Speed limit crackdown to cut emissions
Discussion in 'UK Motorcycles' started by CT, Nov 14, 2005.
  1. CT
    HooDooWitch Guest
    You're not thinking of generations of future archaeologists, are you?
    Oh, and whoosh ...
    HooDooWitch, Nov 14, 2005
    #41
  2. CT
    Dr Zoidberg Guest
    Mine'll do about 67mpg at that speed.
    A run back from london at a constant 80mph (true not indicated) was still
    51.5 mpg.
    Alex
    www.drzoidberg.co.uk www.ebayfaq.co.uk
    Dr Zoidberg, Nov 14, 2005
    #42
  3. CT
    Switters Guest
    I drove Motherwell to Plymouth once on a single tank of diesel in a 1.6D
    Cavalier. Fair flabbergasted was I.
    Switters, Nov 14, 2005
    #43
  4. CT
    Greybeard Guest
    Doesn't that constitute 'criminal damage' ?
    I'm sure there's offence there if you could catch the fuckwit in action.
    Either that, or broken fingers might slow their sticker habits down a tad
    ;o)
    JMHO (officer).
    Greybeard
    FLHRCI -01 UK ( 95 cu-in Stg 2. Big Boy!)
    Trumpet Trophy 1200 -91, for rainy days
    nntp@foxtails[dot]co[dot]uk
    Greybeard, Nov 14, 2005
    #44
  5. CT
    well, it did occur to be that if it happens again, I might kip
    overnight in the car, and if it happens a third time just run the
    fucker over.
    darsy, Nov 14, 2005
    #45
  6. CT
    Eiron Guest
    True but that wasn't the point.
    The OP said "Engine efficiency falls quickly beyond 70 mph", which is wrong.
    Engine efficiency is probably at its highest at WFO at max-torque revs,
    by the true definition of efficiency.
    Eiron, Nov 14, 2005
    #46
  7. CT
    IME they do last - a lot - longer, but only if you leave them turned
    on - turning them on and off a lot seems to **** them over, though.
    darsy, Nov 14, 2005
    #47
  8. CT
    ogdenstein Guest
    This makes them perfect for bathrooms. Stagger to bathroom for midnight
    piss, turn on light, be greeted by gradual increase in brightness and
    avoid being dazzled.
    Leaps and bounds ahead of incandescent bulbs.
    ogdenstein, Nov 14, 2005
    #48
  9. CT
    simonk Guest
    I seem to be doing better with these than the R80 spots I had before, which
    seemed to go "dink" at the rate of one a week. Then again, I had about 20
    of the buggers, in various stages of old-ness, in the old non-airtight
    ceiling - the bulbs were exposed to a constant draught of air sucked in from
    the flat above, which can't have helped matters.
    The only trouble with the bulbs I've got is that, compared to standard
    compact fluorescents, they take a while(~5 mins) to warm up and kick out the
    full brightness.
    http://www.megamanuk.com/products/product.php?sid=4
    simonk, Nov 14, 2005
    #49
  10. CT
    Greybeard Guest
    That'll sort it !
    Greybeard
    #50
  11. CT
    Heh. Imagine a Police instructor lecturing a class of bemused would-be
    coppers: "This index plate is illegally small; that one is far
    away..."
    Pip Luscher, Nov 14, 2005
    #51
  12. In uk.rec.motorcycles, Champ amazed us all with this pearl of wisdom:
    A *lot* longer. They do take a couple of minutes to come up to full
    brightness though.
    Whinging Courier, Nov 14, 2005
    #52
  13. CT
    True enough, but the OP was just a quoting a quote of some nameless
    official who was talking bollocks, or maybe the quoter quoted by the
    OP was. Don't qoute me on this, though.
    Overall vehicle efficiency will prolly do as Champ says.
    #53
  14. CT
    AIUI the predominant aerodynamic drag force squares therefore the
    power cubes.
    So for a doubling of speed one needs eight times the power (twice the
    speed times four times the drag force).
    #54
  15. YTC
    The Older Gentleman, Nov 14, 2005
    #55
  16. CT
    Andy Hewitt Guest
    It's not a fact either, best engine 'efficiency' is when the engine is
    working at maximum load. Somewhere near the peak of the power band.
    In fact, the mixture does not get any richer after about 3000 rpm
    anyway. There would be insignificant savings in this regulation for the
    reasons they suggest.
    Andy Hewitt, Nov 14, 2005
    #56
  17. CT
    Dan White Guest
    Coming from you, praise indeed.
    Seriously though, you don't think that if our motorway limit was much higher
    that cars could be built that would be more efficient at higher speeds?
    Dan White, Nov 14, 2005
    #57
  18. In uk.rec.motorcycles, Dan White amazed us all with this pearl of
    wisdom:
    Why don't they just put another gear in now then?
    My car does 3,500rpm in 5th at 70mph, I could really use another gear!
    #58
  19. CT
    ogdenstein Guest
    Prods at Hog's trolling aside, you might have an idea on this one.
    Timer switches. For lights and whatnot. They all seem to say they're
    not suitable for fluorescent lights, with the exception of some special
    units that cost about three times as much.
    What's that all about? Is it a load of old bollocks, or is there a good
    reason for it?
    #59
  20. CT
    Eiron Guest
    Your car won't be able to pull 3500 in 5th when all its power is taken
    by the alternator to drive your new BFO amp and your Prodigy CD.
    Eiron, Nov 14, 2005
    #60
