Speed Cameras
Discussion in 'Australian Motorcycles' started by George W. Frost, May 20, 2004.
  1. George W. Frost
    Graham W Guest
    If you can't understand that the output from a speedo, the speed
    indicated, is in linear proportion to the input, the rate of rotation of
    the wheels, I don't hold much hope for you designing anything more
    complex without outside help.
    Graham W, May 21, 2004
  2. George W. Frost
    Graham W Guest
    Well as long as they measure 75 when I'm doing 104, where's the problem?
  3. That's not quite right. It's right within about 10%. :)
    Bernd Felsche, May 21, 2004
  4. George W. Frost
    Shane Guest
    The same technology is used to land space ships on the Moon too. It all
    depends on how you use it, yeah?
    Shane, May 21, 2004
  5. You get to guess which one is the scientific instrument.
    Toby
    quidquid latine dictum
    sit, altum viditur
    Warning: All posts to be treated with a grain of salt.
    By Order
    K.K.
    Toby Ponsenby, May 21, 2004
  6. George W. Frost
    Matt Palmer Guest
    Johnno is of the opinion:
    But you have to glance at it regularly to ensure your speed isn't varying,
    because it doesn't take much increase from 60 to get you flashed. There's
    also a lot more analysis required of a speedo, IMO, because it's not a
    "car there / car not there" look, it's "am I doing the correct speed? I'm
    under, by how much, feed more pedal / I'm over, by how much, less pedal" and
    that sort of thing.
    Roughly, yes, but small changes over a longish period of time aren't that
    unlikely. Can you set your car's speed to 60km/h precisely, drive for a
    minute, and check again and it's still on exactly 60? If so, you're a far
    better driver than I'll ever be. I've never ended up with major speed
    differences, but I regularly drift by 5-10km/h over the course of a couple
    of minutes of driving - sometimes faster, sometimes slower.
    Oooh, you've got to come driving down here (Wollongong). Every speed camera
    around here is a virtual traffic jam, as everyone slows to (at most) 70km/h
    to go through an 80km/h camera, and usually about 40km/h for 60km/h cameras.
    I try to avoid driving through speed camera sites not because I'm worried
    about getting booked, but because of the clog in traffic.
    - Matt
    Matt Palmer, May 22, 2004
  7. George W. Frost
    Johnno Guest
    To this, I say:
    1. Like mirrors, you only GLANCE at your speedo, not stare at it.
    2. Surely drivers should be able to maintain a speed.
    Most people do not slow to 20-30 km/h under the limit due to speed cameras.
    While there's seldom an excuse for travelling at a significant speed under
    the limit (and hence obstructing the flow of traffic), it's not really
    relevant to the speed camera issue.
    J.
    Johnno, May 22, 2004
  8. Indication would have been close to speed of faster "target" plus
    the difference of speeds between the targets.
    Bernd Felsche, May 22, 2004
  9. The trailers aren't privately owned... not around here. They're
    supposed to (dis)inform drivers about the accuracy of their
    speedometers, providing a "speedo check".
  10. They tell you you're doing 75 when you're doing 104.
    So you go 25 km/h faster in a 100 zone because your speedo is
    "obviously stuffed".
  11. Only as much as I use the "same technology" to cook a chicken.
    ISTR that you were previously educated as to the claim about the
    "same technology is used to land space ships on the Moon".
    It was *NEVER*.
  12. Can't do that. I can't see any speed on the dial between 40 and 140
    without moving my head.
    Minimum speed permitted 80...
    Maximum speed permitted 100...
    Allow for +-10% speedometer error means that you have to maintain an
    indicated speed of between 88 and 91 km/h... and if the errors stack
    up in the wrong direction as when you're changing lanes, you could
    still get done for "speeding".
  13. George W. Frost
    Nev.. Guest
    OK then, have it your way, make it a list of cases where the prosecution
    gained a successful conviction based on the use of evidence provided by
    publicly owned trailer mounted "speedo check" technology.
    Nev..
    Nev.., May 22, 2004
  14. George W. Frost
    Spooky Guest
    Since when, is there a "minimum speed permitted" sign.?
    Spooky
    Spooky, May 22, 2004
  15. About 1987.
    It's the LAW. Minimum permitted speed on Freeway if conditions allow.
    Bernd Felsche, May 23, 2004
  16. you can be fined for driving too slowly, it's at the cop's discretion
    sheik yerbouti, May 23, 2004
  17. i haven't heard that one
  18. In aus.motorcycles on Sun, 23 May 2004 13:50:37 +1000
    It's only the law in WA.
    Elsewhere you can't go so slow as to be an obstruction, but that's got
    to be *very* slow, like maybe 50kmh on a 100kmh road.
    Zebee
    Zebee Johnstone, May 23, 2004
  19. Anything much more than 30km/h less than prevailing speeds is a
    crash looking for a place to happen.
  20. In aus.motorcycles on Sun, 23 May 2004 19:13:54 +0800
    Tell that to trucks going up hill....
    Zebee
