Speed Cameras
Discussion in 'Australian Motorcycles' started by George W. Frost, May 20, 2004.
  1. It sounds like you have no neck. Otherwise you should be able to see the
    speedo, with those seating arrangements.
    Dickens Cider, May 30, 2004
    #81
  2. Just live with it, I've been driving cars without working speedo's for years
    and never been booked. Passing every other car is usually a clue you might
    be speeding.
    Rainbow Warrior, May 30, 2004
    #82
  3. No. Just a few switch blanks. I moved the active switches around.
    I'm "average" height, etc. All gauges are visible in the LHD version
    of the car with the seat adjusted the same way.
    Bernd Felsche, May 30, 2004
    #83
  4. If I had *no* neck, I'd be able to read the speedometer.
    I'm average height; 1.78m tall, 80kg +-3kg.
    If I were taller, I'd be able to read less of the speedometer.
    #84
  5. George W. Frost
    sharkey Guest
    So, the question is: why did you buy this ill-designed shitter,
    and is the state really beholden to support you in your decision
    by giving you extra leeway? Should the highway patrol be
    performing IQ tests by the side of the road:
    "Well, sir, you were 2 km/h over the limit, but
    seeing as you have extremely quick reflexes and
    exceptional situational awareness, you could have
    maintained +- 0.5 km/h and I'll have to cut up
    your license."
    And ditto if you're silly enough to drive one of those horrid
    things which so insulate you from the real world that you can't
    even tell whether you're driving or watching television.
    -----sharks
    sharkey, May 30, 2004
    #85
  6. No car is perfect.
    The handling is fine. Ergonomics are otherwise excellent with pedals
    and controls perfectly located.
    It is *NOT* important, excepct under draconian policing, that I be
    able to read the speed to within +-1km/h.... the speedometer isn't
    even *graduated* more finely than 5km/h.
    Highway patrol conducting IQ tests? Their IQ is tested using
    breath testers.
    Bernd Felsche, May 31, 2004
    #86
  7. George W. Frost
    Johnno Guest
    It helps to change out of first gear. |-)
    J.
    Johnno, May 31, 2004
    #87
  8. I rode my bike for nine thousand k's with no speedo and never had a
    problem.
    Well, it is a Harley!
    Pisshead Pete, Jun 1, 2004
    #88
  9. George W. Frost
    Yeah but for at least a thousand or so I was riding shotgun for you!
    (And I was almost spattered over you once too!)
    Clem
    Knobdoodle, Jun 1, 2004
    #89
  10. Care to cite? I've found nothing further in NASA's archives.
    How is that relevant?
    I've shown you the report. It's not invalidated by your inability to
    understand it.
    Ignorance is bliss.
    It's not capable of tracking the location and direction of
    individual targets so it's just as susceptible to the same sort of
    errors; even when set up in the prescribed manner.
    Bernd Felsche, Jun 7, 2004
    #90
