SOB: Sticky Starter
Discussion in 'UK Motorcycles' started by rufty_tufty_hoolythug, May 27, 2010.
  1. FZ600 1987. The one with the XJ engine. Starter had been turning
    bike over fine but now will turn engine for a two or three turns and
    then stick. REPEAT Into gear, shuffle back and forwards UNTIL starter
    turns long enough to start bike. As you cn imagine, it's a bit
    annoying.
    So, advice please. Is this a sticky or knackered starter? Could the
    starter clutch be at fault?
  2. rufty_tufty_hoolythug
    crn Guest
    Is there any oil in the gearbox ?
    Could be knackered bearings in the bendix gear / starter clutch or in
    the starter motor itself.
    The only way to find out is to pull it out and have a perkle.
    crn, May 27, 2010
  3. If it's just the starter then that will be easy enough to remove and
    get reconditioned or replaced. Looking at the manual, messing about
    with the starter clutch didn't fill me with joy.
  4. rufty_tufty_hoolythug
    TOG@Toil Guest
    Sounds like a duff starter motor. Doubt it's the clutch, if it's not
    making any horrible noises. Another used starter motor shouldn't be
    hard to find, anyway. If that doesn't fix it, then it'll be the
    clutch. Good luck with that.
    TOG@Toil, May 27, 2010
  5. rufty_tufty_hoolythug
    TOG@Toil Guest
    FZ600s don't have separate gearboxes. If there's no oil in the
    gearbox, there's none in the engine and a duff starter motor is the
    least of his worries.
  6. rufty_tufty_hoolythug
    LOL! I did wonder about that, especially given the poster.
    He really takes this "giving technical advice on subjects you know
    absolutely nothing about" to a new level, doesn't he?
    Ace, May 27, 2010
  7. rufty_tufty_hoolythug
    crn Guest
    Have you ever heard of the phrase "Generic answer" YTC.
    Read what I wrote - the idea of "Bendix gear or starter clutch" should
    be a clue that the answer was NOT intended to be model specific.
    Bloody furriners mumblemuttermumble
    crn, May 27, 2010
