Struggling for speed
Discussion in 'UK Motorcycles' started by hairydolan, Mar 5, 2007.
  1. hairydolan
    hairydolan Guest
    Hi,
    I've just bought my first motorcycle (a Chituma CTM 125) and it's
    struggling to get above 50 mph. I was hoping someone here could give
    me a hand with where to start figuring out what's wrong with it.
    Thanks in advance.
  2. hairydolan
    Monkey Guest
    What leads you to believe that its top speed should be in excess of 50mph?
    Monkey, Mar 5, 2007
  3. Is it brand new? Are you over 15 stone?
    Mungo \Two Sheds\ Toadfoot, Mar 5, 2007
  4. hairydolan
    Pete Fisher Guest
    A 125 single cylinder custom bike ? Sounds about as much as you can
    expect to get out of it to me.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 5, 2007
  5. hairydolan
    Dr Zoidberg Guest
    A chinese copy of an ancient japanese 125 probably won't do much more than
    50mph
    Alex
    "I laugh in the face of danger. Then I hide until it goes away"
    www.drzoidberg.co.uk www.ebayfaq.co.uk
    Dr Zoidberg, Mar 5, 2007
  6. Silly bastard.
    The Older Gentleman, Mar 5, 2007
  7. hairydolan
    Rich B Guest
    I think Bike reviewed this one in November last and reckoned it was good for
    about 135 tops. It was making 95bhp at the wheel, 105 with the optional
    Akras. IIRC, the only faults they found were the height of the bars (too
    low) and the monoshock, which was too high. If it's only getting to 50, and
    it's been correctly run in, I would suspect a faulty water/oil metering
    nodule or possible a thrust phaser out of whack. BICBW.
    Rich
    2001 Disco II ES auto
    1971 S2a 88" petrol
    2006 Bandit 1200S
    Take out the obvious to email me.
    Rich B, Mar 5, 2007
  8. hairydolan
    Hey, Jonny Loundeye, you come to light prace. You buy Plemium Chinee
    moto-sickle, eh? You rearwy expeck it to do more than fiftee of your
    miwes per hour? You havin' fuckin' gweat raff, Jonny.
    Frow the fucker off Beachy Head, Jonny. It then go same speed as all
    those CG125 POS that lie at bottom of criff, washed every day by
    shitty North Sea, that even south coast pikeys won't wheel off beach
    and sell on ebay.
    **** you, Jonny Loundeye. Even my sister hate you, rong time.
    Pip, Mar 5, 2007
  9. hairydolan
    Rich B Guest
    Rich
    1971 S2a 88" petrol
    2006 Bandit 1200S
    Rich B, Mar 5, 2007
  10. hairydolan
    Moon Badger Guest
    Is it a new bike?, if so, change the oil for something that doesn't resemble
    camel tallow. Any 10/40 recommended for motorcycles will do.
    Now, don't thrash it until it has done 500 miles, then change the oil again.
    These bikes really do need the oil changing at 50: 500: 1000, and then
    every 750 miles. They only take a litre, so it won't break the bank.
    They are under geared and easily pull an extra tooth on the front sprocket.
    If you are quite light, try two extra teeth on the front. Sprockets for
    these are the same fitting as the blessed CG <MSOHPR> and are only a few
    quid each.
    They are set to run too lean, almost dangerously lean. Raise the carb needle
    to its highest setting. This richens the mixture up on full throttle, flat
    out running and gets it close to where it should be.
    The original sparking plug is not much use, nor is the original metal plug
    cap. Replace these with NGK.
    Check the valve clearances. They don't come accurately set from the factory.
    If you want to stay in the seat over bumps, and don't fancy sliding about on
    wet roads; replace the tyres with Metzler ME22s and replace those ghastly
    rear suspension units with some that have a semblance of damping.
    Fit an inline fuel filter. The fuel tank has a lot of overspray inside and
    the paint flakes off and clogs the float valve.
    Moon Badger, Mar 5, 2007
  11. hairydolan
    TMack Guest
    Its a Chinese copy of the Honda CG125. If it is brand new then the engine
    will be a bit tight so it won't achieve its maximun speed for 500 miles or
    so. Don't thrash it too much straight away as it needs to be "run in" for
    the first 500 miles. It will also be worth checking what sprockets it has
    fitted. You may find that a slightly larger front or smaller rear sprocket
    will improve top speed (at the expense of acceleration). However, even at
    its best dont expect more than around 60 to 65 mph.
    TMack, Mar 5, 2007
  12. hairydolan
    TMack Guest
    Nope, CG125 copy
    TMack, Mar 5, 2007
  13. hairydolan
    Beav Guest
    Did it go any faster when you test rode it?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 5, 2007
  14. hairydolan
    Pete Fisher Guest
    Oh, yes I see. Only the CTM 50 is a 'custom'.
    Interesting to see that the official factory web site only claims 85
    KPH. So as others have said possibly under-geared as standard.
  15. hairydolan
    Cab Guest
    You are wrong. The thrust phaser was only introduced on the 250 version
    before it was withdrawn from the market following a few deaths caused
    by the fact it was 115bhp on a 250cc lump.
    Cab, Mar 5, 2007
  16. hairydolan
    Cab Guest
    You daft bugger. VBG.
    Cab, Mar 5, 2007
  17. hairydolan
    TMack Guest
    Raising the needle won't affect full throttle - that is determined by the
    main jet. Needle affects 1/4 to 3/4 throttle
    One thing that I didn't mention in my other post is that the exhaust may be
    double-skinned with an undersize interior tube that restricts outflow
    (possibly to meet some kind of emissions requirement in one of their
    markets). Replacement with a cheap CG125 exhaust from David Silver may help
    improve performance overall. They do one for the CG125 K1/B/C/E for £29.95
    that should be a simple replacement requiring no modification.
    TMack, Mar 5, 2007
  18. hairydolan
    muddy cat Guest
    Fewer pies.
    muddy cat, Mar 5, 2007
  19. hairydolan
    muddy cat Guest
    *snort*
  20. hairydolan
    Tosspot Guest
    Chicken Chow Mein with Prawn crackers please.
    Tosspot, Mar 6, 2007
