Speed Cameras
Discussion in 'Australian Motorcycles' started by George W. Frost, May 20, 2004.
  1. in the fast lane....
    sheik yerbouti, May 23, 2004
    #41
  2. George W. Frost
    Nev.. Guest
    Can you be fined for going to slow in the slow lane?
    Nev..
    Nev.., May 23, 2004
    #42
  3. Are you trolling? Or just make a habit of failing to grasp the
    salient issue?
    The point isn't prosecution of readings off the trailers, but of the
    prosecutions resulting from the use of the same core technology;
    being simple Doppler-shift in the microwave band; which fails not
    only to clearly identify a particular target, but also fails to take
    into account the limitations of that type of measurement.
    And there are _millions_ of prosecutions every year in Australia,
    based upon the presumption of accuracy of such equipment. That may
    be right 95% of the time; but the other 5% is a significant burden
    on justice; for the sake of administrative efficacy.
    Bernd Felsche, May 23, 2004
    #43
  4. It'd be a very heavy truck, on a very long freeway grade.
    FWIW: it's not usually the trucks causing the problem, but the
    clueless non-merging idiots who "merge" at 40 km/h with traffic
    trying to do 100.
    You may have noted that I drew readers' attention to the fact the
    German (specifically Bavarian) Police are encouraging an increase in
    the minimum power requirement for heavy vehicles using the Autobahn
    because of the congestion and crashes that are caused by heavy
    vehicles which cannot maintain 80 km/h.
    Back-of-the-envelope calculation says that'd be about 6 kW/tonne on
    the road, allowing for 2% grade and a fairly low coefficient of
    rolling resistance.
    Lane discpline is actually tangible on the Autobahn, which is why
    traffic moving at speed of over 200 km/h can safely coexist with
    such slow vehicles in light traffic. As traffic density increases,
    the speed of the faster vehicles drops rapidly as it adapts to keep
    the speed differential between "full" lanes quite low (<50km/h).
    The "friction" caused by very slow vehicles on the Autobahn is very
    noticeable.
    #44
  5. George W. Frost
    Nev.. Guest
    Who's failing to grasp the issues? I asked for examples of prosecutions and
    you responded with a pedantic comment about who owns the trailers...
    Nev..
    Nev.., May 23, 2004
    #45
  6. Pedantic comment about who owns the trailers? It's YOUR diversion to
    consider the _trailer_ the issue, instead of the "speed detection"
    issue.
    Which bit of "The same technology is used for prosecution." do you
    not comprehend?
    You honestly believe that the _trailer_ is the issue?
    Bernd Felsche, May 24, 2004
    #46
  7. George W. Frost
    Shane Guest
    No I believe it was YOU that was educated but have obviously forgotten that
    the lunar module did in fact use radar in order to land.
    http://www.clavius.org/gravdust.html
    Fig. 1 - The lunar module's landing radar antenna, normally mounted on the
    underside of the LM descent stage. The angled panels send out beams for
    differential range altitude and attitude sensing. APOLLOSATURN.COM
    The landing radar (Fig. 1) is used to to determine altitude and rate of
    descent. Normal aircraft altimeters use differences in air pressure to
    measure altitude, but obviously that won't work in a vacuum. So the only way
    to measure the distance and descent rate is by radar, which was accurate to
    about 15 feet (5 meters). But the descent rate was already fixed before
    switching to instruments, so it was just a matter of riding it down until
    the contact light illuminated.
    Shane, May 24, 2004
    #47
  8. A check of sources closer to the event are worth reading:
    "Complete" transcript and subsequent comments at
    http://www.phrd.ab.ca/Schools/LJHS/APOLLO/ap11jnl1.htm
    They landed *despite* the radar which overloaded the LEM computer,
    after initially giving misleading altitude readings (53,000 feet vs
    actual 50,000).
    [Armstrong - We measured the position of certain prominent
    landmarks at a couple of points prior to ignition and then
    after ignition. Once that was finished, we did a 180-degree
    yaw (to the face-up position) so that the radar could see
    the surface. My recollection is that the landing radar
    wasn't really reliable above something like 30,000 feet.
    They had tried it on Apollo 10 (at 50,000 feet) to see if
    they could get altitude readouts, and we did try to use it
    (at that altitude) to get some measurements. We wanted to do
    that while we were still up at a reasonable altitude to help
    the guidance equation converge. (The timing of the
    180-degree yaw) was a balance between seeing the surface and
    getting the radar information in the guidance solution."]
    102:38:11 Aldrin: Yeah. Altitude light's out. (Pause) Delta-H is
    minus 2,900.
    [They have a radar return from the lunar surface and the
    radar altitude is 2900 feet lower than the PGNS altitude.]
    Further reading:
    http://www.exn.ca/apollo/interviews/kranz.cfm
    Apollo 11 Flight Director Gene Kranz:
    Well there's one where we were working with the back up
    crew, where we started off on our trajectory, higher than we
    should've been to start the descent but we're still within
    the box to get down to the surface of the moon. And then we
    had a radar data discontinuity with radar showing a major
    difference between true altitude and what we provided the
    computer. ...
    ... So all of a sudden the problems are mounting, the
    communications problems, we got navigation system, we had a
    minor electrical problem and then very shortly thereafter,
    as we're preparing to accept because we have to get radar
    data that tells us our true altitude, and we have to make a
    determination whether we're going to accept this into the
    computer or not. And about the time this is occurring, a
    series of program alarms come on and the program alarms are
    telling us that the space craft computer is too busy to do
    all of the things we're asking it to do. ...
    [snip]
    Method of operation is completely different to the mis-named "radar"
    used for "speed detection".
    The "speed detection" units transmit continuously. With continuous
    wave, it's impossible to determine distance.
    It is necessary to pulse the signal and measure the echo's _delay_
    to determine an estimate of the distance.
    The moon is also a significantly-larger target to hit from 50,000
    feet, than a car from 100 metres. And when you are one of only two
    moving objects of significant RCS within about 1 light-second,
    target identification isn't very difficult. At least much easier
    than determining which of the dozen or so intermittent returns from
    CW is actually "tracking" a particular target, or a reflective
    phenomenon between objects moving at slightly-different speeds.
    #48
  9. George W. Frost
    Nev.. Guest
    Does it matter if there's an error in distance calculations? As long as the
    error is relatively consistent the speed measurement will be accurate won't
    it?..
    Nev..
    Nev.., May 24, 2004
    #49
  10. George W. Frost
    TheTaipan Guest
    Not really, if speed is a measurement of distance/time, and we have an
    inaccurate measurement of the distance travelled over that time, how do we
    get an accurate speed?
    If the reading says 90m and its really 100m then the calculated distance
    over time will be 10% out.
    TheTaipan, May 24, 2004
    #50
  11. George W. Frost
    Nev.. Guest
    But I said what if the error is consistent... the distance travelled will
    remain relatively accurate won't it, and presuming the timing is accurate,
    wouldn't the speed calculation be relatively accurate too?
    Nev..
    Nev.., May 24, 2004
    #51
  12. Depends...
    Keep in mind, the speed measurement relies on _2_ distance measurements.
    If by "consistent", you mean "it _always_ reads 3000 feet too high",
    then yeah, the speed accuracy would not be affected. If it was "it
    always reads plus or minus 8%" or whatever, then no, sometimes you'll
    get a "plus 8%" error reading followed by a "minus 8%" reading, and
    you'll get an incorrect speed. (especially if the distance errors are
    large compared to the speed).
    big
    Iain Chalmers, May 24, 2004
    #52
  13. It does if you switch off your main retro-thruster 3000 feet too
    early!
    Did you miss the bit about the USD$30million equipment?
    Did you miss the fact that the altitude sensing is entirely
    different to that used for "speed detection"?
    If NASA can't get it right for USD$30 million (in 1965 value) with
    dozens of pairs of eyes and minds in constant supervision, then
    what hope has a AUD$10,000 "speed detection" digital moron operating
    in a much less-controlled environment with multiple targets and
    reflective objects at different velocities?
    NASA never used the "same technology" to land anything on the moon.
    Armstrong landed because the signals from the entirely-different
    type of radar were _ignored_.
    The technology used is not the "same technology" as used for "speed
    detection"; not by a long shot. The technology used for speed
    detection is more like what your mum uses to heat your dinner when
    you come home late after school: Continuous microwave emissions.
    "Speed" measurement by Doppler shift is obtained by measuring the
    "beat frequency" (frequency difference) between the continuously-
    transmitted microwave signal and return echo. There is _no_
    distance measurement taking place.
    The measuring device doesn't have a clue where the target is
    actually located as it has no means of determining distance by
    Doppler shift alone. The strength of the return is no clue
    whatsoever as equivalent echoes may be from a distant, good
    reflector, or a close, poor reflector.
    Or it may be from a microwave phenomena such as scintillation; or
    multi-path with a nett shift at the receiver in excess of that
    corresponding to any target that's illuminated.
    #53
  14. George W. Frost
    Johnno Guest
    Interesting question.
    If you're *unnecessarily* obstructing the flow of traffic in the left-most
    lane, I would expect you could be fined.
    I shouldn't expect that a heavily loaded truck climbing a steep hill would
    be fined, as it's in such a condition whereby obstructing traffic is rather
    unavoidable. And on freeways, where signs specifically direct trucks to use
    left lanes, this is obviously taken into account.
    J.
    Johnno, May 24, 2004
    #54
  15. Heres an idea, so you wont get pinged by the possibly inaccurate speed
    camera...
    DONT SPEED...
    Howzat!!!
    ··»¤·QUOKKA·¤«··, May 24, 2004
    #55
  16. Which part of "inaccurate" don't you understand?
    If the "speed detection" device _exaggerates_ the vehicle's actual
    speed it can still get booked when it's not actually exceeding the
    speed limit.
    The claimed accuracy is nothing like the practical accuracy of the
    devices. Multanova claims +-1% yet independent field trials have
    shown repeatable errors exaggerating vehicle speed by more than 5%
    under "normal", controlled traffic conditions as well as the
    tendency to identify the incorrect target as being the offender.
    Bernd Felsche, May 25, 2004
    #56
  17. George W. Frost
    Nev.. Guest
    yes, that is what I meant...
    Even then I think the unit would probably discard the results. I'm sure
    several consecutive matching measurements would be required before a speed
    calculation would pass internal error correction.
    Nev..
    Nev.., May 25, 2004
    #57
  18. George W. Frost
    Nev.. Guest
    So lets see... RADAR technology was first implemented in the early 1940s by
    the Poms, NASA had a version of RADAR which it used to land lunar modules in
    1965, and you are of the firm belief that in the 39 years since then there has
    been no significant improvement in the implementation and accuracy of radar
    distance measuring devices. Fair enough. I suppose you still think that $30
    million dollars will buy a computer which will run at an astounding 2MHz with
    a whopping 64KB of RAM and let you store information on 720KB 8inch magnetic
    disks.
    Nev..
    Nev.., May 25, 2004
    #58
  19. George W. Frost
    Theo Bekkers Guest
    "Nev.." wrote
    No way Nev. 8 inch floppies came a lot later. And in 1965 our mainframe was
    running at 0.16MHz. We didn't dare dream about 2MHz. We got 1MHz in 1968.
    Theo
    Who still has nightmares about head crashes on the 4MB hard drives in 1969.
    Theo Bekkers, May 25, 2004
    #59
  20. Unfortunately the Victorian experience seems to show otherwise, with the
    speed cameras happily accepting 170kmh 1979 Corollas and 140kmh uphill
    trucks...
    There's no doubt that radar systems _can_ be engineered with very high
    degrees of accuracy, but remember these were almost certainly contracted
    out to the lowest bidder...
    big
    Iain Chalmers, May 25, 2004
    #60
