Squealing brakes
Discussion in 'Motorcycle Technical Discussion' started by ben scott, Jan 7, 2007.
  1. ben scott
    ben scott Guest
    I have a 1992 750 ninja with dual hydraulic front disc brakes. I have
    tried EBC pads in both the "organic" and the "HH" formulations and
    both screech badly when cold. If I work the brakes to heat them up
    the noise stops and it is less common in warm weather. I looked at the
    pads and don't see any signs of odd wear and cant find anything that
    might be dragging on the calipers that shouldn't be. I can't tell if
    it is just one brake or both front brakes. The discs are in better
    shape visually than the discs on most other bikes I have owned. This
    is driving me nuts and is embarrassing besides.
    Thank you for any help.
  2. ben scott
    Gene Cash Guest
    EBC pads?
    <mythbusters>There's yer problem!!<mythbusters>
    Get rid of that cheap-ass shit and buy OEM Kawasaki pads.
    I've also had EBC pads score my rotors in addition to being noisy no
    matter what antisqueal shims I did or did not fit.
    -gc
    Gene Cash, Jan 7, 2007
  3. Brake pad squeal is caused by a resonance between the pad and the disk.
    It's like dragging your fingernail across a chalk board.
    Pad squeal gets worse with harder brake pads.
    Brake pads are always skimming the surface of the disk lightly, they
    have only about 2 or 3 thousandths of an inch of clearance.
    As the pads intermittently touch the rotors, the surface of the pad
    gets hard and you will notice that the fiber matrix holding the little
    metal bits gets shiny.
    This is called "glazing" and the solution for pad glazing is to remove
    the pads and work them in a figure-8 pattern on a piece of sandpaper
    laying on a flat surface. A sheet of glass makes a nice flat surface.
    But the glazing will return if you don't use your front brakes hard
    occasionally. I used to hear the front brakes on my old GT-750 Water
    Buffalo squealing constantly because I was a rear brake user and didn't
    use the front brakes hard.
    Also, stainless steel rotors that aren't drilled will squeal worse than
    any other type of rotor. GT-750's came with undrilled, stainless steel
    rotors...
    Potage St. Germaine, Jan 8, 2007
  4. And you're still alive to tell the tale? Blimey.
    The Older Gentleman, Jan 8, 2007
  5. ben scott
    ben scott Guest
    Thank you. I will try that along with some of the other suggestions I got.
    ben scott, Jan 8, 2007
  6. I would ride the Water Buffalo 100 miles every day of the week in those
    days, putting 25K miles a year on the machine while exploring all the
    canyon roads leading to the beaches, but my average speed was only
    about 45 mph.
    The double disk brakes were more suitable to vigorous sport riding, so
    they didn't get used hard enough to knock the glaze off the pads, and
    they would "sing" at an annoying high pitch as the rotors turned.
    I would loosen up the caliper bolts, rock the calipers just enough to
    slip a strip of 3M wet-dry sandpaper (grit side out) between the disk
    and pad, pump the brake lever to clamp the paper against the rotor, and
    slide the paper back and forth to de-glaze the pads.
    The other maintenance trick was to reposition the rear brake arm after
    about 7K miles so it wouldn't hit the rear axle when I applied the
    brakes.
    One Honda rider was baffled by what I was doing as he watched me
    reposition the arm in
    the Griffith Observatory parking lot. He asked why I didn't do that at
    home.
    I told him that I was at home on the Water Buffalo, wherever it was,
    but he was just a "weekend warrior" who didn't understand the biker
    lifestyle.
    I used to clean my spark plugs and clean and gap my ignition points
    while the RUB's were busy brown-nosing each other. They all thought I
    was the weird one, but they had to take their own machines to a
    $tealer$hip just to have the air changed in their tires
    every spring...
  7. Well, yeah, I wouldn't ride anything fast either, if I was just relying
    on the back brake.
    Heh. The trick is not to adjust it so far that it over-centres....
  8. ben scott
    Berg Guest
    The old fashion and most used product is copper grease, a much better
    solution(albeit more expensive) is aluminium grease.
    Clean the calliper where the pads ride for all non-belonging material.
    Then smear a thin cote on all of the contact surfaces, including the
    edges. Forget the latter, and it will squeal...
    J.
    Berg, Jan 8, 2007
  9. I pack the shims behind the pad and the pins with wheel bearing grease.
    (wheel bearing grease don't melt) It attracts brake dust and dirt and
    makes changing them more messy but it stops the squeaking. I hate
    squeaks. When I need new pads I clean everything up and re-grease it.
    Snap Whipcrack.............., Jan 8, 2007
  10. Is this Nomen Nescio again?
    I've heard about using copper grease on the *pins* that single-sided
    calipers slide on, they have o-rings to seal grease in and British
    riders use the copper grease because
    they salt the roads and calipers corrode and get stuck.
    But this poster makes it sound like he's putting grease on the backs
    and edges of the brake pads.
    Now, what is grease? It's a lubricating agent of some sort in a binder
    that melts at some temperature. If the lubricating agent is powered
    copper or aluminum in something that melts, what's to stop the melted
    stuff from getting on the calipers and the working face of the brake
    pads?
  11. ben scott
    Berg Guest
    Grease is a generic term, as in "Grease", containing soap and
    lubricants, and wait for it..... Comes in different heat tolerance ranges.
    And yes, I do apply it to the back of the pads, and the edges.
    The only place it is not used, is in true racing applications, where
    squeal is a non-issue.
    J.
    Berg, Jan 8, 2007
  12. ben scott
    Berg Guest
    Copper grease is also known as copper paste, as is the aluminium based
    version(Aluminium paste).
    J.
    Berg, Jan 8, 2007
  13. Over a long period of time, this is the case. The O-rings work
    effectively, quite often for many years, but removal of the pins and a
    cleane and re-grease is good policy.
    What's also important is to grease the pins that secure the pads
    *especially* on calipers where the pins go blind into the caliper (and
    thus can't be knocked out from the other side). Suzuki bandits are
    notorious in this respect.
    Yes. So do I.
    Using high melting point grease. Next question?
  14. What's the melting point of the binder agent?
    The peak temperature around here gets up to 100 degrees F everyday for
    six months, then we get the cold season where the high temperature is
    55 to 60 degrees F.
    The temperature on the pavement is probably 150 to 160 degrees F during
    the summer, and, if the brakes are used, they probably heat up the pads
    to 300 degrees.
    If the melting point of the binder is too low, the stuff will drip off
    the pads, maybe onto one rotor when the motorcycle gets parked on the
    side stand...
  15. Look, in the last few days you have:
    Told a flat-battery Ducati owner to check his kill switch when the bike
    actually spins the engine on said switch.
    Given a KE100 owner reams of advice on checking his sidestand ignition
    cut-out when the bike doesn't have one.
    Told the Ducati owner to look for his battery behind the fairing, when
    it's actually under the tank.
    Told the Ducati owner to check his sidestand ignition cutout when the
    Given the Ducati owner several hundred words of irrelevant verbiage on
    batteries. All he had was an immobiliser which was flattening the
    battery over time, for Chrissakes - a well-known issue, and something
    that other posters referred to as well.
    Given us your perceived wisdom of riding a bike on the back brake only.
    And now you're banging on about not using a very specific type of grease
    on brakes *when some manufacturers actually include the stuff with the
    pads*.
    Just accept that, on occasion, the depth of your knowledge is matched by
    an equally vast chasm of ignorance and that people may do what you don't
    advise, and it works for them.
    I've used a very thin smear of brake grease (forget what it's called -
    comes in little sachets with some brake pad brands) and/or some very
    high melting point grease on pads and pins for decades. I haven't run
    out of brakes yet.
    It also seems to work for other posters here.
    The Older Gentleman, Jan 9, 2007
  16. As I said previously, greasing brake parts with something like Duckhams
    Copper 10 is a British thing, nobody in California needs to do it, as
    the roads aren't salted, CalTrans just throws gravel on the snow so
    unwary riders can crash after the snow melts.
    And you still didn't answer the question about how hot the stuff has to
    get before it moves around...
    Potage St. Germaine, Jan 9, 2007
  17. You're still likely to get corrosion of one type or another - it'll
    just take longer. And as others have said, it helps prevent squeal.
    I don't care. I use HMP grease, very sparingly, and I haven't had a
    problem in <checks calendar> 31 years of riding. In fact, I've never
    had a grease-on-brakes incident in 31 years of riding <sticks finger in
    wind> something like 400 different motorcycles. And like I said, it's
    SOP here and plenty of other places. Including the US. Why think it's
    confined to Britain?
    Ah! Wait! I tell a lie! I bought a Kawasaki H1D in, um, oh, must have
    been 1996 or 1997, and on the test ride the front disc didn't bite *at
    all*, so I went into a bend rather faster than I intended. Bad news on
    an old Kawasaki triple.
    When I got back and told the seller that the brake had given me a nasty
    moment he confessed to having sprayed everything with WD40 before
    putting the bike into storage.
    Just accept that you're wrong about this.
    chateau.murray, Jan 9, 2007
  18. To get the kind of corrosion I saw on 10 year old motorcycles in
    England, you'd have to live at the beach in Malibu and park outside for
    about three years.
    My GS1100 Clymer manual calls for a thin coating of a clear grease on
    the calipers' axle pins. The only reason I knew about Brits using
    copper loaded grease is from reading motorcycle magazines, and my
    Yamaha Haynes manual also mentions using Copper 10 on UK motorcycles.
    Well, I *thought* I was wrong, once. But I reconsidered and realized
    that I was mistaken...
    Potage St. Germaine, Jan 10, 2007
  19. Heh. Trust me, other countries do it as well. The UK, mirabile dictu,
    does not have a global monopoly on foul weather.
    The Older Gentleman, Jan 10, 2007
  20. Where did I ever say that I relied on the rear brake only? I said that
    I didn't use the front brakes hard enough. So the pads glazed.
