Speed Cameras
Discussion in 'Australian Motorcycles' started by George W. Frost, May 20, 2004.
  1. George W. Frost
    feral Guest
    Two years is not a lot later IMHO. Give him a break.
    I was still formatting and using the single-sided muthers in
    the late *80's*. :-( IIRC single-sided, double density (400k).
    T.C. Feral
    feral, May 25, 2004
    #61
  2. George W. Frost
    Shane Guest
    Found another site which details early issues they had with the lunar module
    landing radar. It kept changing ranges for no apparent reason until they
    worked out why and apparently fixed it. Possibly a software problem.
    If I suggested that errors of this magnitude could be found on the Kustom
    gear we're using the Tech's downtown would laugh at me. These guys swear by
    the accuracy of these things both on the bench and on the road. All of our
    equipment is tested by tech's on the road before allowing them to be used
    operationally. Put it this way Bernd, I can MAKE a Silver Eagle play all
    kinds of strange games if I wanted to. The things I'd have to do to MAKE it
    do this are so far away from the services guidelines it's not funny.
    Shane, May 25, 2004
    #62
  3. George W. Frost
    Theo Bekkers Guest
    "feral" wrote
    It's harsh week.
    Theo
    Theo Bekkers, May 25, 2004
    #63
  4. George W. Frost
    Moike Guest
    You weren't there, were you.
    8" FDDs came along much later than $30M computers with 64K of ram.
    I think the Micromation mictocomputer I was using in the early 80s was
    about those specs (~1MHz, 64K, and 8"FDDs, but cost was only about $10k)
    Oh, and I don't think 720kb was ever a standard capacity for 8" drives.
    That would be the 3.5" DSDD.
    Moike
    Moike, May 25, 2004
    #64
  5. George W. Frost
    Moike Guest
    D'oh. Must read whole thread before making smartarse reply....
    Moike
    Moike, May 25, 2004
    #65
  6. George W. Frost
    Nev.. Guest
    those fixed cameras don't use radar though...
    Nev..
    Nev.., May 25, 2004
    #66
  7. D'oh!
    Good point...
    big
    Iain Chalmers, May 25, 2004
    #67
  8. But it does sound like you've tried them out, doesn't it?
    big
    #68
  9. George W. Frost
    conehead Guest
    You mean they're still dearer than that?! It'll still be a while before I
    upgrade then.
    conehead, May 25, 2004
    #69
  10. George W. Frost
    John Littler Guest
    Weren't the DD 8" ers 180K ? - the 5 1/4" double density were 360K and
    seem to recall that being an advance
    JL
    John Littler, May 25, 2004
    #70
  11. George W. Frost
    Johnno Guest
    How is that so?
    J.
    Johnno, May 25, 2004
    #71
  12. The steering wheel's rim is in the way.
    Bernd Felsche, May 25, 2004
    #72
  13. George W. Frost
    Graham W Guest
    Accuracy isn't the problem here. The problem is reliability. These
    cameras were accurate the vast majority of the time and miles out
    perhaps one in a thousand cars.
    Rather than pursuing improved accuracy, what is needed is improved
    reliability. One method would be to have a second speed measuring device
    and to log any and all examples of the two devices disagreeing, even
    if both say no offence occurs. The second devide doesn't even have to be
    particularly accurate, +/-5kph would be ample to show if any systematic
    errors are made by the primary device. This way, even very low rates of
    sporadic errors such as were apparently happening will get detected.
    Obviously where they disagree no ticket should be issued too.
    Graham W, May 25, 2004
    #73
  14. George W. Frost
    feral Guest
    I recall the original 1971 IBM single-side floppy as 200k.
    In the 80's Siemens Telecom were still using them, but they
    could not be formatted on the equipment. We found a system
    (NEC IIRC)that could format them in either single or double
    density. Now I remember, single sided for programming and
    double sided for data saves.
    I do not know if Siemens formatted them to 200k though, and
    never will now.
    T.C. Feral
    feral, May 26, 2004
    #74
  15. best suggestion ive heard in a while.
    this would fix the problem
    sadly it would also increase costs, thus reducing their ability to
    realise the "true" benefits of speed cameras
    sheik yerbouti, May 26, 2004
    #75
  16. Erm... no.
    The computer on the LEM was much smaller and slower than that.
    But it was also far more _robust_ than the piece of crap you're
    using.
    And guess what? There were several humans in the loop, and backup
    systems (inertial guidance and optical) to help the humans decide if
    the information from any single source is valid.
    You're also conveniently over-looking that:
    a) the technology for distance measurement used in the LEM and that
    used for "speed detection" is quite different. The speed detection
    units are incapable of detecting distance to the target.
    b) the underlying limitations of the physical world that cause many
    of the errors cannot be eliminated.
    The main problem with the way in which speed cameras are used is
    that it's *impossible* for the only human in the loop (after the
    fact) to obtain a perspective beyond the machine which may provide a
    clue as to the validity of the information presented.
    It's indeed possible for the cameras to provide additional
    information to increase the certainty that the result obtained by a
    firmware upgrade or maybe even a configuration option, but that is
    not done.
    Bernd Felsche, May 27, 2004
    #76
  17. George W. Frost
    Johnno Guest
    It sounds like you need to adjust your wheel and/or seat so that you have an
    unobstructed view of all the indicators and gauges on your dashboard.
    J.
    Johnno, May 27, 2004
    #77
  18. The steering wheel position is not adjustable.
    The seat is adjusted so that my foot can fully depress the brake
    pedal without the leg being completely straight.
    The seatback is adjusted so that my wrists can rest on the top of
    the steering wheel rim, with my shoulders against the backrest.
    #78
  19. George W. Frost
    Johnno Guest
    Are other indicators and gauges on the dash obscured too?
    If you cannot see all of your indicators and gauges whilst having the seat
    and wheel positioned for optimum comfort, it sounds like the car doesn't
    particularly suit you ergonomically.
    J.
    #79
  20. George W. Frost
    conehead Guest
    I don't think I'd pay too much attention to someone who can't spell
    "Felcher" properly, even when it's his own name.
    conehead, May 28, 2004
    #80
