Starting problems..
Discussion in 'Australian Motorcycles' started by Damien, Dec 3, 2003.
  1. Damien
    Damien Guest
    For some reason bike wont turn over ?!
    I started it fine, rode it out the front of my house, washed it (used a
    bucket - only used the hose for a quick spray down at the end). Tried to
    start it up and the starter worked but bike wouldn't kick over. Tried with
    choke and tried roll start but nothing.
    One time it after a roll start it did catch but revved very low and then
    died.. Yes it has petrol and it is turned to On (also tried reserve)..
    Any ideas ?
    Damien, Dec 3, 2003
  2. Wet electrics maybe?
    Try spraying the spark plug leads with wd40 - the high tension side of
    the ignition system is particularly susecptible to moisture...
    I had a problem with the Spada once which turned out to be some red
    bulldust (from a trip 6 months earlier) in the connector that the
    ignition pickups plugged into the black box - it seems once the bulldust
    got wet, it was conductive enough to make it run _really_ badly...
    big
    Iain Chalmers, Dec 3, 2003
  3. Damien
    Theo Bekkers Guest
    "Damien" wrote
    Water in the carbs. (if you have carbs) Drain the carbs, take out the
    main-jets and blow through them. Corrosion in a connector. Try taking the
    plug-caps off and wipe them, and the plug insulators, clean.
    Do not try to jump-start it from a car! :)
    Theo
    Theo Bekkers, Dec 3, 2003
  4. Damien
    Aido Guest
    Why not Theo? I used to jump my old 650 Kat from the workven all the time,
    That's until I got a new battery for it.
    Aido, Dec 3, 2003
  5. Damien
    Damien Guest
    yeh cause I been trying to start it every ~hr and the battery is getting
    flat so I am going to have to jump it soon ?! other what i do ?
    Damien, Dec 3, 2003
  6. Damien
    Dave Mojo67 Guest
    Agree, and charge the battery overnight before you try it again. You'll end
    up killing the battery.
    Dave Mojo67, Dec 3, 2003
  7. Damien
    RM Guest
    note smile after jump start statement...i think indicating that you should
    not attempt to countersteer a shaftie :)
    i'd reckon wet electrics...more likely than water in airbox / carb etc
    RM, Dec 3, 2003
  8. Damien
    Naah; just tow it behind your mates car up to 50 or so then jam it inta'
    first and hang on!!
    Keep revving the crap outta' it and it'll eventually dry out and run on all
    four.
    Knobdoodle, Dec 3, 2003
  9. Damien
    Damien Guest
    Thanks to all. I got it started again :)
    Tried a few more starts and it didn't work and battery was almost dead so
    jump started it from a car and after a few attempts, it turned over and now
    seems relatively happy.
    Damien, Dec 3, 2003
  10. Damien
    Theo Bekkers Guest
    "Damien" wrote
    Just kidding. See the 550 thread for the full argument.
    Theo
  11. check coil, it could be on way out,
    Michael Chester
    Baileyana Embroidery, Dec 4, 2003
