SO Boxer Rear Shocks
Discussion in 'Classic Motorcycles' started by SteveH, Sep 13, 2009.
  1. SteveH
    SteveH Guest
    After a spirited ride today, taking in the Epynt mountain [1], I have
    decided that the rear shock has pretty much had it.
    What's the recommendation for replacement? - they appear to be a bit
    'how fscking much?!', but are cheaper from German eBay sellers.
    [1] http://www.italiancar.co.uk/epynt.jpg - we were above the clouds up
    there, so had a chilly drop down towards Llandrindod Wells.
  2. SteveH
    Hagon are usually pretty decent.
    Timo Geusch, Sep 13, 2009
  3. SteveH
    SteveH Guest
    They should be, at £275.
    This appears to be what costs £275 in the UK, but a lot cheaper.
    http://search.ebay.com/270349341703
    (Sadly my German never really progressed beyond GCSE level plus a bit
    picked up from colleagues at Tchibo)
  4. SteveH
    Those are for a twin shock one - wasn't yours a mono?
    And yes, a quick skim of the ad suggests that they're indeed flogging
    Hagons. Price is for the basic bog standard version for the twin shock.
    They don't really mention anything about the monos.
  5. SteveH
    SteveH Guest
    Doh! Yes - it's in the title.
    They really should show a pic of a pair!
    Monos are 'HFM!?', as they are in the UK.
  6. All monoshocks are an arm and a leg, though.
    Do Quadrant Dynamics still exist?
    Austin Shackles, Sep 13, 2009
  7. SteveH
    SteveH Guest
    Do I need to replace the spring, or is just a damper likely to fix
    things? - only an OEM damper can be had for about £100 less than a
    complete shock / spring assembly.
  8. Chuck it at Maxton for a complete overhaul. Only £100-odd.
    The Older Gentleman, Sep 14, 2009
  9. SteveH
    I'd ask Maxton how much for them to make a replacement Steve. But I
    think it is going to be £400
    The OEM dampers for the mono models are affordable at £155. I expect
    your spring is a bit tired though.
    The Hagon unit is priced to be exactly the same as a complete OEM Boge
    unit!
    Of course you REALLY want a 46PRC Ohlins at £557
    Hog, Sep 14, 2009
  10. SteveH
    Guest Guest
    Right. I've got a Koni, which is superb. They stopped making them for a
    while, but I've seen new monolever shocks on eBay recently, that look to
    be a similar pattern, so someone may be.
    Try the usual suspects: Sherlocks, Motobins Motorwerks (sp?). There are
    so many out there, I can't believe there aren't any to be had for
    200-250 (about what mine cost some years back). The Koni transformed the
    handling too - dosh well spent, IMHO.
    Guest, Sep 15, 2009
  11. Ikon
    IIRC, the company bought the tooling etc, but isn't allowed to call them
    Koni, so they just made an anagram of the name.
    The Older Gentleman, Sep 15, 2009
  12. SteveH
    Guest Guest
    I forgot to mention: I was told years ago that the OEM units (BMW ones)
    die after standing for a while (seals or whatever), and they aren't
    fully serviceable, unlike twin shock ones.
    I've seen a few NOS BMW ones come up on eBay recently. Wouldn't go near
    them with a 20ft pole...
    Cheers,
    S.
    PS: If this is an old wives' tale, I'd love to know.
    Guest, Sep 16, 2009
  13. SteveH
    Guest Guest
    Thankyou!
    I think I ought to eat more carrots or whatever - memory almost, er ...
    Guest, Sep 16, 2009
  14. SteveH
    SteveH Guest
    SteveH, Sep 16, 2009
  15. SteveH
    I must admit I find Monoshock prices a bit eye watering too but I guess
    it is what the market will stand. And funnily enough a Progressive
    Suspension unit seems to be the same as the Hagon, same as the OEM.
    Then you have Maxton, Technoflex and Ohlins above £400
    Hog, Sep 16, 2009
  16. SteveH
    SteveH Guest
    Progressive appear to only sell via Chromosexual dealers in Europe.
    I'll probably end up forking out for a Hagon or Ikon.
  17. SteveH
    Then as if by magic
    www.motorcycle-spares.com/betor-monoshocks-c-126.html
    £185
    plus my commission
    Hog, Sep 16, 2009
  18. SteveH
    SteveH Guest
