still no joy
Discussion in 'Australian Motorcycles' started by homeless penguin, Sep 9, 2005.
  1. I gave up on trying to get the front sprocket off, and went on with
    the many other jobs on the list instead. However, now that everything
    is on it's way back together, it's time to start thinking about that
    bloody sprocket again.
    It just absolutely refuses to budge. Even with a nice long extension
    bar, all that happens is the bar bends. The bolt just will not move
    even a fraction.
    So does anyone have any hints? How do you remove the front sprocket
    when you just can't get the bolt to move at all? I've tried everything
    I can think of, but I'm out of ideas! Any suggestions that work would
    be VERY much appreciated. :)
    On another note, a pistol-grip C-clamp (they probably have a better
    name, but you'll know the ones I'm talking about anyway) plus a long
    socket with a section cut out works *very* well as a valve spring
    compressor. Quite easy getting it all back together, and worked out a
    damn sight cheaper than buying a VSC that would have done the job,
    since I already had both clamp and socket anyway. :)
    Damien
    GPX250 -> CBR600 -> Shadow?
  2. What Length bar are you using?
    Buy a quality breaker bar & socket from a toolshop.
    Then stock a 1m long lump of water pipe over the end of it.
    Or hire an Aircompresssor and get it off with a rattle gun.
    I presume that the thread is not back to front or there is no lockig tab
    holding it in place?
    Zaphod Beeblebrox, Sep 9, 2005
  3. homeless penguin
    J5 Guest
    yeh could be LH thread :)
    J5, Sep 9, 2005
  4. About 2ft long.
    Got a compressor, and already tried a rattle gun. Of course, there's
    always the possibility that neither is quite up to the job.
    Well, general consensus seems to be that it's RHT. :) There's nothing
    to indicate LHT anyway, and there's no locking tab. It's just on very
    fucking tight indeed.
    I've totally blown my budget anyway, buying tools and parts, so
    there's no money to buy a chain just yet. So if I can't get the
    sprocket off then I'll just focus on getting the bike running first,
    and then when I have the money for the chain will trailer it around to
    the bike shop and let them worry about it. I'd still like to get the
    bastard off myself (cos then I fit the chain myself and save some
    money), but right now the bike shop is looking like the best option.
    Damien
  5. Tried heating the nut? Get it reeeal hot and then try to loosen it.
    Otherwise, take to it with a grinder, trying not to get the shaft
    threads. Sacrifice the nut.
    Regards, Andrew.
    Andrew Puddifer, Sep 10, 2005
  6. yeah, it'll be a right hander
    try a bit of heat on the nut
    get a longer bar
    take it to a truck tyre shop...they have BIG rattle guns
    if all else fails, cut the nut off with a cold chisel and get another one
    this is how we used to do Mazda rotary crank nuts, which are tightened
    to 400N/m or something silly
    surely if you trailered it to the bike shop, had the covers and stuff
    off, bought the chain & sprockets...they would see their way to undo &
    redo the nut for you?
    they used to do stuff like that anyway
    fulliautomatix, Sep 10, 2005
  7. Previously damaged and welded back in place as a "temporary fix" so it
    wouldnt fall off? Don't laugh, I've heard of it happening (and the one guy
    I know that will admit to doing it used to post here in Aus.moto, a honda
    V-twin dirt bike rider)
    Al
    Alan Pennykid, Sep 10, 2005
  8. homeless penguin
    Gixxer Guest
    I had difficulty getting one off a friends GSX600F, ended up trailering it
    to the local bike shop where they tried a rattle gun with no luck. Luckily
    I was mates with the guys in the shop cause it took about 30 minutes and in
    the end it took 3 guys hanging off a 5-6 foot bar to get the thing off. I
    dropped in a couple of dozen the next day, it pays to stay friends with
    those guys.
    Keep trying.
    Gixxer, Sep 10, 2005
  9. To add to the fun, I managed to snap one of the bolts for the inlet
    camshaft bearing cap, which pissed me off no end! So now I'm pretty
    much stuck until I can get the bloody thing out. Otherwise, it's all
    going back together well enough so far...of the course, the real test
    will be when it comes time to turn the key again! **** knows where
    some of those bloody hoses go tho...lol
    Damien
    homeless penguin, Sep 10, 2005
  10. homeless penguin
    atec Guest
    Have you checked the thread has not been center punched , I will assume
    the nut flats have not been notched for a left hander ?
    Can you see any clear stuff like nail varnish on the thread as I suspect
    it may have been locktited
    in which case you need a fitting socket( impact socket is best ), a
    decent bar and about 2 meters of thick wall tube , now remember its not
    a slow turn but a shock from you jumping on the bar that will shake it
    loose ( bike help in gear and what ever to stop it turning)
    good luck as you will need it .
    atec, Sep 10, 2005
  11. homeless penguin
    Psycho Biker Guest
    if it's got locktite try eucalyptus oil (about $3 from the chemist or
    woolies), it eats the locktite real fast, it also eats chain lube etc .
    Psycho Biker, Sep 10, 2005
  12. homeless penguin
    Johnno Guest
    If you have shaft or bolt exposed, RH is \\\\\\, LH is /////. Place a
    heavy hammer on one flat of nut and swift tap on opposite flat, around all
    flats should crack bond, then a tight fitting ringy or socket with a swift
    whack (or rattle gun) should move it. If it is locktighted, heat will break
    it. It doesn't need much heat. If you heat similar steel, say a screw
    driver past the point where it changes to a straw colour you will lose the
    temper in the steel. Blue is well overheated.
    good luck!!
    Johnno, Sep 11, 2005
  13. It's the bolt for the front sprocket, so the only visible part is the
    bolt head. And no, there does not appear to be any sort of markings on
    it at all. As for heat, well I dont really have anything to heat it
    with. Looking more and more like a job for the bike shop, I think. :)
    Damien
    homeless penguin, Sep 11, 2005
  14. homeless penguin
    Gavern Guest
    Had this happen to me once YEARS ago....
    Was in my brother's workshop to remove the chain and sprockets and the
    front sprocket nut refused to busge. Half an hour with a rattle gun,
    various lengths of torque arms and pipes up to 1500mm long.. and NOTHING.
    Brother's boss wanders over and comments that he's been watching the fun
    and can get it off in seconds.
    Gets a cold chisel onto one of the flats and in the direction of removal
    (ie on left flat) and with a nice hard clout of the hammer, the nut
    nearly spun right off the thread.
    Happy that it came off ..... HAppier still that he hadn't made a bet
    with us beforehand...!
    A nifty trick that I have had to use a number of times.... and at least
    once more on a sprocket nut..!
    Cheers,
    Gavern
    (Suppose next step if this fails is to cut the nut - cold chisel time
    again...?
    Gavern, Sep 11, 2005
  15. homeless penguin
    Theo Bekkers Guest
    I was about to say that, glad I read your post first. Stopped me looking
    like a Knob.
    Theo
    Sorry Clem.
    Theo Bekkers, Sep 12, 2005
  16. homeless penguin
    sharkey Guest
    Not me! I never changed the sprockets on mine!
    -----sharks
    sharkey, Sep 12, 2005
  17. Big Greg, welded it on so the XLV could complete the Condoblin 750
    Al
    Alan Pennykid, Sep 12, 2005
  18. homeless penguin
    sharkey Guest
    Ah, no, that'd be an XRV Africa Twin. The XLV is a shaftie.
    It's not actually entirely an unreasonable thing to do in some
    circumstances ... if you were careful and only welded a couple
    of little spots on the tops of the splines, you could probably
    file it back out easily enough when you got home ... wouldn't
    look all that nice though!
    -----sharks
  19. Yoo'ure write of coarse Sharks, I just forgot.
    Twasnt the AT either though it was the 600 Tranny before that.
    Al
    Alan Pennykid, Sep 13, 2005
  20. homeless penguin
    sharkey Guest
    Ah, well, fair enough. Who hasn't welded a Tranny to something?
    -----sharks
    sharkey, Sep 13, 2005
