Suzuki X7 poor starting
Discussion in 'UK Motorcycles' started by Steve, Jun 1, 2007.
  1. Steve
    Steve Guest
    Hi All,
    I have just about finished rebuilding my X7 which I purchased in boxes.
    The old girl is an absolute **** to start cold but runs perfect when hot.
    From cold it will fire ocassionally and then eventually start but only run
    for a couple of seconds before stopping. If I manage to get the revs high
    enough I can keep her running but she is constantly cutting out. If you keep
    doing this eventually she is warm and then starts and runs fine.
    Any suggestions gratefully received
    Steve, Jun 1, 2007
  2. Steve
    You seem to be confusing an inanimate collection of bits of metal,
    plastic and rubber with a living being. Once you get this sorted out
    in your head you'll be well on your way to sorting it.
    Oh, and it sounds like the mixture's too weak, the choke isn't working
    properly or the plugs are the wrong type.
    _______
    Ace, Jun 1, 2007
  3. Steve
    Rich B Guest
    Blocked pilot jet?
    Rich B, Jun 1, 2007
  4. Steve
    Piss in the tank?
    Muck, Jun 1, 2007
  5. Steve
    JB Guest
    Did you accidentally swap the float bowls round when cleaning the carbs?
    There is only a choke fuel supply jet in _one_ of them. It took me *weeks*
    to find this out.
    JB
    JB, Jun 1, 2007
  6. Steve
    MikeH Guest
    Don't turn it off.
    MikeH, Jun 1, 2007
  7. Perhaps she just needs sitting down for a bit of a heart-to-heart? She's
    obviously a sensitive sort so have you just tried giving her a hug? Perhaps
    she feels a little threatened by your masculinity and would appreciate
    seeing a glimpse of your gentler side?
    Either that or make sure the carb's jets are clean, the mixture's correct,
    and you've got the correct, properly gapped, plugs in the bitch.
    Mungo \Two Sheds\ Toadfoot, Jun 1, 2007
  8. Steve
    Buzby Guest
    Steve wibbled:
    get a Honda . . . .
    Buzby, Jun 1, 2007
  9. Steve
    Put new plugs in the slag.
    sweller, Jun 1, 2007
  10. Steve
    TOG Guest
    Crank seals? Sniff the engine oil and see if it smells of petrol.
    TOG, Jun 1, 2007
  11. Steve
    Rich B Guest
    No, shit in the carbs.
    Rich B, Jun 1, 2007
  12. Steve
    Steve Guest
    That was it the bowl on the choke carb didn't have a hole
    thanks for the help
    Steve, Jun 1, 2007
  13. Steve
    Puke in the pipes?
    Muck, Jun 1, 2007
  14. It's all right; you can say '****' around here.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Jun 1, 2007
  15. Wonderful you've got it sorted, but next time, please read the FFAQ and
    pay close attention to the posting style bit, especially the top/bottom
    posting non-debate.
    GS850x2 XS650 SE6a
  16. That'd be a good trick.
    GS850x2 XS650 SE6a
  17. Steve
    Oooh, missed that one. TOG's trying to out-do YTC#1, it would seem.
    _______
    Ace, Jun 1, 2007
  18. Steve
    Took me a moment to work that one out.
    ogden, Jun 1, 2007
  19. Steve
    Steve says
    Bury it somewhere you'll forget and buy an RD250 instead. X7s were shite
    in the 70s, 30 years on they aren't any better.
    Lozzo
    Suzuki SV650 K3 (Trackbike project)
    Yamaha SR 250 SpazzTrakka
    Suzuki GSX-R 750L (Trackbike - for sale £600)
    I ride way too fast to be worried about cholestorol
    Lozzo, Jun 1, 2007
  20. Steve
    JB Guest
    Steve says
    Nooo!. RDs fetch *far* too much money these days. X7s do indeed have a well
    deserved rep for being 'a little fragile' if tuned, and cranks are nearly
    considered a soddin service item, but they are soooo much fun. They don't
    stop or handle well in anywhere near standard form, but Christ can they
    shift for an old 250. I think even KR1s are more reliable too.
    JB
    JB, Jun 1, 2007
