Squeaky brakes
Discussion in 'UK Motorcycles' started by A Lemming, Apr 17, 2008.
  1. A Lemming
    A Lemming Guest
    Hi all,
    I've got a problem with the front brakes squeaking on my CBF600. I had a
    bit of a search, but the one thread I found related mainly to drum
    brakes and I have 2 discs up front.
    The bike has only done 1200 miles (I bought it second hand at 912 miles)
    and the squeaking has only started since it's been outside in the rain,
    but it now squeaks even when it's been dry for a full day. The squeak
    only starts as I'm near a stop (so below 10mph when braking from 40).
    It still stops as it did before these started making a noise, so I was
    wondering if it is likely to be something to do with having been outside
    in the wet?
    How likely is it to be a real problem this early in it's life, and what
    is the best way to stop the noise?
    Thanks in advance,
    Wayne
  2. A Lemming
    Beav Guest
    I realise this is unusual, but here goes.
    Take the pads out of both callipers and smear a little smeg (or copper-slip)
    on the back of the pad and the anti-squeal shims. Re-instal. Ride.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Apr 17, 2008
  3. A Lemming
    antonye Guest
    I would:
    1. Take pads out and put to one side
    2. Remove calipers from bike and apply liberal amounts of brake
    cleaner
    to remove all the shit from them
    3. Without popping the pistons, pump the brake VERY SLOWLY just to
    expose
    the pistons by around 5mm, then smear with some coppa-slip
    4. SLOWLY push the pistons back in place. Repeat 3 & 4 if the pistons
    are
    overly sticky or show difficultly in moving freely
    5. Refit calipers and torque as per (Haynes) manual
    That's the calipers done, now the pads:
    6. Get a piece of sandpaper and lay it on a flat surface
    7. Place pads on it (pad to sandpaper, obv!) and sand them lightly to
    remove any traces of crap and glazing from them. This can be seen
    as
    a rainbow sheen at certain angles of light on the pad surface -
    sand
    until this is removed
    8. Clean the backs (metal side) with a splash of brake cleaner then
    give them a good smear of coppa-slip
    9. Refit pads making sure you clean and smear coppa-slip on the
    retaining
    pin(s) as you go
    10. Once refitted, give your brakes a good pump to get the pistons
    back
    in the right place - you don't want to be doing this at the first
    junction you need to brake for!
    11. Go out and ride it. Take it steady at first to re-bed the pads in.
    antonye, Apr 17, 2008
  4. A Lemming
    Simon Wilson Guest
    antonye wrote:
    I wouldn't do this. Coppa-slip is rumoured not to be good for some seals
    (can make them expand). Castrol make a special red-rubber grease which
    is ok for pistons.
    Simon Wilson, Apr 17, 2008
  5. A Lemming
    The coppaslip shouldn't go anywhere near the seals if it's on the back
    of the pads only. I don't use coppaslip on caliper bodies any more
    since I found out how it damages brake seals. Wurth do sachets of
    aluminium brake paste that are good, but I'm a red rubber grease
    convert now.
    Lozzo
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 17, 2008
  6. A Lemming
    Dave Emerson Guest
    Correct.
    Coppa (Copper) slip is great for the back of the pads and the mounting bolts
    but not for the pistons.
    No only can it chemically react with the seals but the seals need a
    controlled amount of friction with the surface of the piston. It's this
    grip that pulls the piston back very slightly as the seals recover when the
    line pressure drops, i.e you let the brake off.
    Dave Emerson, Apr 17, 2008
  7. A Lemming
    A Lemming Guest
    Erk - what's an anti-squeal shim ?
    I've not got a HBOL for this beast yet :(
  8. A Lemming
    A Lemming Guest
    Thanks - sounds kinda complex. How long would this take a normal person
    to do ? Just so I know to double it and use that as a best case scenario
    :D
    So I'll be needing a torque wrench, brake cleaner and the castrol red
    stuff someone mentioned. I take it most bike shops should have this
    stuff?
  9. A Lemming
    Beav Guest
    A really thin piece of steel that sits abasck of the pad. You'll see it when
    you pull the pads out, because they're usually "tabbed" to the pad.
    Good man :)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Apr 17, 2008
  10. A Lemming
    Beav Guest
    It's an hours work to do all the pistons (sans copper-slip) not that they
    should need ANY work, given the bike is low mileage and (I assume) not old
    or been standing around for months not being used.
    Not really. Just get the caliper bolts well nipped up.
    Red grease. Designed so that it doesn't eat rubber. Important when you're
    dealing with seals. (and whales presumably)
    Most good ones, but that's not "most". A good motor factor should though,
    even Halfrauds could stock it.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Apr 17, 2008
