success! found cause of wobble
Discussion in 'Motorcycle Technical Discussion' started by David Allen Trimm, Jun 8, 2004.
  1. for those of you who gave suggestions, I found the problem. I live in
    southern California, and found out the one thing you never do: Never buy
    new tire for you bike that have a water groove straight down the center of
    the tire. Because here in California we have rain grooves cut into the
    concrete roadway, and the grooves in the roadway fit in the groove in the
    tires and creates wobbling, cause the roadway is not cut straight. And this
    on a 82' cm450 is dangerous!
    thanks for your suggestions
  2. God, that takes me back!
    In France, the autoroutes used to be grooved like that. "Rainurages",
    they called them, in a bizarre mix of French and English.
    And they used to make bikes do all sorts of horrible things, which I
    think is one reason why they gave them up. I had no idea they still
    existed anywhere, let alone in the US.
    The Older Gentleman, Jun 8, 2004
  3. David Allen Trimm
    bowman Guest
    The US even has specialized machinery called 'rotomills' to hack grooves
    into perfectly good pavement. It's only a temporary situation before
    repaving, but that is of little comfort after riding 10 or 20 miles. If you
    stay loose, you usually go more or less where you wanted to go.
    bowman, Jun 9, 2004
  4. This is true. I remember the advice on rainurages was to relax your hold
    on the bars. Grip them like fury, and the wobbles got worse.
    The Older Gentleman, Jun 9, 2004
  5. It can also help a lot to raise your tire pressures by a couple of pounds.
    Rob Kleinschmidt, Jun 9, 2004
  6. It can also help a lot to raise your tire pressures by a couple of pounds.
  7. It can also help a lot to raise your tire pressures by a couple of pounds.
  8. David Allen Trimm
    Mark Olson Guest
    So, somewhere around six pounds should be about right, eh?
    Mark Olson, Jun 9, 2004
