stuck jet extraction
Discussion in 'Motorcycle Technical Discussion' started by jseely13, Sep 1, 2004.
  1. jseely13
    jseely13 Guest
    i think my pilot jets are clogged, because my bike dies when i take
    off the choke, and needs a little throttle to start.
    i took off the carbs and soaked the jets in wd40 for a day or so. i
    managed to get one out, but the other won't budge, and i really worry
    about breaking it. any pointers? kroil? impact driver? i'm having
    a hard timing finding a thin enough screwdriver that fits well...
    what if i do break it? i tried extracting a broken one from an old
    carb i have, but the reverse screw bit just chewed up the jet.
    is there some good reason these things are made of brass instead of a
    durable metal, or is it just a conspiracy to frustrate shadetree
    mechanics?
    thanks,
    -- john
  2. jseely13
    Mark Olson Guest
    Gunsmiths use precision flat screwdrivers[1] in a finely graded array
    of sizes. I have had occasion to break out my Chapman gunsmithing
    screwdriver set to remove carb jets. You want a screwdriver blade
    that fits *exactly* the width and thickness of the slot in the jet,
    you won't need an impact driver. You might give the driver a tap
    with a tack hammer to help jar the jet loose, but I'd be surprised
    if that was necessary.
    [1] The sides of the blade are ground exactly parallel, you do not
    want a screwdriver that has any taper to the blade.
    Scroll down to Kit No. 1000 on this page:
    http://www.mytoolstore.com/chapman/chaguns.html
    Mark Olson, Sep 1, 2004
  3. Now *that* is useful information.
    Ooooh! Tool porn. Shiny, shiny!
    I wonder if that's what I've got - I have a lovely little Chapman
    ratchet set, very like that, in a canvas pouch. It was in the toolkit of
    a bike I bought years ago, and I kept it.
    Some slightly odd sizes of allen key and screwdriver in it. The mini
    ratchet is a joy to use.
    The Older Gentleman, Sep 1, 2004
  4. jseely13
    jseely13 Guest
    aluminum seems like it would be a decent middle ground :)
    Mark, thanks for getting me on the screwdriver kick... I was about to
    order that set you suggested, but the sizes didn't seem quite right.
    So I grabbed a jet I'd already removed and ran down to Sears hardware.
    I found a "precision" screwdriver w/ no taper that fit almost perfect
    for 2.99. Grabbed it, ran home, stuck it in, prayed, and turned it as
    hard as I could. The jet loosened, and after about 30 min of working
    it back and forth, I got it out!
    Got the jets soaking in carb cleaner to get them ungunked, and hope to
    have the bike idling w/o choke tonight!!
    Bummer you got beat to the brass. On the non-corroding ship kick...
    If you're ever in southern jersey, head down to Cape May and you can
    see a wrecked concrete ship. I don't think it'll be reclaimed by
    water, salt, and oxidation anytime soon ;)
    jseely13, Sep 2, 2004
  5. Probably too thermally sensitive -- and maybe soft; who wants
    jets changing size from temperature and/or the friction of fuel flow.
    Dennis Lee Bieber, Sep 3, 2004
  6. jseely13
    Warren Weber Guest
    Is there some reason they could not be a hex head or a recessed allen?
    Warren
    Warren Weber, Sep 7, 2004
