Suspension bits..
Discussion in 'UK Motorcycles' started by Spike, May 12, 2006.
  1. Spike
    Spike Guest
    OK, my bikes suspension is basicly shot. Not surprising really, considering
    that its had my lardy arse on it for 36K miles, and all of those on the
    fantastic smooth streets of Our Nations Capitol. Going round corners is now
    feeling very vague, and not at all confidence inspiring.
    Couple of things:
    When replacing the rear shock, is it always the case that you should replace
    the fork springs too? Or does a simple oil change do the job?
    Is it worth renovating the rear monoshock, or should I just spring (haha)
    for a replacement?
    The head bearings need replacing soon as well, which may have some bearing
    9haha again) on what other work is easiest done when the forks are out of
    the yokes...
    Please bear in mind that Im not a *complete* mechanical numpty, but most of
    this stuff is stuff Im doing for the first time...
    Tips please!
    Spike, May 12, 2006
  2. New fork springs is a good idea, and they're so cheap, really. Decent
    springs and new oil will make a helluva difference.
    It's way cheaper to have it rebuilt, and often better than buying off
    the shelf. Maxton and others do them for as little as £100. Compare this
    with as much as £500 for a really good quality aftermarket shock, and
    £200+ for a cheapie.
    Your problem is having the bike off the road while they do it. A
    solution is to buy a cheap used OE shock off Ebay (should be do-able for
    £40 or less) and send that off to be rebuilt.
    We've covered head races recently. Removing the old ones can be a bugger
    of a job. As you say, while the forks are out of the yokes, you might as
    well.
    I'd really GAMI for the head races. I dunno what bike you've got, but
    consider this: if it has no centre stand, propping up the front end can
    be awkward with no forks in it! Secondly, you may have to cut the old
    races off the steering stem. It's just a sod of a job. I'm happy to do
    it on smallish bikes, but on big ones it's a bitch.
    If you are DIY-ing, then remember to slather as much grease as possible
    on the new races. Then squirt chain lube all over them: the chain lube
    carries the grease right into the bearings. Then add more grease and
    reassemble.
    The Older Gentleman, May 12, 2006
  3. Spike
    Spike Guest
    Not too much of a problem, its used to comute mainly, but theres always the
    tube for that (Ptah!)
    Doh! the one essential fact I left out..
    Its a 2001 Fazer 1000
    How much are we looking at for GAMI to do the head races?
    Is it a complete bitch of a job where you *have to know* what youre doing,
    or is it just time consuming and fiddly? Time consuming and fiddly I can
    cope with, otherwise I spose Ill have to cough the dosh...
    Spike, May 12, 2006
  4. About £100.
    Both. You're wresting with pipes, wires, cables, levers, hoses, you name
    it, and then the buggers won't come out and you don't have the special
    tool to get stuck ones out... It's just a horrible job.
    For re-assembling them, you have to know how much to tighten them up.
    It's very easy to over-tighten them, and thus ensure they'll nadger
    again in a few thousand miles.
  5. Spike wrote
    I could be wrong of course but I always though the criteria for changing
    the front fork springs were Based less upon the wear rate of
    unassociated parts and more on the relaxed length of said springs.
    Times may have changed of course but somehow I doubt it.
    Look at the play in all the wheel and steering bearings before you start
    spending shedloads on new suspension parts. It not prevent you spending
    shedloads on new suspension parts but if you replace the worm ones
    either because they are worn or on the basis of "the fucker is apart I
    may as well do everything while I am in here" it will improve the
    handling of the bike no end.
    steve auvache, May 12, 2006
  6. Spike
    SD Guest
    Eventually. <crosses fingers>
    New handlebars on tomorrow.
    | ___ Salad Dodger
    |_\_____/_| ..79553../..21469.../..31308.
    '^' RBR'06 Points: 75 Miles: 317
    SD, May 12, 2006
  7. Spike
    Beav Guest
    I've contemplated drilling a tapping a hole in the headstock for a grease
    nipple. Maybe when the time comes to change my head bearings, I'll actually
    do it. The swing arm on the Zed is already done, although it came with ****
    all grease anywhere near it.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 12, 2006
  8. Spike
    Beav said...
    How do you propose to get the grease past the outer races and into the
    part of the bearing that actually matters?
    Lozzo, May 12, 2006
  9. Spike
    SD Guest
    There's a reason for that. The clue is written on the side of the
    tank.
    | ___ Salad Dodger
    SD, May 12, 2006
  10. Not a bad idea, except that you will have to completely fill the
    headstock with grease (maybe 500ml?) before it gets to the bearings, and
    when it gets warm, guess where that grease is gonna run?
  11. Spike
    On Fri, 12 May 2006 10:27:04 +0100,
    How well do the cheaper types of aftermarket shock compare against OE
    stuff generally?
    Pip Luscher, May 13, 2006
  12. Spike
    Personally, I wouldn't go wild on the chain lube, though, and
    certainly wouldn't be tempted to use it instead of "normal" grease.
    The previous owner of a K100RS I once owned had put some sort of heavy
    grease on the head races that was *incredibly* temperature sensitive.
    On frosty mornings the steering was noticeably heavy and the bike
    would tend to fall into corners.
    It came to a head when on one memorable chilly ride home from Hertford
    to Cambridge, the bike started rolling heavily whenever the speed
    dropped below about 40mph. I did briefly wonder whether I could slow
    to a halt without falling off!
    Not surprisingly, I replaced the grease the weekend following that
    incident. Cured it completely.
  13. Quite. Which was why I said use it on the normal grease, and thern add
    more normal grease afterwards....
    The Older Gentleman, May 13, 2006
  14. Depends how good/crap the OE stuff is.....
  15. Spike
    Depends how good/crap the OE stuff is.....[/QUOTE]
    Ask a silly question...
  16. Spike
    Beav Guest
    3000 psi and a small prayer :)
    My thoughts are that if air can get in, grease can get out if enough
    violence is used. And if not, I'll use more violence.
    It's got to be worth a try anyroad.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 14, 2006
  17. Spike
    Beav Guest
    You make a more than valid point Mr Dodger.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 14, 2006
  18. Spike
    Beav Guest
    I every fucker out to spoil my fun? As to the escaping grease, in't that
    what jet washers are for:)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 14, 2006
  19. Ask a silly question...[/QUOTE]
    <VBG>
    The Older Gentleman, May 14, 2006
