Snotoilers
Discussion in 'UK Motorcycles' started by steve auvache, Sep 27, 2005.
  1. Were one to be considering buying one, one may be inclined, nay drawn
    even, by the idea if one can afford the extra investment one should
    purchase the touring kit. However one wonders if those with appropriate
    experience or prejudice might inform one of the advantages if any of not
    doing so? With special attention paid to the general lack of touring
    that one is hoping not to do on an item of chain driven discerning
    gentlemen's personal transport.
  2. steve auvache
    Advantages - you don't have to fill up as often (duh!), & you don't
    have to find somewhere to strap the standard reservoir.
    Disadvantages - it'll make the mudguard rub the wheel if you've got a
    VFR VTEC.
    Krusty, Sep 27, 2005
  3. Krusty wrote
    How often is often?
    I don't think I'll have a problem particularly with the GS, there is
    loads of space all over the place.
  4. steve auvache
    I don't know tbh, not being one of those people who keeps records of
    such things. I just know it's much less often since fitting the touring
    kit - once or twice a year.
    The VTEC is the only bike I've heard of that has that problem. Tigers
    also have an issue in that the touring reservoir pushes the number
    plate back to the point where it's no longer illuminated - but I don't
    gaf about that.
  5. steve auvache
    It attaches to the side of the touring reservoir, behind the number
    plate...
    ....but possibly not if you do that.
  6. Krusty wrote
    I note from their web site that they now offer a device called a 'Lube
    Tube' which might make a suitable halfway solution.
  7. steve auvache
    Spike Guest
    Had the standard one under the seat for a long while, but then went and
    bought the touring reservoir...
    The standard I had to re-fill about every 150-200 miles, depending on how
    warm it was... reservoir, a couple of times a year.
    I bought the dual injector kit at the same time. Seems to work well... 35K
    on the chain and still going strong...
    Spike, Sep 27, 2005
  8. steve auvache
    Eddie Guest
    How often?! FFS, I'd have to refill it twice a week most of the time.
    Let me guess: your back wheel was covered in oil as well, wasn't it?
    Don't you think you should have turned it down a tad?
    I'm fairly sure I used to get ~1000 miles out of a fill when I had one.
    Eddie, Sep 27, 2005
  9. steve auvache
    Did anyone say you did? Sheesh!
  10. wessie wrote
    I have best part of a gallon of chain oil in(underneath) the shed..
    *boggle*
    Ye jest Shirley?
  11. steve auvache
    I keep meaning to try veg oil in my Snotter - less polluting, and should
    clean the back end up - veg oil should dissolve the old clagged-on dino crap
    out of the chain guard etc.
    platypus, Sep 27, 2005
  12. steve auvache
    FFS.
    I mean, I've always thought snotters were a waste of time, but if you
    have to refill the fucker _more_ often than you'd normally lube the
    chain, there must be something wrong with the adjustment. Shirley?
    Or a 'normal' attitude thereto. I don't consider it 'laissez faire'
    that I only kick the chain and tyres every few hundred km and oil it
    every couple of thousand (unless it's _really_ got soaked, when I
    might do it twice in that period). Anything more frequent than that
    belongs back in the 1970s when a) bikes _needed_ regular fettling to
    keep running and b) shop services were things only the rich gits[1]
    did.
    [1] And, of course, c) I wasn't one of them.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Sep 27, 2005
  13. steve auvache
    Ginge Guest
    Mine is set very low, so the chain is just dripped on occasionally,
    which is all I think is needed.
    It didn't quite empty out over 1500 miles.
    Ginge, Sep 27, 2005
  14. steve auvache
    Tosspot Guest
    With the touring tank around 10K between fills.
    Tosspot, Sep 27, 2005
  15. steve auvache
    Spike Guest
    Not *covered*... just litely speckled :)
    My chain *is* very clean though, and as I say, its done 34 thousand odd
    miles, and I just dont even bother checking it these days, as I have to
    adjust it about once a year, at most... so I spose its doing its job :)
    Spike, Sep 27, 2005
  16. steve auvache
    serf Guest
    Mine is about the same.
    serf, Sep 27, 2005
  17. steve auvache
    steve auvache says...
    Speak fucking English, man.
    Lozzo, Sep 27, 2005
  18. steve auvache
    I have fitted one of these to my Gixer because I don't have a rear
    mudguard to mount a touring kit to. It works well.
    Lozzo, Sep 27, 2005
  19. Lozzo wrote
    Where have you put it?
  20. steve auvache
    Ah, but doesn't it also lube the outer rollers?
    Pip Luscher, Sep 27, 2005
Similar Threads
Loading...
