Smog Advice
Discussion in 'Bay Area Bikers' started by John Beck, Sep 5, 2003.
  1. John Beck
    John Beck Guest
    I know this is not motorcycle related but neither is Gray Davis ...
    I have a `88 pickup truck which needs a smog check (at a Test Only
    Station) by November. It passed smog 2 yr ago - but not by much. It
    has 270K miles on the engine (well, it was rebuilt 80K ago) so it's not
    worth putting much money into it. What servicing would you recommend
    before the smog test. So far I plan to:
    1 replace Sparkplugs
    2 replace Airfilter
    3 change Oil (put in 20W50)
    4 adjust the idle (last smog test it was mediocre at low rpms, but
    was fine at high rpms)
    Any other suggestions?
  2. Few tanks of high quality gas, perhaps?
    Nicholas C. Weaver, Sep 5, 2003
  3. John Beck
    JB Guest
    You mean Chevron/Union as opposed to Arco ... Union has alcohol instead
    of MTBE in it's gas -- would that be better for a smog test?
    JB, Sep 6, 2003
  4. John Beck
    Alan Moore Guest
    On Fri, 5 Sep 2003 22:35:07 +0000 (UTC),
    Check your fuel filter. If there's a way to drain a bit of gas from
    the very bottom of the tank, do it -- water and other crud tend to
    collect there. Then, with all other maintenance tasks done, take it
    out on the freeway -- preferably a fast stretch.
    Al Moore
    Alan Moore, Sep 6, 2003
  5. John Beck
    NorCalIC Guest
    What make of pickup is it? Domestic, import?
    I've got an '88 Nissan (120K) and it passed CA smog no sweat. Until
    this year. After everyone put in their two cents worth I finally
    figured out that I needed to make sure that FI's mixture was set
    properly. The tech doing the smog had messed with it thinking it was
    the idle adjuster. It was way off map when I set it back to where it
    was supposed to be. After that, passed OK.
    NorCalIC
    NorCalIC, Sep 6, 2003
