Street Trip conks out again
Discussion in 'UK Motorcycles' started by The Older Gentleman, Apr 7, 2011.
  1. I stalled it at some lights on the way into work. Restart.... didn't.
    Dim warning lights, reluctant starter, then nothing.
    That'll be the new reg/rec failed, then.
    While waiting for the RAC I idly tried the starter again, and it went.
    Cancelled the RAC, got it home, stuck the multimeter on it, and it was
    reading 14.08 volts at tickover and 14.30 volts at high revs. Seemed a
    trifle high, but Rosners says that is absolutely within spec.
    All seems fine. Baffled. Taking it out again. Prace bets now.
  2. Sounds about right but it is only an indication of the voltage being
    produced, not the amount of work it is doing and is suggestive of the rr
    being fit for purpose.
    <considers probabilities>
    Did it travel more than 53 feet?
    steve auvache, Apr 7, 2011
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    Intermittent earth?
    Wicked Uncle Nigel, Apr 7, 2011
  4. The Older Gentleman
    Pete Fisher Guest
    Indeed, or the battery on the way out Voxan Roadster stylee. That used
    to be intermittent before it became terminal. At the Manx a couple of
    years ago it would be fine one day and pretty much flat the next. On the
    previous occasion it would be literally dead as a nit when you switched
    on, or seemingly OK in a random fashion. On those though the batteries
    get killed by the heat from the oil tank and rear pipe. Can't see that
    happening on a the Street Triple.
    | Pete Fisher at Home: |
    Pete Fisher, Apr 7, 2011
  5. The Older Gentleman
    Paul - xxx Guest
    Poor earth contacts? Poorly crimped connectors?
    Paul - xxx, Apr 7, 2011
  6. The Older Gentleman
    TOG@Toil Guest
    I dunno. It had a brand new battery when they replaced the r/r last
    year. And it seems fine now. I took the long way into work (as in blat
    round the M25 and in on the A12, just to put some decent miles on it).
    My neighbour did suggest a dodgy earth, but buggered if I know where
    to look for that.
    Rosner's said they've had some "issues" with the 675 r/rs, but I knew
    that last year when it went phut, because I had to wait 10 days for
    the uprated reto-fit one to come in. And it wears that now.
    I suppose the thing to do is wait and see if it does it again. I
    *hate* intermittent electrical faults and I don't like riding bikes
    with "will it, won't it?" hanging over my head.
    <Thinks>
    I mean, I own a Ducati, FFS. And, ironically, it's been the most
    reliable bike I've ever owned, with the possible exception of the K,
    but I've only had that a few years whereas I've owned the Duke for
    nearly 14 years now.
    TOG@Toil, Apr 7, 2011
  7. The Older Gentleman
    Mark Olson Guest
    Could indeed be an intermittent or just plain failed battery.
    About the only way you'll diagnose this is to fit a voltmeter that displays
    constantly whenever the bike is running. If it stops charging you'll suddenly
    see the voltage drop from 14-ish to the low 13s or high 12s. Or you may see
    high voltages (15+) which are boiling the battery dry. If you always see a
    decent charging voltage yet the battery still has episodes then look for
    either a wiring fault or a bad battery.
    Mark Olson, Apr 7, 2011
  8. The Older Gentleman
    Stephen Guest
    But fit the voltmeter where? Across the horn?
    And when it dips then you need to stop and wiggle the wires whilst
    watching the meter. Hopefully this will sort it out.
    In reality it won't. Electrical gremlins are horrible.
    Stephen, Apr 7, 2011
  9. From the clues we have so far I would start by looking close to the
    battery for either duffness or a loose/corroded connection
    I tried that once, it hurt.
  10. The Older Gentleman
    Dan L Guest
    <rummages in handy Ducati supplied list of reasons for non starting>
    Sticky fuel pump relay?
    Dan L, Apr 7, 2011
  11. The Older Gentleman
    Mark Olson Guest
    Why would I do that?
    Adding a voltmeter is quite popular for the sport touring crowd who add lots
    of electrical load to their bikes. http://www.fjrtech.com/getdbitem.cfm?item=8
    Agreed.
    Fitting a voltmeter won't guarantee a diagnosis, of course. It's just a
    way of getting more information about the state of the system.
  12. The Older Gentleman
    TOG@Toil Guest
    Nah. The starter was very reluctant to turn, and the warning lights
    went dim, and then it went dead.
    <Thinks>
    Could have been a dodgy starter relay, though. The battery terminals
    seemed nice and tight when I put the multimeter over them.
  13. The Older Gentleman
    Stephen Guest
    Well across the pos of the horn and the earth.
    It's a fused connection coming from the wiring. Connecting a new set
    of cables for a voltmeter straight to the battery probably won't help
    if the fault's in a wiring loom connection.
    Yes... but this is to check the charger's working. TOG's problem
    sounds like something's broken so the important thing is to measure
    after the break, not at the battery (unless it is a faulty battery
    which I'd think most unlikely)
    As others have stated it's probably a poor connection somewhere. I
    had a cracked terminal post clamp once which took bloody ages to find
    since the crack wasn't easily visible. Vibration caused it to open
    and resulted in misfires etc.
  14. The Older Gentleman
    Stephen Guest
    Did the engine stall because of poor clutch operation, or did it just
    'stop' running at a standstill?
  15. The Older Gentleman
    RB Guest
    I'd say you'd be best off testing for volt drop. There are some clear
    notes at:
    http://www.aa1car.com/library/voltage_drop_testing.htm
    Regards,
    RB
    RB, Apr 7, 2011
  16. The Older Gentleman
    TOG@Toil Guest
    It stopped because of rider error. I just fumbled the take-off.
    But the re-start didn't happen, as detailed.
  17. <fx: stamps feet>
    No, seems pretty consistent here.
    PipL alter ego, Apr 7, 2011
  18. The Older Gentleman, Apr 7, 2011
  19. The Older Gentleman
    Tim Guest
    That'll be because it's a warm day and your airbox got toasted. The
    little sensor in there told the computer to change the fuel mix with the
    results you experienced. My 595 does this as well. In fact I think you
    witnessed it do so on a French run a while ago.
    Tim, Apr 7, 2011
  20. The Older Gentleman
    Simon Wilson Guest
    So, changing the mixture results in dim warning lights and sluggish
    starter. Riiight.
    Simon Wilson, Apr 7, 2011
