Stripped Splines on Kick Starter ...
Discussion in 'Classic Motorcycles' started by Jools Chappell, Apr 17, 2004.
  1. Hello everyone,
    While taking the XS750 and the Lovely Kim down to Dungeoness last night, it
    emerged that there are some electrical "issues" with the bike (i.e. pressing
    the horn or switching the lights on makes the engine backfire/cut out). So
    the kickstarter got used a lot, so the teeth got stripped from where it
    pinches on to the splined shaft. OK I realise that I have to get a new one,
    but in the meantime I need to start the engine to have a look at the
    'lectrics. Any ideas onyone?
  2. Jools Chappell
    Sean Guest
    Jools Chappell let forth with a mighty belch and uttered :
    Botch time :)
    You'll need some steel wire. A non-wound D or G string from a 'leccy guitar
    is perfect. Preferably using a triangular file, cut some shallow grooves in
    the hole in the kick start bit that clamps to the shaft. About 6 should do
    it. Remove the bolt completely and wedge a flat bladed screwdriver in so
    you can put the wire into the grooves. Bolt it up and you may have some
    success with that.
    My off road bike used that for years, but then again, a 2t 125 single
    doesn't take much kicking over.
    Sean, Apr 17, 2004
  3. Jools Chappell
    Kim Chappell Guest
    Botch time :)
    Blimey - didn't think I'd get an anwer to that one! Cheers Shaun :)
    Kim Chappell, Apr 17, 2004
  4. Jools Chappell
    Kim Chappell says...
    There is an easier way. Take 4 or 5 old sewing needles, loosen off the
    clamp bolt leaving the kickstart boss on the shaft. Hammer the needles
    into the bit between boss and shaft then clamp it up again. Always
    worked on SORD400s.
    Lozzo, Apr 17, 2004
  5. Sean's bodge may be insufficient for a 750cc triple.... why not just
    tack-weld on the kickstart lever? As you say, you have to replace the
    shaft anyway, and when you have the new shaft, just use an angle grinder
    on the tack welds and shaft.
    The Older Gentleman, Apr 17, 2004
  6. I've used that on gear levers and yeah, it works. A FOAD kick-starter on
    a 750 may be a different kettle of poissons, though.
  7. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Jools Chappell"
    Simple bumpstart, or tack weld the kickstart lever to the end of the
    shaft - you can simply angle grind it off later.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Apr 17, 2004
  8. *Ginge*
  9. It was somewhere around Barstow, on the edge of the desert, when the
    (The Older Gentleman) saying
    something like:
    Pah, six minutes.
    GS 850 x2 / SE 6a
  10. Jools Chappell
    Sean Guest
    Lozzo let forth with a mighty belch and uttered :
    Done that on gear levers. The idea of 'grooving' is to key the wire in to
    the kick lever so it can't move about. Would probably be better using pins
    rather than guitar strings, just that was all I had laying about last time
    I did it.
    TOG is probably right about it not being wholly effective against a 750
    triple. The ultimate solution, which will mean modifying the shaft, would
    be to get a recess cut in it, and a slot cut in the kick lever then use a
    woodruff key. Beats me why that was never done in the first place.
    Sean, Apr 17, 2004
  11. Jools Chappell
    Sean says...
    Pins are a bit soft, needles are alot tougher.
    Lozzo, Apr 17, 2004
  12. bump it.
    Austin Shackles, Apr 17, 2004
  13. Jools Chappell
    Guest Guest
    Reminds me - if you're cutting up guitar strings or piano wire, make
    sure you're using the right sort of hardened wire cutters.
    My other half snapped half of one of the jaws off my favourite
    electronics snips when she decided to use them to cut a wire weight for
    her lace making (I think it was piano wire). If the un-hardened ones
    don't snap they notch nastily.
    "But dear they were wire cutters, weren't they?" <mutter>
    Regards,
    Simonm.
    Guest, Apr 18, 2004
  14. Jools Chappell
    taz Guest
    I had a little go at the pins idea - nothing worked for any length of
    time.
    If you are going to replace the shaft in the end then as a
    temp repair you could drill a hole through the kick starter
    and shaft and then put a masonary nail through the hole.
    If you do use this method the hole must be quite small
    (2/3 mm) and then tap a nail through that you get with
    plastic cable clips. Masonary nails are hardened and will
    take the shear forces that would be present.
    Cheers taz.
    taz, Apr 19, 2004
