SUNL Chinese Trash
Discussion in 'Texas Bikers' started by Anonymous Sender, Sep 15, 2007.
  1. BUYER BEWARE!
    Thinking of buying a SUNL ATV or product? DON'T DO IT!!
    Below is what you can expect!
    Extremely low quality, no after the sale service or parts.
    SUNL is just a bait and switch JUNK dealer! Do not waste your money!
    http://www.complaintsboard.com/complaints/sunl-c14603/page/1.html#c25099
    49 days ago by R.e. Smith
    I bought my son a sunl go kart and it is also a piece of crap!!
    31 days ago by Tom H.
    We were a SUNL dealer but we had nothing but problems... One scooter came with out a gas tank! Another one had no ignition key; numerous DOA's. The parts department was totally non-supportive, we tried to get a wiring diagram and were told that we hadn't bought the scooter from them (Company letter-head, hmmm), so no support.
    http://www.complaintsboard.com/complaints/sunl-c869/page/2.html#c21464
    55 days ago by Mikus Cantrellion
    For those of you who have complaints about SUNL, you are correct. You get what you pay for, JUNK. I know this because I am one of you. I thought, when buying the 70CC quad, how bad could it be? Well, if I had the opportunity to do it again, I would buy the brand name. To add insult to injury, I then bought the 150CC go kart, based on price. Another mistake. The 70 never starts, when it does, it leaks gas all over the floor and drains the tank. One of the bolts for the exhaust was switched with the carb, creating an intake leak. (from the factory) even fixing this didn't fix the starting issue, so don't tell me I need to maintenance the unit. It should run right out of the box. I changed the carb and all it does it foul plugs. I have to keep a battery charger handy to to run it (when it starts). As for the 150, the intake manifold consistently separates from the carb when the engine travels and causes it to shut off. You think they would take this into account when designing.
    If they are clones, they must have been the quality rejects. Reverse is a nightmare and mine just shredded. They also run the brake cable right over the battery box so it's almost impossible to remove. Another engineering wonder. I could go on for a long time, but the moral of the story is, Buy the Brand name, SUNL is Inferior Scrap and will cause you grief and get your children hurt. It doesn't matter how much experience they have. When the carb lid unscrews from vibration and it runs wide open, you better hope it's you on there and not your child. I was fortunate it happened while I was testing it. If they are so good, why only a 30 day warranty??? For those of you who swear by them, I offer this to you "Even a blind squirrel finds a nut sometimes".
    http://www.complaintsboard.com/complaints/sunl-c869/page/1.html#c14115
    109 days ago by Terry Hebert
    I recently bought a sunl sld 29 125cc dirtbike. It broke the day i bought it. The bolts that hold the motor to the frame snapped while riding it. It hit me on my leg making a large bruise. After i fixed that the valves in both tires busted. Then the dealer charged me $35 for 1 tube but kawasaki charged $5 for a better tube. The sunl tube busted again the kawasaki didn't give a problem. Then my throttle cable broke. The price for a new one was outrageous. After i fixed that, the clutch cable broke again the price was outrageous. After that the bolts on the motor broke again making another bruise on my leg. Not only that parts break but they are of poor quality the clutch on it is very bad, and doesn't have any pull. The bolts on the suspension are always loose. I have to tighten them before during and after i ride. The chain stretches so fast that i have to tighten it two times a day. The chain has broken twice making me flip both times the bike landed on my leg, and i was onl
    y in 2nd gear. The bearing in the wheels are very bad i bent mine and had to change them, and they bent on level ground while moving very slow. The air filter is always needing to be cleaned. The carburetor is made of low quality and it floods for no reason. You can't find many parts to make it better. The sponsorship sticker on the bike are just stickers those parts aren't really on it. I think that everyone should get together and do something to stop them. And my problems can't be blamed on poor maintenance because i take care of it, all my problems happed within a month of buying it!!! And it is still breaking regret buying it everyday!!!
    http://www.complaintsboard.com/complaints/sunl-c19858.html
    2007-08-06 by David C. Antliff
    Not honoring warranty
    Complaint Rating: 100 % with 1 votes
    On June 29,2007, I purchased a 250cc off road go-kart for my son. I have had nothing but trouble with it since day one. We had the machine less than a day and the drive belt went, and I was charged $200.00 to repair it. The place where I purchased the machine did the work. They ended up putting the wrong belt and sending it back to me, with the wrong belt on the machine. Got the machine home and it was running worse than before. The machine had no pick-up, and would not climb out of my driveway, which by the way is less than a 3% grade. After a week of complaining to the owner of Motorcycle Madness, which is where I purchased the machine, I finally received the correct belt. The belt was installed, and the machine still would not run. I called back Motorcycle Madness and spoke with the owner about this problem. I told him that it did not work , and my son wanted his money back, the owner said to me that it will never happen, he will not get a new machine or his money back. He
    is not honoring the warranty for this machine.
    http://www.complaintsboard.com/complaints/869/page/2
    20 days ago by Bill Donovan
    totally agree that sunl sucks, we purchased a sunl 90 for one of our grandkids for christmas, no problem starting it but within 10 hours of our 7 year old grandson riding it the whole frame broke off at the swing arm.
    2 days ago by William Kanaley
    I BOUGHT A MOPED AND A SCOTTER THEY SHORTED ME PARTS ON ONE THE I CAN GET TO RUN NO PARTS AVABLE. I SOLD A 150CC SCOTTER IT QUIT AND I TRYED TO GET HELP FROM SUNL NO EMAIL ADDRESS FOR THEM IS ANY GOOD I NOT A HAPPY CAMPER EITHER. I THINK THE USA GOV. SHOULD GIVE THEM A LOOK AT.
    http://www.thesqueakywheel.com/complaints/2007/JUN/complaint14982.cfm
    NO PARTS JUST LIES
    I PURCHASED A MOPED FROM A PLACE CALLED MEGAPOWERSPORTS IN FLORIDA ON MAY 7,2007. wHEN I RECEIVED THE BIKE THE PARTS FOR THE STEERING HANDLE WERE NOT IN THE BOX. I CALLED MEGAPOWERSPORTS SEVERAL TIMES SINCE THEN BUT IVE ONLY GOTTEN LIES. I TRIED CONTACTING THE SUNL GROUP AND SPOKE WITH ADAM WEILY BUT STILL NO PARTS. ADAM WENT AS FAR AS TELLING ME THAT MY PARTS WERE BEING AIR FREIGHTED FROM JAPAN ESPECIALLY FOR ME. YEAH RIGHT. IT IS NOW JUNE 22 AND I HAVENT RECEIVED NOT ONE THING. IVE FILED A COMPLAINT WITH THE B.B.B IN FLORIDA AGAINST MEGAPOWERSPORTS AND I AM ALSO DISPUTING THE CHARGES WITH MY CREDIT CARD COMPANY. BOTH COMPANIES SUCK!!!!!!!!!!!!!!!!!
    Thanks very much for your support.
    Alexandra Philogene
    http://www.complaintsboard.com/complaints/sunl-c869.html
    2 days ago by Don Lang
    Not sure yet about the quality as I just bought this via a private sale. What I can say is it is very hard or so far impossible to find parts. The 200 cc ATV I purchased was missing the skid plate. For more than 2 weeks I have tried to find this part. I have contacted the Corporate offices, local dealer, (who says he's not even a dealer), the NJ office, Houston, Dallas... I have talked to the National Sales Manager who just blew me off. Left messages for every extension at the corporate office and just can't get a simple part. I am now having it custom manufactured. I hope the ATV lasts for 1 summer, that is all I expected. It had less than 1 hour use on it when I purchased it. The plastic was still on the seat. I can tell, I have been in business for nearly 25 years and have never seen anything like this company. Absolutely!!! BUYER BEWARE!!!
    http://www.complaintsboard.com/complaints/sunl-group-c13239.html
    Sunl Group
    Poor Quality product
    My son purchased a 110cc dirt bike from a distributor in WI with his own hard earned money on 7-4/06.
    He was told that this was a high quality product built and designed after Honda. Well let me tell you
    this is not true. We have had nothing but problems since this bike was purchased. After only driving
    this dirt bike 8 times, the frame broke and luckily he was not badly injured. We have sent many hours
    and a great deal of money on repairing this bike.
    The worst now is the dealer will not stand behind this product and repair or assist in getting this
    bike issue resolved.
    SUNL's UNSATISFACTORY BBB record
    http://dallas.bbb.org/commonreport.html?bid=15000591&language=1
    http://forums.atvconnection.com/messageview.cfm/catid/10/threadid/513487
    Glad to have found this site to vent on. My son bought one of these
    from NYDiscountmotors on Feb. 19 on ebay. Nothing but problems since
    it came out of the crate. Starter wouldn't work, so he was jump
    starting it for about two weeks. Place was going to meet us halfway
    between NY and CT to fix problem, then tells me to take it somewhare
    and they will reimburse cost. Did that and the day before we took it
    all of a sudden the starter worked. Guy up here looked at it, couldn't
    find why it wouldn't start before, needed headlight replacement. Was
    never sent. Then they won't reimburse him the $90 because it was now
    working. Then agreed to pay half, still haven't gotten it. Body parts
    are broken off, cheap plastic, In March the chain broke, $38 to
    replace that with a good chain By beginning of May, rear brake pads
    completly gone. Another $68 to replace them, once the guy found ones
    that matched. Yesterday, the front wheel is now sheared right off the
    axle. Luckily he was going around a curve and not going fast. These
    are a piece of $1000 junk. He rides in the woods on trails he and his
    friends have made and these bikes are just not rugged enough for that.
    He had a Polaris 90 Sport we got used for $600. That on had been
    flipped, crashed, drowned and never broke off a body part. On this
    piece of crap the entire right side from front fender to back is in
    pieces and other parts are cracked. He has sure learned a
    hard lesson for a 14 year old. NY Discount motors response is
    basically you get what you pay for. They are really mad because I left
    neutral feedback on them. Just said good sale, shoddy product, email
    for info before bidding. Ruined there 100% positive rating. Have asked
    me to recind it, was considering it, until the wheel incident. Sorry
    to go on so long, but just needed to vent. I guess buyer beware is
    really true. Thanks
    http://forums.atvconnection.com/messageview.cfm/catid/10/threadid/518264.cfm
    All the bad things you have read about SUNL are correct, why bother
    with JUNK!
    Things I've had go wrong in the first 3 months:
    1.) Chain broke after the "guard" squashed against it after casual
    trail riding...and I mean CASUAL.
    2.) Bolts to the swing arm axle adjuster fell out after a day of
    CASUAL riding, used red thread lock to fix it, took an hour to find
    them in the field.
    3.) Throttle cable got stuck after a day of attempted mud riding...my
    son held on for dear life!
    4.) Frame developed a crack near the lower swing arm joint...hmmm.
    5.) Gas tank developed a hair line crack after another day of CASUAL
    riding (this is when I decided it was no longer safe for my son to
    ride it).
    So, bottom line, if your having good luck with your SUNL, your among A
    FEW. Don't waste your money...that's all I'll say.
    Buyer beware!
    In April of 2006 I purchased 6 ATV's from a SUNL dealer thru EBAY.
    This dealer, who I will not name, has been so very helpful. I have no
    complaints at all about him. He has sent me box after box of parts for
    free. What absolutely floors me, is how incredibly poorly these things
    are made. My kids are all average sized, ranging from 6 yrs old to 11
    yrs old. They only ride them on the weekends in our 4.5 acres of flat
    as can be grass yard. No jumps, tricks, rough riding, nothing. These
    things have been an endless headache for me. I seriously can't tell
    you how many hours and hours I have spent trying to make these things
    work. Here are just a few problems I have encountered: CONSTANT carb
    problems-float needles sticking open causing the carb to empty the
    entire fuel tank all over the ground/floor. Needles sticking shut
    causing the engine not to start. Fuel lines cracking and leaking all
    over the hot engine after only one month of riding. Dead batteries
    every weekend causing me to need to jump start them off of my battery
    charger just to get them going. All of them have had the chains break
    at least once. The frame on one of the 110's broke in half where the
    swingarm meets while my 60 lb daughter was riding it, luckily she was
    not hurt. All of them have had parts break, fall off, loosen up, etc
    for no reason. I got to the point where I was putting Loctite on
    everything! I could go on and on. At this point, only ONE of the SIX I
    purchased is running. They are parked permanently. Now, I knew that
    these were not going to be as good as the Hondas that I originally
    wanted to buy (the Hondas are 5 times the $), but I didn't think these
    things would be so terribly made and downright dangerous. In the end,
    I guess you do get what you pay for. BUYER BEWARE!
    http://chinariders.net/modules.php?name=Forums&file=viewtopic&p=6462&highlight=
    I was a SunL Dealer couldn't get parts at all and filed against them
    through my credit card company. Endless Journey Cycles Ohio
    http://myvento.net/forum/viewtopic.php?t=3544
    Just picked up a brand new 150cc scooter by SUNL. Got it cheap, but as
    I am finding out, getting replacement body panels are difficult to
    come by. I email SUNL in Texas but they don't respond. I email a
    distributor in City of Industry, California, and they too don't
    respond. It would appear the SUNL is another fly by night company or
    run out of someone's bedroom.
    http://www.atvnation.com/forum/lofiversion/index.php/t11020.html
    Run away from anything that says SunL on it. We used to deal in their
    scooters also and they were nothing but problems.
