SPECS..
Discussion in 'UK Motorcycles' started by Steve Parry, Jun 5, 2008.
  1. Steve Parry
    Beav Guest
    I think you'd somehow have to "flag" yourself and seeing as the camera's
    don't see you if you change lanes, why would they want to keep a picture of
    you and send a man out to identify you?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 7, 2008
  2. Steve Parry
    frag Guest
    Doing 120 in a 50 limit would do this quite nicely I'd have thought.
    Don't rely on that.
    Each camera can optically cover "x" metres width of road.
    When they set them up they tell the computer where the lanes are -
    think of someone virtually drawing the lane dividers on the video image.
    This is purely so the computer can 'tag' the photo with the lane number.
    There's normally 1 camera with 2 IR lamps either side of it at each
    checkpoint, 2 of these for > 3 lanes (it seems to be).
    Car goes past first post (in any lane, the computer doesn't care),
    computer recognises movement, categorises it (size of vehicle - helps
    to cut down the areas of moving image to scan for number plate sized
    areas), finds plate, does OCR, saves image + reg no + other data.
    Ditto second post, albeit rather than saving the image straight off it
    tries to match the reg no. If it can it works out speed. If speeding,
    both are saved, if not, first one is deleted. It didn't care if you've
    changed lanes.
    When I worked for Monitron on this stuff it was in very early days,
    most of the ACPO (?) acceptance tests didn't exist, things were just
    thought up of on the spot (mostly to do with anti tamper so images
    could be proven to be untampered so they could be used as evidence in
    court).
    I know the software/hardware can do it, I guess from your experience
    that either cars are only tracked in one lane, or more likely (what
    speeds do you do, and whats the limit?) these things are set to 25% or
    more over the limit.
    Why did they nick that biker who flicked the Vs at a Truvello hundreds
    of times?
    frag, Jun 7, 2008
  3. Steve Parry
    frag Guest
    I know exactly what the software and hardware was capable of in 1999.
    It can only have improved.
    frag, Jun 7, 2008
  4. Steve Parry
    Beav Guest
    Was/is it?
    Did they take it out, or was it never *in* in the first place. SPECS aren't
    type approved for anything other than single lane monitoring.
    The result is the same though. Change lanes and you're not seen.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 7, 2008
  5. Steve Parry
    Beav Guest
    Ok. How would they know? They're AVERAGE speed camera's we're talking about
    here so you'd have to go through at least two for ANY average to be
    calculated. As the 2nd camera and the first camera are pointing at two
    different lanes and the SPECS can only be used for single lane checks, there
    IS no average.
    I don't need to, I KNOW it works because on the M60 in the Stockport area, I
    never gave them a second thought and drove (with a front number plate)
    through the checking area as quickly as I wanted to and FAR too many times
    to remember without getting any sort of ticket/warning/NIP, so I've still
    got a pristine clean license.
    I *have* seen these things y'know.
    It may not matter to the camera, but it matters to whatever "higher
    authority" allows them to be used and HOW they're to be used. Currently,
    they're not approved for multi lane checking.
    I suspect that a 50mph limit being totally disregarded to the point that
    100mph+ is showing on the speedo comes under the category "A little over the
    trigger point"
    Because he was a naughty boy with attitude? Who really gives a **** why? The
    camera was an "on the spot" speed cam, not an average speed cam so the
    system was triggered to flag him because right at that moment, they KNEW he
    was speeding. It takes *two* SPECS in an average speed check area to reach
    the conclusion that anyone is speeding and it's at THAT point the speeder
    will be flagged. How many times have you flicked the V's at a trevello and
    not had plod knocking at your door?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 7, 2008
  6. Steve Parry
    frag Guest
    Was.
    This might interest the IT geeks:-
    #ifndef _REDSPEED_H
    #define _REDSPEED_H
    /*============== H E A D E R F I L E - RedSpeed
    PURPOSE - General header file for red-light and speed camera system
    #include <time.h>
    /* Name + . + Extension + Delimiter */
    #define FILENAMESIZE 8+1+3+1
    /* Customer defined identification of tape */
    #define VOLUMENAMESIZE FILENAMESIZE
    /* (21= 13mph)*/
    #define MIN_SPEED 21
    /* Maximum Speed for System (kph) (224= 140mph)*/
    #define MAX_SPEED 224
    <snip>
    /* Violation Data */
    typedef struct
    i16 Size; /* Size of structure */
    TIMEDATE_STRUCT tmdate; /* Date and Time (to 1/100th) of this frame */
    i16 Channel; /* Detector Channel */
    i32 OffenceNo;
    i16 OffenceSeqNo; /* First frame = 0, Second frame = 1 etc. */
    i16 SeqDelta;
    float VehicleSpeed;
    i16 TimeIntoRed; /* In tenths of sec */
    i16 LastAmber; /* In tenths of sec */
    char FileName[FILENAMESIZE]; /* File Name of Image for this
    Violation */
    } VIOLATION_STRUCT;
    Note the maximum speed :)
    frag, Jun 7, 2008
  7. Steve Parry
    Beav Guest
    Nice, but all ^^that^^ meant **** all to me coz I couldn't see anything that
    indicated an average speed check area or any indication that you can now be
    caught even if you change lanes.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 7, 2008
  8. Steve Parry
    frag Guest
    Thats cause its from the source for red light and normal speed cameras.
    I can't find the specs stuff.
    frag, Jun 8, 2008
  9. Steve Parry
    Beav Guest
    I reiterate. You can't be "done" in an average speed check area with SPEC
    cams if you change lanes part way through.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 8, 2008
  10. Steve Parry
    frag Guest
    3 packets of sugar and a horse, please.
    frag, Jun 8, 2008
  11. Steve Parry
    Steve Parry Guest
    I f*cking hate people who sit in the middle lane unnecessarily. ... grr
    Steve Parry
    BMW R45, 01 Kawasaki ZX12-R, 07 K1200GT SE
    95 BMW F650, 87 Yamaha FS1, Sukida SK90PY, 91 Kawasaki AR50,
    07 VW Passat SE Estate for comfort
    www.gwynfryn.co.uk
    Steve Parry, Jun 9, 2008
  12. Steve Parry
    Beav Guest
    You must fucking hate a LOT of people then.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 9, 2008
  13. Steve Parry
    Steve Parry Guest
    reminds me of the "I'm not racist I hate everyone" t-shirt
    Steve Parry
    www.gwynfryn.co.uk
  14. Steve Parry
    I want one that reads "I'm not a racist, I just like riding fast"
    Lozzo the velologist
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Jun 9, 2008
  15. Steve Parry
    I don't see why not. I would have thought one of the cameras tell the
    single computer that car x entered speed check area at time y and then
    car x leaves speed check area at time z - it doesn't matter to the single
    computer which camera reports the number plate and it issues ticket as
    appropriate.
    I don't understand this.
    sweller, Jun 10, 2008
  16. Steve Parry
    Which is why there are three cameras, one for each lane.
  17. Steve Parry
    frag Guest
    sweller scribbled:
    I was testing a theory that it didn't matter what I said, Beav would
    repeat the same thing ad-nauseum.
    frag, Jun 10, 2008
  18. Steve Parry
    Beav Guest
    Beav wouldn't need to iy you *actually* got your facts right.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 11, 2008
  19. Steve Parry
    Beav Guest
    Ok, have it your way. Stick to the speed limit, stay in your chosen lane and
    leave all the others open for those who can't be arsed travelling at 40mph
    for 10 miles when they can happily **** off up the road at whatever speed
    they want by changing lanes after entering the ASC area.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 11, 2008
  20. Steve Parry
    frag Guest
    I have, you fuckwit, you just can't read simple English.
    frag, Jun 11, 2008
