Suggested tires for an '84 K100RT
Discussion in 'Australian Motorcycles' started by Damien Gardner Jnr, Jan 10, 2006.
  1. Damien Gardner Jnr
    G-S Guest
    The Metzler range of 'narrower' has been consolidated into one tyre
    (Lastertec) and the ME33 etc are no more (although many dealers still
    have stock).
    G-S
    G-S, Jan 11, 2006
  2. Damien Gardner Jnr
    G-S Guest
    There is a period of vibrations on many earlier 4 cylinder K series
    bikes which unfortunately coincides with the 100 to 110 highway area.
    G-S
    G-S, Jan 11, 2006
  3. Well Fuel, because my holidays usually run christmas->newyear, so it's quite
    normal to find that small servo's aren't open, so you might have 500km
    betwen fuel stops.. Oil, on the ZZR wasn't such a problem on the highway
    (when it got hot in the city, oil dribbled out around the drive shaft to the
    front sprocket), but on the old XS250, and XJ750, they'd eat a good
    1L/1000KM of oil, so i made sure to take bike oil with me, cause buying bike
    oil anywhere outside of a bike shop seems to be hell.. The XJ was a 'fun'
    bike to tour on.. Plugs and oil change every 3000km, so I actually dropped
    the oil and replaced oil and filter at the campsite at Port fairy, got some
    strange looks from the campers beside me.. Ended up with sticky piston
    syndrome on the way back from mt gambier, so I borrowed a card table from
    the campers beside me where I camped at the grampians, covered it with quite
    a few layers of tarp, and proceeded to strip down and do a full clean and
    lube on the carbs..
    Guess I won't have that sort of problem anymore with the K100 - it just
    takes standard 20W50 car engine oil from what the manual says????
    Regards,
    Damien
    Damien Gardner Jnr, Jan 11, 2006
  4. Damien Gardner Jnr
    CrazyCam Guest
    Well, you obviously travel in more sparsely populated areas than I ever
    did on my K. I used to find that I could get over 300 kms from a tank
    (except trackdays!) and generally, I felt like a stop well before I
    needed to stop for fuel.
    Yup. Also, BTW, in case you haven't noticed already, use the centre
    stand... it stops the cloud of blue smoke when you first fire it up
    after it leaning on the side stand.
    regards,
    CrazyCam
    CrazyCam, Jan 11, 2006
  5. Damien Gardner Jnr
    G-S Guest
    All this means that there is going to be even less choice (that above
    wasn't very well worded).
    G-S
    G-S, Jan 11, 2006
  6. Damien Gardner Jnr
    flightyswine Guest
    It's a Beemer, so it takes Metzlers. There's a good article on the web
    somewhere about vibes on K bikes. Something to do with exhaust mounts,
    among other things.
    flightyswine, Jan 11, 2006
  7. Damien Gardner Jnr
    ck Guest
    effectively it is a name change
    ME33 was a laser anyway
    Now you have Sportec, Roadtec, Racetec, Lasertec.......................
    ck
    ck, Jan 11, 2006
  8. Damien Gardner Jnr
    sanbar Guest
    Well, there you go. I hated the Macadams. They cupped after a few
    thousand kilometres[1], and were nothing short of slippery in the wet.
    OTOH, Metzelers were everything I needed, and gave 25k km for the fromt
    and almost 35k for the rear.
    - sanbar
    [1] Look at me before replying! Please don't say anything like "well,
    there's your problem, wrong tyre pressure" because I checked the tyre
    pressure every fuggen week. So piss off.
    1985 BMW K100RT|2004 Honda NT650V Deauville
    http://antifsck.dyndns.org
    sanbar, Jan 12, 2006
  9. Damien Gardner Jnr
    ck Guest
    stop pushing on the inside 'bar through corners.............once it is
    turned in let it go
    there ya go!! didn't mention your tyre pressures
    ck
    ck, Jan 12, 2006
  10. Damien Gardner Jnr
    Boxer Guest
    Sounds good what type of Metzeler are you using?
    Boxer
    Boxer, Jan 12, 2006
  11. When I rocked up to the bike shop, the Michelin man was there (aka the
    roving sales dude), who steered me away from the macadams as 'they cost too
    damned much', and pointed me at a set of metzlers.. Which funnily enough
    ended up being exactly the same tires as what was already on the bike..
    Will search around for that article on the vibes :)
    Regards,
    Damien
    Damien Gardner Jnr, Jan 12, 2006
  12. Damien Gardner Jnr
    Theo Bekkers Guest
    Well, I don't carry oil for a start. A table and chair is essential, as is a
    gas stove, gas lamp and two 1kg gas bottles, one man tent (the shop said it
    was a 4 man, but what would they know about my space needs), air mattress,
    pump, tube repair kit, spare tube, 4 pairs of gloves, cooking gear, 10
    litres of fuel, etc. But the whole lot comes to nowhere near 80 kg.
    Theo
    Theo Bekkers, Jan 12, 2006
  13. eh???
    Matto :)
    05 Sprint ST
    VelocityTheory, Jan 12, 2006
  14. Damien Gardner Jnr
    [shocked look] I must've turned homo when I wasn't watching!
    I'll be buggered....
    Knobdoodle, Jan 12, 2006
  15. Damien Gardner Jnr
    flightyswine Guest
    flightyswine, Jan 12, 2006
  16. Damien Gardner Jnr
    Boxer Guest
    Just put a new set of Michelin radials on my K100RT, 135/15 on the front and
    a 155/15 on the rear.
    Boxer
    Boxer, Jan 12, 2006
  17. Eh?
    The 140/80 only left a cigarette paper space between tyre and swing arm.
    How do you go with a 155?
    And a 135 on the front? Wow!
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s (gone on to better and brighter things - I hope)
    '87 BMW K100RT (write-off)
    '81 Yamaha Virago (XV) 750H (work in progress)
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    http://eladesom.com.au/ulysses/
    # 37181
    Peter Cremasco, Jan 12, 2006
  18. Damien Gardner Jnr
    Toosmoky Guest
    "If it doesn't fit in the tankbag, you don't need it."
    Toosmoky, Jan 12, 2006
  19. Damien Gardner Jnr
    Boxer Guest
    I mounted it on a VW wheel
    I had to use a non standard front end to fit it.
    It tracks really well, although I need the 145/10 on the side to hold it up.
    Boxer
    Boxer, Jan 12, 2006
  20. I can fill one of my bags OK but I hate having to hunt around for things,
    that I may have a remote chance of using, to pack in the bag on the other
    side.
    Pisshead Pete, Jan 12, 2006
