Suggestions for lightweight runabout?
Discussion in 'UK Motorcycles' started by TMack, Feb 20, 2006.
  1. TMack
    TMack Guest
    I have a CG125 (MTSOTHP) as my spare bike which is fine for buzzing about
    locally but if I need to go any major roads its just a bit too slow. I am
    looking for something a little bit quicker but I want it to be cheap to buy
    secondhand, lightweight, and easy to manoeuvre as I often need to negotiate
    two cars parked close together on my fairly narrow driveway (which also
    slopes significantly upwards towards the road.) Essentially something which
    is fairly easy to physically drag sideways if necessary. I have in mind
    something like a 250 single but I am open to any suggestions. Any
    recommendations?
    TMack, Feb 20, 2006
  2. In uk.rec.motorcycles, TMack belched forth and ejected the following:
    How about a nice GS450 that's in my sig?
    It'll need fork seals and a new rear tyre for the MOT next month but
    it's as reliable as you like. It'll do 85-90 pretty much flat-out and
    does about 55mpg give or take.
    Nowhere near immaculate but it does clean up nicely.
    Whinging Courier, Feb 20, 2006
  3. TMack
    JB Guest
    Lozzo's GPz500? Much cheapness. Very well looked after too I'll wager
    JB.
    JB, Feb 20, 2006
  4. TMack
    TMack scribbled on the back of a napkin:
    CB250RS?
    Timo Geusch, Feb 20, 2006
  5. TMack
    TMack emerged from their own little world to say
    KMX200[1], DR350[1], F650 [2]
    [1] if you can find decent ones: they are also very likely to be targetted
    by thieving scrotes
    [2] probably my choice for a bike to use around town
    wessie, Feb 20, 2006
  6. TMack wrote
    A 500 twin? My GS ain't hard to work and it does everything it needs to
    do, barring three figure speeds in the blink of an eye, around and about
    all the roads I might find in Sunny Essex.
    steve auvache, Feb 20, 2006
  7. TMack
    Eatmorepies Guest
    ER5. Mine has done 12600 miles, 1999, good tyres and is probably only worth
    £1200. If you have a look on Bike Trader you can get a tatty one with the
    odd ding in it for a lot less. I like it a lot and am only looking to sell
    it so I can buy something with a bit more room for a pillion.
    John
    Eatmorepies, Feb 20, 2006
  8. TMack
    JB said...
    Thanks. It's not up to my usual standards of niceness, as my for sale
    post said, but the work that has been done is to a decent standard.
    It's still for sale, and very cheap for what it is. I just need to make
    room in the garage.
    Lozzo, Feb 20, 2006
  9. TMack
    JB Guest
    I know that feeling all too well.
    If I had room in my garage/drive/garden amongst the other members of my
    'fleet', I'd have it myself. (I've still to break it to the SO that there
    will be another Guzzi 'materialising' soon too!)
    Cheers,
    JB
    JB, Feb 20, 2006
  10. I've just acquired two CD250s.
    Nice little bikes. Benly on steroids, and with rubber mountings for bars
    and footpegs. Top whack over 80: cruising speed 65, and really rather
    fun in a workaday fashion.
    The Older Gentleman, Feb 20, 2006
  11. TMack
    TMack Guest
    I've got a 500 twin thanks (CX500 - I know, I know) and it is a right
    bastard trying to pull it backwards (not enough room to turn it around)
    uphill through a narrow gap between two cars. I don't mind the effort if
    I'm going for a decent run but for just nipping down to the shops it isn't
    quite the ticket. Also - with something lightweight I can just drag it
    sideways without much effort to line it up with the gap beween cars rather
    than doing a 15 point back and forward routine. I know I could always move
    one of the cars but I can't park on the road outside the house so it makes
    it all too much hassle.
    TMack, Feb 20, 2006
  12. TMack
    TMack said...
    The original CX was a dinosaur when it was new in 1977. More modern 500s
    weigh about a third of what a CX does. They also go better, stop better
    and handle much better. You can't compare a CX to any modern bike at
    all, except maybe a Guzzi.
    Lozzo, Feb 20, 2006
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Eh?
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
    Wicked Uncle Nigel, Feb 20, 2006
  14. TMack
    Wicked Uncle Nigel said...
    They don't make CXs any more, but there are modern versions of Guzzi
    Californias etc.
    Lozzo, Feb 20, 2006
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Oh, all right then.
    Spoilsport.
  16. TMack
    TMack Guest
    A CG125 weighs about 200lbs which makes it easy to drag around. A GPZ500
    weighs about 375lbs which, whilst not massive, doesn't quite fit my concept
    of "lightweight" - but thanks for the suggestion.
    TMack, Feb 20, 2006
  17. TMack
    TMack Guest
    Your just rubbing it in aren't you? I was sooo tempted by that one on ebay
    that you ended up buying. Mind ewe they weigh about 350lbs and I really
    want a lighweight so it might not have been such a good idea. I probably
    need something like a GN250 (circa 266 lbs) or an SR250 (circa 295lbs).
    TMack, Feb 20, 2006
  18. TMack
    TMack Guest
    I know that the cx500 is a heavyweight dinosaur. However, even modern 500
    twins come in at nearly double the weight of a CG125 (circa 200lbs).
    Basically something under 300lbs that does over 70mph and isn't total shite
    would probably do.
    TMack, Feb 21, 2006
  19. TMack
    TMack Guest
    I KNOW the reputation of the CX500 but I rather like the durability,
    eccentricity and the multitude of very cheap spares. I also know that a
    modern 500 would weigh much less - but still enough to make it less easy to
    drag around than I would ideally like.
    TMack, Feb 21, 2006
  20. TMack
    as I said up there: Suzuki DR350 (286lb dry weight)
    wessie, Feb 21, 2006
