Maybe going up one size and gently tapping it home so there's little chance of it slipping out (f'narr). I'd REALLY hesitate to use an impact driver on something made of zinc and knob cheese. -- Beav VN 750 Zed 1000 OMF# 19
Only if you count north west Leicestershire as the north. My old Vintage racing mate always used the term. Thrutch = torque. -- +----------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster [ SPACE ! ] Yamaha WR250Z | | Gilera GFR * 2 Moto Morini 2C/375 Morini 350 "Forgotten Error" | +----------------------------------------------------------------+
I have no plaster cast but have been on anti-biotics for a week, up until yesterday. Tonight I will be quite happy if I end up throwing beer & curry all over myself. In fact, it's a goal.
Or climbing. Using brute force instead of technique is sometimes referred to as thrutching (or thugging) your way over a move/up a route.
I learnt it from my mentor as an apprentice mechanic. I reckon he could be described as a vintage northern pervert, so pretty much all the boxes appear to have been ticked. Paul.
Well of course pozidrive screw heads are a different profile from phillips - maybe that is the idea though? I was horrified to notice recently that phillips head screws are *designed* to limit the torque transmitted from the driver to the screw. The idea is to prevent damage from ham-fisted operators during assembly. Of course this turns out to mean that they are also *designed* not to come undone with normal screwdrivers after they have been installed for a while. You need something to hold the driver in while the rotational force is applied or to use some other method to "persuade" it to release http://en.wikipedia.org/wiki/Henry_F._Phillips "The design was purposely made to cam out" # # # Coefficient of expansion of various metals http://metals.about.com/gi/dynamic/...yharmancanada.com/TheBrazingBook/comparis.htm Range Zinc & its Alloys 19.3 10.8 Aluminum & its Alloys 13.7 11.7 Alloy Steels 8.6 6.3 See the article if you care about the units. It is certainly the case that alluminium alloys have a usefully higher coefficient of expansion than steel with respect to releasing stuck stuff. Zinc alloys seem to have an even larger coefficiant of expansion and so the effect should be greater. Even boiling water will have an effect. Don't get scalded.
Don't know about northern, but it's a common enough word usually used to describe a hard time on the bog. -- Beav VN 750 Zed 1000 OMF# 19
True enough, but they're interchangeable for the majority of jobs and a Posidriver used on a Philips screw wn't hurt either the driver or the screw. For tightening yes, not for undoing. Nope. the shape of the screw slot is "one way" and will "allow" the driver to come free of the screw without damaging it, but it does nothing to stop HUGE amounts of torque being applied in reverse. Like an impact driver? Wike again, so it must be true. And it is, partially. I'm not bothering to read what's in that link, but I suggest you try to discover what the term "cam out" means and then apply it to what happens when the force is reversed. -- Beav VN 750 Zed 1000 OMF# 19
Commonly used as a verb by climbers, meaning the technique which involves jamming as much of your body as will go into a crack, then squirming in a (hopefully) upward direction. Climbing walls don't generally have this kind of move, so it might be becoming a bit obsolete.
Exactly, however the OP has described that he is reluctant to bash his carburettor wiv a big hammer. Hmmm. Are you saying that the phillips screw/screwdriver is not symmetric? They sure look symmetric. They also very frequently fail to remove screws that have been installed for a while. My current view is that phillips head screws are simply not designed to be removed for maintenance without recourse to an impact driver or similar. If it happens that an impact driver is not conveniently deployable in any paricular situation then it appears that the manufacturers view is - that's your problem matey. While I am not presently involved in professional vehicle maintance I do have substantial experiance that supports the described view.
As well he should be, but I was being just a little facetious. Nothing's perfect, but you can apply more torque anti-clock than you can in the clockwise. They don't cam out by design when undoing. Your view is wrong then. Why would they think anything esle though? Ok, you win. And it's "experience" -- Beav VN 750 Zed 1000 OMF# 19
I don't think this is true. Float bowls are invariably held on with Phillips screws and I've never had to use an impact driver to remove them. Sometimes, when they've been severely stuck, I've had to grip the head in a pair of Mole grips to turn it (as you suggested), but that's very rare. Phillips scres on engine cases etc often need an impact driver because they're in an exposed position to cop all the water and road crap, whereas those used elsewhere aren't.
