Stator plate came loose
Discussion in 'Motorcycle Technical Discussion' started by midwestmotocross, Dec 1, 2005.
  1. The stator plate came loose on my 1981 XT250. The bike apparently ran
    for some time with a pretty loose stator because when it finally did
    stop and I took off the ignition cover, it was loose enough for the
    lighting coil on the stator plate to be dragging on the flywheel
    magnets.
    Anyway, no spark now. I can see some minor damage on the aluminum of
    the stator plate itself where the flywheel rubbed. It's right across
    the wires for the pulser coil, although the actual wires, which sit in
    a recess, don't look like they were touched (grime still on the
    insulation).
    Still, I figure the shock of the stator hitting the flywheel knocked
    something loose--and the markings on the plate hint at the pulser
    coil--but the OHM readings check fine for: the pulser coil, the
    charging coil, the ignition coil and the plug cap.
    This leaves the CDI box, but I don't see how the loose stator caused
    that.
    So, do these clues suggest I need to analyze the stator coils more
    thoroughly or just assume it's the black box--i.e., could it have been
    damaged from this happening?
    (FYI, this XT has had the battery and lights removed.)
    Thanks.
  2. midwestmotocross
    CK Guest
    Read what www.electrosport.com has to say about your stator. They may
    or may not build replacement stators, but they have information about
    stators even when they don't make one for your machine.
    Are the magnets still strong? Rubbing against the stator may have
    weakened the magnets. Do you get any reading between the CDI source
    coil and the crankcase on
    R X 1000 ohms scale? Maybe the CDI coil is shorted out? I would guess
    that the CDI source coil would put out 50 to 100 volts. The pulser
    coils probably put out 1.5 to 2.0 volts when the engine is kicked over.
    You'd probably need an analog voltmeter (needle type) to see the output
    from the pulser coil, a digital meter would be too slow to respond.
    CK, Dec 1, 2005
  3. midwestmotocross
    Wudsracer Guest
    James,
    Ricky Stator will check out your stator and pulser coil. If it
    doesn't need repair, he will send it back to you for only the cost of
    shipping. He has done this for me several times, and has also stood
    behind his repair work (eating the shipping costs).
    Tell him that I sent you.
    Jim Cook
    Smackover Racing
    Gas Gas DE300
    Team LAGNAF
    www.smackovermotorsports.com
    Wudsracer, Jan 3, 2006
  4. Thanks, Jim. Actually, I checked everything again and I must have
    missed something before because the pulser coil came back bad (~20
    OHMs). A few weeks ago, I got an '84 XT stator plate (all coils) and
    finally got around to splicing in the '84 pulser coil. The connections
    were different ('84 grounded on stator plate and ran one wire to the
    cdi while the '81 ran both up), but I got a spark and it runs same as
    before (meaning lean). Thanks, again
    midwestmotocross, Jan 4, 2006
