Stuck Screws
Discussion in 'Australian Motorcycles' started by Dr. Big Maggot, Jul 5, 2004.
  1. If anyone has ever worked on an old, weathered bike, you've probably come
    across the dreaded un-removable master cylinder screws. My XJ650 is in dire
    need of some brake maintenance, but I can't remove the damned screws.
    I've tried WD40, Penetrene and other similar agents, all to no avail. The
    head of the screw (philips) still has a fair amount of "bite" left so I
    still have options.
    Does anyone have any ideas?
  2. In aus.motorcycles on Mon, 5 Jul 2004 15:25:43 +1000
    Got an impact driver? They are cheap enough to buy.
    If that doesn't work, a drill and a very steady hand....
    Zebee
    Zebee Johnstone, Jul 5, 2004
  3. Dr. Big Maggot
    Black Bart Guest
    If you still have something for the philips head to grab onto, then use an impact driver and hammer.
    You don't have to bash shit out of it, just a few taps to loosen the screw enough to get a
    screwdriver
    to undo it without making things worse.
    Black Bart, Jul 5, 2004
  4. Dr. Big Maggot
    sharkey Guest
    Valve grinding paste (in the screw slots). Stops the driver slipping.
    And use an offset screwdriver or socket or similar to get some
    torque on it..
    Failing that, it's time for Mr. Drill or Mr. Dremel. Once the
    screw heads come off, you can generally undo the threads with
    pliers.
    -----sharks
    sharkey, Jul 5, 2004
  5. Dr. Big Maggot
    Gavern Guest
    Quite apt the last line....... from my old LC250, RZ500 & FZ750 I have come
    across this kinda thing on numerous occasions. Was never beaten once.
    First thing to do is to try and TIGHTEN the thing (just a little) to crack
    the thread lock.
    (Actually worked a couple of times)
    Second was a few light taps on the back of the hammer as you twist
    Third was a few fairly decent taps on the back of the hammer as you twist
    (The most sucessful for screws not entirely rooted)
    Fourth would have been an impact driver... but I never found a bit small
    enough to fit the small screw
    Fifth was a flathead the width of the phillips cross smacked in a few times
    to make new "purchase"
    Sixth was to do the fifth again and then use either the flathead or a
    pointed drift tapped at 45degrees across the head and engaged in the slot,
    and around in the direction of loosening.
    (If Second failed then this more often than not worked))
    Lastly and only once did I have to drill the thing out.... but i must have
    been lucky, cos I used a driver-drill with a 2mm (?) bit and let the thing
    "bite" and whacked it in reverese and the screw unwound. Maybe a Dremel
    drill kinda thing without the drill flutes and use the drill in
    reverse....??? May begin to drill and then "bite" and unscrew the
    thing.....???
    Good luck,
    Gavern
    Gavern, Jul 5, 2004
  6. Dr. Big Maggot
    Moike Guest
    Before you do anything too destructive, pop into your local "Supercheap"
    store and get one of their nifty screwdriver sets. The one in question
    consists of a set of assorted screwdriver bits with a chrome 'L'-shaped
    handle and extension all attached to an orange plastic holder that can
    hang on your belt.
    About $7.
    The L-shaped handle lets you get lots of leverage on the screwdriver
    bits. I've used it to shift some very stubborn screws. You might want
    to buy some better quality screwdriver bits for it. I have managed to
    break one under stress (well, actually, it was Goaty).
    The grinding paste trick is a beauty as well (although some fine
    scrapings off wet and dry sanrpaper mixed with a little water might do
    as well).
    The problem with impact drivers in this sort of job is that the "impact"
    needed to operate them might do irreparable damage to the item being
    repaired.
    Moike
    Moike, Jul 5, 2004
  7. Dr. Big Maggot
    Dee Guest
    Another option you can try is to heat the screw with a little pencil
    torch, should come out fairly easy after that
    Dee, Jul 5, 2004
  8. Dr. Big Maggot
    Mad Biker Guest
    Go down to a bargain shop and buy some eze out screws for about 10 bucks...
    then drill the buggers out with a slow and cordless drill - they will just
    pop out once you have a deep enough gap in the head..
    then go find some screws to replace it with :) most bike shops have a
    selection.. from 27c each
    Mad Biker, Jul 5, 2004
  9. Dr. Big Maggot
    sharkey Guest
    Not a wonder, most of us would be stressed to breaking under Goaty.
    -----sharks
  10. Dr. Big Maggot
    Eddie Guest
    As Gavern said in one of his suggestions..
    Tap the handle of the screw driver as you turn it. Works almost as good as
    an impact driver....and is cheaper.
    Eddie
    Eddie, Jul 5, 2004
  11. Don't know if the L-shape handle is the same but a tool I've used
    quite often at work is a Speed brace. The tightening method and paste
    in the slotts definity have their merits as well. I've used another
    great tool called a Gut-buster but I think it may be a little too big
    for this job
    __
    Cheers
    The Happy Drunk
    K100RT
    The Happy Drunk, Jul 5, 2004
  12. Dr. Big Maggot
    1) bash a slot in it with a flatblade.
    2) drill the head off. (The rest generally unscrews quite easily)
    Knobdoodle, Jul 5, 2004
  13. Dr. Big Maggot
    Goaty Guest
    Goaty under stress is not a pretty sight![1]
    Cheers
    Goaty
    1. *I* wasn't the one who insisted on needlessly dismantling the trailer ...
    Goaty, Jul 5, 2004
  14. Thanks to all who posted suggestions. This is the first time that I've ever
    seen a question answered with so many serious and useful responses... (where
    IS Hammo?).
    In the end, the "bash it with a flatblade screwdriver" option worked. I did
    the brake fluid change that I so desperately needed, and now have a nice,
    stiff lever.
    Thanks again.
    Dr. Big Maggot, Jul 6, 2004
  15. Dr. Big Maggot
    Matt Palmer Guest
    Dr. Big Maggot is of the opinion:
    It's important that your lever is always stiff.
    - Matt
    Matt Palmer, Jul 6, 2004
  16. Dr. Big Maggot
    [smug look]
    Clem
    Knobdoodle, Jul 6, 2004
  17. Dr. Big Maggot
    sardo numspa Guest
    youll be lucky if you get an intelligent answer out of this lot
    sardo numspa, Jul 7, 2004
  18. Dr. Big Maggot
    Moike Guest
    Feeling a little silly are we?
    You really should read the other responses before you vent your pathetic
    little spleen.
    Moike
    (is it still harsh week?)
    Moike, Jul 7, 2004
  19. Dr. Big Maggot
    Moike Guest
    although there was my reply to sardo that I attached to Dr Big's
    post..... that's pretty silly.
    Moike
    Moike, Jul 7, 2004
  20. Dr. Big Maggot
    R1100Smee Guest
    Caught your post later moike.
    R1100Smee, Jul 7, 2004
