I was just rearranging the garage to make room for the latest addition, due in a couple of hours. The garage has free standing wooden shelving (the four posts with shelves between sort) down the left hand side and kit car and bikes on the right. The rear fifth is separated by an internal wooden wall with a door which opens onto the left wall in the only space that doesn't have shelving. So you've got to go in at a slight angle past the shelves and then straighten up to go through and then hopefully turn right into the space prepared for the Benly and old ZXR to be worked on. After getting the rear left indicator stuck on my shelving (which rocked alarmingly but didn't fall over) I've now managed to jam it half way through the door into the back bit. It's caught on the back brake pedal - so the foot rest definitely will not fit through. I can't go backwards because the rack is up against the shelving I just inched it past. I've tried lifting the back wheel and edging it sideways but the handlebars are tounching the wall of the back bit on the left. Now what do I do?
