Suzuki f SV650S fuel pump woes
Discussion in 'Australian Motorcycles' started by bikerbetty, Apr 13, 2010.
  1. bikerbetty
    Run a gravity feed to carburettors maybe?
    BT Humble, Apr 14, 2010
  2. bikerbetty
    Based on when it failed, it sounds like they were pretty much right on the
    button!
  3. bikerbetty
    TimC Guest
    When you find out what you want, can you tell me what I want?
    Thanks.
    TimC, Apr 14, 2010
  4. In aus.motorcycles on Wed, 14 Apr 2010 20:49:20 +1000
    your sigmonster has already done that.
    Zebee Johnstone, Apr 14, 2010
  5. bikerbetty
    theo Guest
    Agreed. It seems now that the small-block has grown to bigger than the
    original V7 and is mostly going about in the big-block frame. Not that
    that surprises me greatly. Shame though.
    Theo
    theo, Apr 14, 2010
  6. bikerbetty
    theo Guest
    Guzzi riders go through a similar agony at 40,000. Is it run in yet,
    or does it need another 10,000?
    Theo
    theo, Apr 14, 2010
  7. bikerbetty
    John Dwyer Guest
    Try the following.
    Are there any readers with experience on SVs with 50000 + km so that some
    idea of likelihood of failure can be obtained? What does the dealer say
    about this?
    If the likelihood of failure is low then you may be one of the unfortunate
    people owning an SVs with a fuel pump that has failed. Like others who have
    commented here, I would expect the fuel pump to last rather longer than
    59000 km.
    A post to SVdownunder may produce some information on fuel pump failures.
    John Dwyer.
    John Dwyer, Apr 14, 2010
  8. As per my call on price. I think you'll find a Cali costs a lot more
    than an SV 650.
    I've never had a fuel pump die, but the more you spend on a bike, the
    better the componentry tends to become (HD excepted :)
    Kev
    Kevin Gleeson, Apr 14, 2010
  9. bikerbetty
    hippo Guest
    On most things with a fuel pump there are two things:
    1/ *never* run out of fuel (yeah, yeah, best intentions & all that...) and
    2/ run a filter between source and pump inlet (not always practical.
    Cheers
    hippo, Apr 15, 2010
  10. bikerbetty
    theo Guest
    There's a few horror stories going around on small-block uni joints.
    When the joint fails, it destroys the back of the gearbox.
    Theo
    theo, Apr 15, 2010
  11. bikerbetty
    bikerbetty Guest
    Princess Paranoid (that's me) has never ever run out of fuel (touch wood.) I
    think I probably drive people nuts on long trips by making sure I fill up
    every 250kms, and topping up sooner than that if I'm not sure how far to the
    next fuel stop. I guess the 20 litre tank on the GS500 spoiled me a bit -
    the SV's 17 litre tank seems miniscule.
    Update: new fuel pump installed, wallet emptied. New Harley ordered (just
    kidding)
    betty
    bikerbetty, Apr 15, 2010
  12. bikerbetty
    Andrew Guest
    Kawasaki Ninja 650R ABS. Only 15.5 litre tank, but. Seat height 10mm
    lower than the SV (stock). Call CMC and take one out for a pootle.
    I would have thought your SV would have been good for over 100,000km
    without major expense, certainly for the motor. I wouldn't be getting rid
    of it just because a fuel pump died.
    Andrew, Apr 15, 2010
  13. Exactly...the aim of good product engineering is to have something last
    just beyond the warranty period before failing
    It also helps if the cost of replacing 'it' (or repairing if you must)
    is small enough compared to the product value that no one complains
    about this event
    Fulliautomatix, Apr 15, 2010
  14. bikerbetty
    TimC Guest
    You too, eh?
    Last trip back from Sydney saw me doing 3.7L/100km too (cold weather,
    engine ran well).
    TimC, Apr 15, 2010
  15. bikerbetty
    hippo Guest
    Maybe you just got a bad pump. Hopefully the new one'll be better behaved.
    Cheers
    hippo, Apr 15, 2010
  16. bikerbetty
    Boxer Guest
    Never seen a starter motor in a fuel tank before, makes you long for the
    days of the kick starter.
    Boxer
    Boxer, Apr 16, 2010
  17. In aus.motorcycles on Fri, 16 Apr 2010 07:09:55 GMT
    Well it would make the old trick of a spanner across the solenoid a
    bit on the spectacular side....
    Zebee
    Zebee Johnstone, Apr 16, 2010
  18. bikerbetty
    hippo Guest
    Yes, I was thinking that. You'd certainly start your day with a bang!
    hippo, Apr 16, 2010
  19. bikerbetty
    You need an XJ750 you do!
    Knobdoodle, Apr 16, 2010
  20. bikerbetty
    CrazyCam Guest
    A spark, fully enveloped in petrol, won't do any harm, but, if the tank
    is empty of petrol, but still contained fumes, then, it could be
    spectacular.
    Maybe that's why the instructions always say stuff about not running out
    of fuel? ;-)
    regards,
    CrazyCam
    CrazyCam, Apr 17, 2010
